BMW M2 Forum > BMW M2 Discussions > Rear tail light issues
      01-26-2018, 09:48 AM   #23
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Originally Posted by mssVT98 View Post
the only difference in cost to do the swap would be the extra labor for coding
This is an incorrect assumption on your part.
They are NOT 100% plug and play.
You have to go from a 6 wire pin out to a 4.
That's why a dealership would never retrofit them for you under warranty.
mssVT98141.50
      01-26-2018, 09:53 AM   #24
mssVT98
mssVT98's Avatar
142
Drives: 2017 M2
2017 BMW M2  [9.67]
Great point, I was forgetting about the connectors. You're right, probably not even worth asking about the LCI tails.
I assume they'd be even less likely to work with the Euro pre-LCIs since they're not a US part, even though they would be (another assumption) completely plug-and-play.
      01-26-2018, 10:44 AM   #25
AndrewC1989
Not trying to be a negative Nancy but realistically you won't be getting anything other than a direct replacement free of charge. If you want an upgrade you'll have to finance it yourself.
      01-26-2018, 10:48 AM   #26
mssVT98
mssVT98's Avatar
142
Drives: 2017 M2
2017 BMW M2  [9.67]
Not negative at all, just realistic. I'm in the "it can't hurt to ask" camp, both about whether others have tried something similar and while at the dealer. I appreciate the feedback.
      03-14-2018, 10:55 AM   #27
LooksBeyondBasic_BMW
Drives: 2017 LBB M2
2017 BMW M2  [0.00]
Rear Tail light condensation/leaks
Gotta be the sealing. My older Lexus I removed and put in the oven at 200 degrees and resealed them, however this is a brand new car. Called service and they quickly set me up for an appointment. I've read that some people think this is normal, and the lights should breath. That makes no sense at all. Where ever moisture can get in it will settle and cause other problems, hardening of sealant, mold, etc. I'm hoping they either replace them or have a procedure for fixing them. We'll see, appointment is 3/15/18. I keep all posted. I'd take pics, but they identical to what is already posted on this thread.
      03-15-2018, 05:04 PM   #28
Cibbersicks
Cibbersicks's Avatar
87
Drives: 2017 F87 M2 LBB
Yep, mine are both horrific, going into the dealer for warranty on the 28th March.
      03-15-2018, 05:10 PM   #29
subliminalaudio
subliminalaudio's Avatar
314
Mine have been fixed after 2 visits to the dealer and get them replace twice on the right passenger side.
