M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Head light adjustment
      08-11-2017, 08:52 AM   #1
Fuman
24
Drives: F87 DCT
I lowered my car with KW HAS and the head lights needed height (Vertical) adjustment.
So if there isn't info on adjusting the headlights, here's one:
See image attached - based on front left head light. Use your imagination for the right head light.
The adjustment screw is just above and in the middle of both the heat sinks for the lights.
I used a Philips screw driver.
Projecting onto a wall about 5m away, every half turn anti clockwise raises the beam by about 10mm.
Trial and error.
(FYI- There's also horizontal adjustment but I didn't need it)
Current garage F87 DCT KW-HAS, and F20 N20. Previous E92 N54 FBO 100%-E85, E90 N52, E46, E21.
bollinm25.00
      08-21-2017, 11:21 AM   #2
DivideBYZero
DivideBYZero's Avatar
484
Drives: F87 M2<E92 M3<E46 M3
Doesn't the auto leveling sort this out?
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT
2016 F22 M235i Coupe, MW, ZF8
      08-21-2017, 11:35 AM   #3
gmzanatta
gmzanatta's Avatar
1823
Drives: LBB 6MT M2 # 660/713
To a point, depends on how slammed the car is.
Fuman23.50
      08-21-2017, 01:31 PM   #4
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Auto leveling accounts for passengers/weight. The level is still based on a baseline setting at the factory.
I have raised the headlights on every BMW I have owned. BMW seems to aim them lower then I like. Search across all the BMW forums, you find I am not alone in this.
The M2... seems to be the first BMW they are set correctly.
www.ReTuneTheDeTune.com
Fuman23.50
      07-13-2018, 08:28 PM   #5
Fuman
24
Drives: F87 DCT
I've since learnt that the right drivers side lamp dips and angles outward under 40 kmh. I needed help from a friend to send me pictures of how his lights point in reverse gear, neutral and high beam.
The best way is the set height of passenger lamp, and turn on high beam to adjust level and gap between drivers side lamp vs passenger side.
Technically both lamps on high beam should be perpendicular when pointed onto wall - the horizontal position.
      07-19-2018, 05:52 PM   #6
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
Yeah, a non-US car should have VLD coded from the factory, meaning your beams are going to move around at lower speed, they drop a bit more and fan out to the sides to help illuminate more sidewalk/etc at "city speeds."
Putting it in reverse should revert them back to "normal," or at least that's how my US-spec car with VLD enabled via coding behaves. So to adjust the lights at normal height, put it in reverse and shut off the engine I guess? Or, maybe the lights don't adjust if the engine isn't running... I haven't checked that.
Fuman23.50
      07-19-2018, 05:55 PM   #7
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
That's correct. Engine has to be running for VLD to be enabled. They won't pan out in accessory mode, even if the headlights are switched on.
      07-19-2018, 06:00 PM   #8
ZPrime
I INDIC8
ZPrime's Avatar
2018 BMW M2  [9.50]
Originally Posted by andrewc89 View Post
That's correct. Engine has to be running for VLD to work. As soon as you start the car and enable the headlights the drivers side will pan out.
Ah, so problem solved then. Put it in "run" / accessory mode and turn on headlights, engine off. Adjust height with the screw then, and simply be aware that VLD will drop them lower and spread them out at lower speeds (this is on purpose and expected).
      07-19-2018, 06:27 PM   #9
BSMF87
BSMF87's Avatar
140
Drives: M2 BSM 6SPD
You can also turn off auto headlights while the car is running by turning the headlight dial all the way to the right, headlights will be on in standard mode/ VLD off.
      07-20-2018, 04:11 PM   #10
ZPrime
I INDIC8
ZPrime's Avatar
2018 BMW M2  [9.50]
Oh, they don't VLD/move around when in "on" mode, only in auto!? I was not aware of that. I wonder why?
      07-20-2018, 04:50 PM   #11
Fugly M3
Fugly M3's Avatar
5067
Drives: 2023 M3CX
I've done a lot of headlight adjustment as well over the years. I've always found I can never get it perfect like a shop would. On my current 230i, they seem to have come from the factory very well adjusted, even are fine post Dinan spring drop. I'd say I owe this to the fact that the I did European Delivery. In fact, the car in general seems to have slightly higher quality that other BMWs I've had. It's almost like they once-over the car more than once for ED customers. Even the paint pre-perfecting and coating had less orange peel.
Fuman23.50
      08-27-2019, 07:59 AM   #12
switlikbob
Chuggin' Along
switlikbob's Avatar
Drives: 2017 LBB ///M2
Thanks for this info!
