M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Chassis stabilization error
      06-24-2017, 05:28 PM   #1
Whatup
Drives: LBB M2
Was on the track turning into a corner from a long straight, rear wheels kinda locked up a little bit and lost power. Got a error saying chassis stabilization, drive moderately. Turned the car off and on and it was fine. Anyone else experienced this? Error hasn't returned since and the rest of the run was fine, but thinking of taking it in just in case.
      06-25-2017, 01:48 PM   #2
Peter_VIE
Austria
183
same happened to me once on track, after hard braking and turning. Restarted engine and never appeared never since then.
Whatup30.50
D CHOI581.00
      07-06-2017, 04:42 AM   #3
D CHOI
D CHOI's Avatar
581
Drives: 2017 BMW M2
I just made a post about this as this happened to me in a parking lot. The error hasn't came back ever since. Have you gotten any updates about this?
      07-06-2017, 09:49 AM   #4
chmura
chmura's Avatar
1558
Drives: 2019 M2 Competition
Strange this would happen when the M2 does not have an adaptive suspension.
What is the cause of this?
2011 BMW M3 Sedan Alpine White
Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD**
      07-08-2017, 06:03 AM   #5
Wangspeed
Sounds like the ediff getting upset. Was this before or after the initial breakin service?
      07-08-2017, 08:26 AM   #6
D CHOI
D CHOI's Avatar
581
Drives: 2017 BMW M2
I have about 3kish miles on the car already but everything seems fine now.
      07-09-2017, 07:15 AM   #7
Whatup
Drives: LBB M2
I drove my car around for about 2 weeks after the error and didn't have a problem, but decided to bring it in just in case. There was a code for over-revving oops They just cleared the code and I was on my way. But over-revving in a parking lot? I guess anything is possible.
D CHOI581.00
      07-09-2017, 09:37 AM   #8
D CHOI
D CHOI's Avatar
581
Drives: 2017 BMW M2
I don't remember over revving...it wasn't even that serious. Perhaps I didn't pause long enough when changing gears from reverse to 1st and pushed it lil hard.:
      07-19-2017, 10:08 PM   #9
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
Yes - a couple of times in my 235i on track. In all cases I was a bit low on fuel. A quick shutdown and restart cleared it in all cases.
      07-03-2018, 02:48 PM   #10
jasmial
jasmial's Avatar
Drives: 2017 M2 Long Beach Blue
I've been getting this error warning for about a year now. Started last summer. Came on once, then again over the winter. Had a few other codes pop up during winter and brought car into dealer a couple of times. Two weeks later, after disassembling most of interior, they found a shorted wire in wiring harness under passenger side seat . No problems for the next 6 months, now the code has returned along with something about adaptive headlight malfunction. Just pops up at random times, usually resets after car has been turned off for a while. I have an appointment to have dealer look it at AGAIN next week.
      08-11-2018, 03:32 PM   #11
Leichardti
Leichardti's Avatar
11
Drives: 2015 BMW 335i
I saw your post regarding chassis stabilization and adaptive headlight malfunction. I have the exact same problem with my 2015 335i. Along with the error messages, I lose power steering. The first time it happened was 3 weeks ago. Turned the engine off, then back on and the problem went away up until yesterday. Parked my car, went to Lowes and when I came back to the car and started it up, I got the problem again. Turned the engine off, then started it up and the problem went away momentarily, but came back after I pulled out of the stall. Did the same turn car off then back on with the same results for the next two attempts and got the same results (cleared errors only momentarily). Finally, after the forth attempt, the errors reset and I was able to drive the car home. My car is currently at the dealership. I am awaiting their update. Did you get any luck with resolving this problem?
