M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Driver Restraint System Malfunction after Steering Wheel Swap
      03-12-2024, 01:46 PM   #1
bhong
Drives: NA
I switched back to my stock steering wheel, now I have this error message on my car and will not go away after a restart or disconnecting/reconnecting the battery. I had to remove the steering wheel airbag and had the battery still connected during the install. Is there a way I can clear this without potentially paying for a trip to the dealer? I don't have Bimmercode or Bimmerlink but will either of these apps clear this?
      03-22-2024, 12:33 PM   #2
Got f1?
Got f1?'s Avatar
Drives: 06 E46 ZHP, 20 X3M, M2CS
Unfortunately the only way to avoid this is by disconnecting the battery during a swap which you should always do anytime you are working on SRS (airbag) items. It will need to be cleared with a capable tool.
You can try to disconnect the battery for 15-20 minutes but doubtful that will work
      03-23-2024, 03:37 AM   #3
maxfrompine
maxfrompine's Avatar
4
Drives: BMW M2C
if you have bmw Tool32 you can try to remove the codes in the Airbag ecu...maybe!
F87 ///M2 Competition '19 Alpine White
      03-25-2024, 12:31 PM   #4
bhong
Drives: NA
Ended up purchasing a VeePeak OBDII scanner paired with the BimmerLink app and was able to clear the code but good to know the battery should be disconnected prior to working on anything with airbags.
