BMW M2 Forum > BMW M2 Discussions > M2 Dimensions - interesting facts
      08-04-2017, 06:52 AM   #1
gsrbri
gsrbri's Avatar
Drives: F87 6MT
The M2, at 176.2 inches long, is pretty compact. Take a look at the list below:
BMW F82 M4 184.5 in
2017 Honda Civic Type R 179.4 in
E46 M3 176.8 in
E30 M3 171.1 in
      08-04-2017, 07:07 AM   #2
zenmaster
Drives: '17 M2
Lol! Would you "sacrifice" an increase in the M2's length by 3.2 inches to have the 2017 Honda Civic Type R's weight of 3,117 lbs?
      08-04-2017, 08:22 AM   #3
gsrbri
gsrbri's Avatar
Drives: F87 6MT
Fair point! Where I do think that BMW spends a lot of time/engineering, and ultimately weight, are two areas: Structural strength (unibody, safety cage) and rigidity (suspension structural reinforcement, subframes). It's a design trade that compromises overall weight for a more robust structure. I'll take that over pure curb weight savings.
DOMs335D220.50
Spa2k1194.00
No Boost4021.00
      08-04-2017, 03:38 PM   #4
gxmech
gxmech's Avatar
15
Drives: 2017 M4
Do you happen to have the width difference between the M2 and M4?
Nelson
2017 Sakhir Orange M4, 6-speed manual, exec and lighting packages.
      08-04-2017, 03:41 PM   #5
Stilakazam
Drives: 2017 M2
M4 is 73.6", M2 is 73"
      08-04-2017, 05:37 PM   #6
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
Still a lot longer than my TTRS at 165.3″...
But they had to add room for rear passengers somewhere.
It's just going to make it a very tight fit in my stupid short garage.
Technically the garage isn't that short, but due to the layout and where the stairs to the house are and the requirement to leave room for people to walk past, I don't have as much F/R room as my wife's side. She has a Forester so we can't switch, so I basically *must* have small-ish cars.
Which I don't really mind, because I hate driving big stuff, even though I myself am pretty large.
      08-04-2017, 07:37 PM   #7
Tag
this is the way
Tag's Avatar
18118
Drives: N-1 starfighter
What's really interesting is the curb weight between an M2 w/MT and an e46 M3 w/MT is the same at 3,450 lbs. The curb weight between an e46 M3 with SMG differs by only 3 lbs between it and the M2; e46 M3 w/SMG 3,508 lbs. | M2 w/DCT 3,505 lbs.
Weights...
SW192453.00
      08-08-2017, 07:59 AM   #8
Obioban
Emperor
Obioban's Avatar
1613
Drives: M3, M3, M5, M5
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2005 BMW M3 Coupe  [0.00]
2001 BMW M5  [0.00]
Weights...
BMW's e46 M3 6mt curb weight with 6mt is 3415 lbs. BMW's e46 M3 SMG curb weight is 3450 lbs. I don't know why C&D published that curb weight, but it certainly isn't the official one from BMW.
But, you should compare BMW's numbers to BMW's numbers-- not compile numbers from different sources with different procedures.
(e.g. some curb weights include a driver and small suit case, some don't, some are the base car, some are "as typically optioned")
This winter I should be getting mine under 3000 lbs with full interior (including back seat) and a quiet muffler
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport
      08-08-2017, 11:30 AM   #9
geogerf
geogerf's Avatar
116
Drives: MY17 LBB M2
2017 BMW M2  [0.00]
That's lighter than a M2's current weight...?
JustChris17483.00
      08-08-2017, 11:44 AM   #10
Aronis
Aronis's Avatar
2269
Drives: 2018 M5
I crush the curb weight stat on my M2 but just getting into it.
Mike
2018 M5 and 2019 Porsche Boxster GTS
Prior. '94 325is, '97 M3 Lux, '16 M2
ZPrime611.50
      08-08-2017, 01:00 PM   #11
akkando
akkando's Avatar
5862
I think C&D weighed the car, that's why the published it, no?
      08-08-2017, 01:05 PM   #12
carl44
Drives: M2C
i have scales and mine weighed 3456 full tank . carl
      08-08-2017, 01:36 PM   #13
Dee Pee
Dee Pee's Avatar
176
Drives: '11 AW 1M, ‘24 718 GTS
Yeesh...4 inches longer than my 1M. I'm just got concerned about if I can get my (if I get an allocation) CS into my garage. City living=tight spots.
      08-08-2017, 03:06 PM   #14
Tag
this is the way
Tag's Avatar
18118
Where are you getting your weights from? Doing some extensive Google'n this was the only legacy web page I could find direct from BMW on a 2004 M3 Coupe. Its weight doesn't match any of the numbers that have been discussed thus far.
https://secure.bmw.com/in/en/newvehi...gine_data.html
      08-08-2017, 06:43 PM   #15
XutvJet
Drives: 2011 Cayman Base, 2016 M235
I promise you that if you put both the M2 and Civic Type R on a rack and look under the interior panels, the underbody, and under the hood, you'd see the robustness in the BMW engineering compared to a factory modified Civic. I'm not knocking the CTR at all and i am in an amazement of its performance (not looks); however, it's not built to the standards of BMW. I work on my own cars and had a 2012 WRX before my M235 (my first German car ever at 42l). The difference in engineering is boggling. Not trying to be a BMW nutswinger, but it's clear to me why the 2 series is a bit hefty for it's size. My M235, no moonroof, 6mt, and full weight is 3,335.
No Boost4021.00
JustChris17483.00
      08-08-2017, 06:59 PM   #16
No Boost
enthusiasm > practicality
No Boost's Avatar
Drives: 987 CS | G35x
The car is compact. You'll be fine.
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp
Left lane campers, GTFO!
      08-08-2017, 07:57 PM   #17
zenmaster
Drives: '17 M2
Yes, over 300 lbs lighter. All the weights can be googled.
      08-09-2017, 02:35 AM   #18
ZPrime
I INDIC8
ZPrime's Avatar
2018 BMW M2  [9.50]
Mike
Same here... If I could do the -50-80lbs driver mod, that would be awesome, but I have 0 willpower.
      08-09-2017, 03:10 AM   #19
Levente_CSL
196
Drives: bmw m3 csl
the funny thing is that the 7er G11 has more weight savings in core like any M car. which is kinda......stupid. im not saying that the G11 is lighter then an M car, but they made much more effort to save weight compared the older 7 series. Why dont they do the same effort on the m cars is beyond me. the new 7 series has carbon in the raw chassis. On the M cars we just get this trendy carbon here and there which does not seriouely save weight or have any purpose. new 7 series is like 120 kg lighter then the old. 120kg!!!!!!!!!!!!!! thats a lot. last time BMW made such a weight saving was the M3 CSL
      08-09-2017, 05:32 AM   #20
JustChris
General
JustChris's Avatar
Drives: Tesla MYRWD
Correct, that will hopefully change moving forwards. All current M car are F chassis. Let's see what the G chassis brings to the M. For example even with added X Drive the new M5 will be lighter than the outgoing by a margin. How much carbon core is carried over the general 5 I'm not certain. Then let's see next gen M3/4 etc etc. Jus the way BMW model proliferation works, 7er would have it first.
My car made front page of Bimmerpost
      08-09-2017, 06:21 AM   #21
Obioban
Emperor
Obioban's Avatar
1613
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2001 BMW M5  [0.00]
Unlikely since they listed as "curb weight" rather than "weight". Also, I'm not sure how they would have optioned a car to be that heavy stock.
... and either way you were comparing C&D numbers (e46) to BMW's numbers (M2).
https://web.archive.org/web/20050816...e/techdata.htm
From their US web site in 2005 (since the US website is what was linked for the M2)-- 3415 for 6mt, 3450 for SMG.
European curb weight is a different standard, so number won't line up.
      08-09-2017, 06:23 AM   #22
Obioban
Emperor
Obioban's Avatar
1613
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2001 BMW M5  [0.00]
I do feel like focusing on curb weights in general is a little silly, as "as typically optioned" can vary the weight of a car A LOT, and different standards around the world add confusion.
Better to just get your car corner balanced and know the exact weight of your individual car.
JustChris17483.00
