06-18-2017, 07:20 AM | #1 |
Rep 1,608
Moonroof
You guys equipped with M2 Moonroof, can you tell me how much it encroaches on your headroom?
Here in the USA, its being offered for the first time on the '18 production, and I ordered mine with one... But never having had the opportunity to sit in an M2 with a moonroof, Im concerned about how much headroom I'll lose. I have a 135i now with moonroof, and E36M3 before that also with moonroof, and never had a problem.. But this time its sight unseen so Im concerned. I guess I can always find a 2 series equipped with one to sit in and compare. The height of an M2 and my current 135i is about the same on the external dimension, so, if the height of the headliner is about the same also, it should be comparable to what Im driving now. I hope. Thanks.
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 Last edited by boostm3; 06-18-2017 at 08:38 AM.. |
06-18-2017, 08:33 AM | #2 |
Rep 110
Someone here stated they just sat in a 2 series coupe (230i, 240i, whatever) with a moonroof to make sure they fit (2 series have moonroof options avail in the US).
I had the same concern so I went to my local BMW dealer, scoped out the 2 series with moonroofs and asked to sit in one. I fit but I was a little surprised at how much it does take away - others have said like 1 - 1.5 inches. I'm 5'7" by the way. For me I "need" a sunroof - I live in SoCal.... :-) Last edited by BLOJOE; 06-18-2017 at 11:27 PM.. |
06-18-2017, 08:48 AM | #3 |
Rep 549
Drives: The Bus
What's the difference between a sunroof and a moonroof?
06-18-2017, 09:17 AM | #5 |
Dinosaur supervisor
3030
Rep 4,214
I would never go with both moonroof and electric seats. It depends on how long you are of course and how high you like to have the seat. But I usually have mine at the bottom and I have manual seats so no biggie.
I opted out of electric seats just to get the moonroof. And I'm in a wheelchair and adjust my seat every time I enter the car to take in my wheelchair so I would have preferred electric seats. |
M3 Adjuster7909.00 |
06-18-2017, 12:15 PM | #6 |
Rep 1,431
06-18-2017, 12:21 PM | #7 |
Dinosaur supervisor
3030
Rep 4,214
Nah, it is as Spa2k said. Moonroof is made of glass and sunroof is any body panel that opens if you go on what most people refer to them as. But they are all sunroofs, moonroof is just a marketing name that Ford invented back in the 70s.
06-18-2017, 12:47 PM | #8 | |
Rep 2,200
06-18-2017, 01:09 PM | #9 |
Rep 1,608
You guys in int'l markets who have the moonroof installed, is this essentially the same moonroof offered as standard equipment on the M240I described as follows?
"2-way power glass moonroof with "one-touch" operation and sliding interior sunshade"
Boostm3
06-18-2017, 01:15 PM | #10 |
Rep 642
I went with the spaceroof.
Normally, a moonroof doesn't have a track mechanism for sliding underneath so it weighs less than a sunroof. Structurally they both compromise body integrity and torsional stiffness. Edit: My reference is from years ago when you could easily add a pop up glass panel. Moonroof you can see through and now BMW calls them that and they slide as well. Remember my buddy adding a pop-up moonroof to his Ford Pinto.....what a classic that was! Last edited by M2Nebula; 06-18-2017 at 01:23 PM.. |
2M502.50 |
06-18-2017, 01:52 PM | #11 |
Dinosaur supervisor
3030
Rep 4,214
Yes, it is the same as the regular series car.
06-18-2017, 02:37 PM | #12 | |
Rep 1,086
OTOH, a moon/sunroof does add maybe 20-50 lbs of weight up high, which will very slightly raise the center of gravity - important only to a couple of percent of track-day drivers qualified for, and capable of, setting record laps in their M2s. |
06-18-2017, 03:25 PM | #13 | |
Rep 642
06-18-2017, 03:47 PM | #14 |
Rep 1,086
The purposes of having a hole in the roof are decidedly different for a BMW vs. a Pinto. For the BMW, it's ventilation, light and a connection with the outdoors. For the Pinto, it's an escape hatch for when you get rear-ended and the fuel tank explodes.
06-18-2017, 10:21 PM | #15 | |
Rep 13,144
Fringe benefit of a sliding roof: extra escape route...
///M is art ↔ Artemis
Spa2k1195.00 |
06-18-2017, 10:29 PM | #16 | |
Rep 13,144
Driving wih tilted roof is relaxing. Even in the rain. Fresh air enters the interior. No noisy drag as with side windows partially opened.
BMWM5NYC502.00 |
06-20-2017, 05:24 PM | #18 |
Rep 1,608
What does no openings available mean??
Boostm3
06-20-2017, 09:06 PM | #19 |
383
Rep 731
Sunroofs are available in US as of MY18. You will have less headroom, which may not be an issue if you are 5' 10" or less. I have a 2015 228 with no sunroof. I opted out because I am 5' 11", and felt it would be an issue if using a helmet for track days, which i have done several times.
06-20-2017, 10:32 PM | #20 |
Rep 1,608
I dont think headroom is a big issue if trackdays arent contemplated..
Boostm3
06-21-2017, 12:59 AM | #21 | |
Dinosaur supervisor
3030
Rep 4,214
Hence my previous post that I would NEVER get both electric seats and moonroof at my height or taller. And there is no way at all for me to fit a helmet. |
06-21-2017, 06:21 AM | #22 | |
Rep 1,608
http://f87.bimmerpost.com/forums/sho...8&postcount=12 Here are the specs for 135i which I believe only comes moonroof equipped.. strangely it shows the same headroom as the spec for the 1M : http://www.thecarconnection.com/spec...3_2dr-cpe-135i
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 Last edited by boostm3; 06-21-2017 at 06:42 AM.. |
