M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Wheel arch liner plug removal.
      05-17-2017, 12:29 AM   #1
Prodigy.
Prodigy.'s Avatar
699
Drives: ///M2
Anyone know how to remove these plugs behind the front wheels holding the wheel arch liner on please?
Do they just pull out or do i need to do something with the pin in the middle? Would like to not break them so i can re-use them.
      05-17-2017, 10:33 AM   #2
NO_USER_
Drives: .
Push in the center circle/pin and the fastener should pop out/unlock!
Prodigy.698.50
      05-20-2017, 04:10 AM   #3
dtmurf
dtmurf's Avatar
485
1996 BMW 318is  [4.75]
2012 Audi Q5  [4.50]
2017 BMW M2  [10.00]
Might not be able to reuse them as the center pin will probably fall out when you push it in. It's not a reusable item for the dealer but if you can find the pin, you can reinsert it!
You can find replacements on-line (Amazon) and they're cheap...the attached pic might not be exactly what you are looking for but you get the idea.
Prodigy.698.50
      06-17-2017, 10:41 AM   #4
bernstem
bernstem's Avatar
They are $0.26 and stocked in every dealership. As cheap as they are, I now replace them rather than reuse as they are never the same after you take them out.
      07-10-2017, 08:40 AM   #5
stefan
stefan's Avatar
Drives: M2 Comp
^^ This. Anyone who has owned any BMW any period of time knows you need to find every type of these you have on your car and order a few dozen of them to have in your toolbox. Just replace em.
///M Power
