04-26-2017, 09:44 AM | #1 |
Rep 1,835
Drives: 2020 X4M CS
Problem installing VRSF CHarhe Popwk?
My background. 15-18 BOCES for auto tech, electric, auto hbac, and inspector class...I then worked in 3 shops over 12 years from High Performance to Stereistereo Installation and everything in bewteen.
I don't say this to brag just to make a point, I am an experienced trained tech, even this is the first mod in the M2 I'm having serious trouble. As you know the VRSF CP comes with an upper sect. ( C Clip to throttle body 3") and Lower 2.5" Sect, that clip to the VRSF FMIC, They meet under the A/C Compressor and attach w a 3" long 3" to 2." reducer.... Well that gap depending on where the engine stops do to its torque is almost 3" and no matter how tight I make the clamps the engine movement rips that connection open... Has anyone else had this issue??? I ordered a 4" reducer that'll be here today. other wise im clueless other than returning to OEM? Help g stock pipe. AM I the only one w this issue?
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
04-26-2017, 01:13 PM | #3 |
Meh
926
Rep 781
Drives: M3CS & Cayman S
I had the same problem w/ ER charge pipe. had to torque down the clamps a bit more than just "hand-tight". also the rotation of the charge pipe may be off a bit. it needs to be very close to exact so the pipes line up such that the clamps are effective.
04-26-2017, 01:35 PM | #4 |
Rep 1,835
Drives: 2020 X4M CS
[QUOTE=UltraMagneticAL;21618010]I had the same problem w/ ER charge pipe. had to torque down the clamps a bit more than just "hand-tight". also the rotation of the charge pipe may be off a bit. it needs to be very close to exact so the pipes line up such that the clamps are effective.[/QUOTE
Youre right but still to short, i would leave off the bottom clip turn the pipe counter clockwise, to get it in the tun it clockwise and uo to to in further,,,zi just cant get more than 1/4 inch to stay in
04-26-2017, 01:38 PM | #5 | |
Meh
926
Rep 781
04-26-2017, 07:56 PM | #6 |
Rep 1,835
Drives: 2020 X4M CS
i ordered a 4" long HPS coupler from amazn, it came overnight, problem solved :}
thank u though, good suggesstions
05-03-2017, 01:59 PM | #7 |
24178
Rep 190,767
I recommended contacting VRSF ... We sell a lot of VRSF charge pipes, no complaints
05-04-2017, 12:42 AM | #8 |
Rep 1,835
Drives: 2020 X4M CS
as I said, taken care of...Holding up very well...I was not leaving enough space in the coupler between the top and bottom...the engine movement was ripping the clamp off on hard shifts.
05-07-2017, 08:42 AM | #10 |
Rep 1,835
Drives: 2020 X4M CS
It's been fixed and holding 20psi for almost 2 weeks...one thing I could say is include a 4" long 3" to 2.5 silicone reducer" instead of 3" long. The cp still has plenty of allowable engine move my but bc's sooo much more reliable and easier to install.
05-11-2017, 03:19 PM | #11 |
24178
Rep 190,767
Glad you got it to work
05-12-2017, 11:00 PM | #12 |
Rep 1,835
Drives: 2020 X4M CS
FYI I bought it along with my fmic, and JB4 from you guys and I'm very pleased with the price, shipping speed and products
05-13-2017, 01:10 PM | #13 |
24178
Rep 190,767
Thank you for your support!
