04-26-2017, 04:58 AM | #1 |
Rep 304
Missing Part..... Any M2 updates
I came across this post on the 2addicts forum today http://www.2addicts.com/forums/showthread.php?t=1200964
My 16 M2 hasn't got these installed, what about anyone else? I test drove the M2 and thought it to be quite a quiet car but after purchasing and doing a long and spirited run this weekend I noticed I had to keep turning up the Volume when going fast and then lowering when slowing down. I had quite a lot of engine noise. Anyone else got these fitted to the M2?
2016 F87 M2
04-26-2017, 06:01 AM | #2 | |
S0THPAW
8715
Rep 7,846
You are aware of the fact there is an artificial(ASD)enginesound coming in through the speakers which can be switched off? That's what I did. Great mod. http://f87.bimmerpost.com/forums/sho....php?t=1272747 Cheers Robin |
04-26-2017, 11:45 AM | #4 |
this is the way
18122
Rep 8,513
The insulation is not standard on the F87, but it is for other 2-Series models. My guess is it's most likely due to cost cutting and/or overall weight reduction as there's quite a bit of insulation on the 2-Series that was omitted on the M2.
2' F87 M2 M2 SOUND INSULATING FRONT 2' F22 M240iX Sound insulation Sealing side panel, left #51487300693 Sealing side panel right #51487300694 |
04-26-2017, 12:01 PM | #5 | |
Rep 3,949
04-26-2017, 12:13 PM | #6 |
“One finds limits by pushing them”
123
Rep 529
I'd like to try this... got the part numbers? How did install go?
MY2019 M2C
Street Bike: Honda Grom. Track Bikes: 02 SV650/09 R6 "It is a shame for a man to grow old without seeing the beauty and strength of which his body is capable" |
04-26-2017, 12:33 PM | #7 |
this is the way
18122
Rep 8,513
04-26-2017, 12:49 PM | #8 |
Rep 246
Installed these last month in my car, its meant to cut down road noise as I've just got the car hard to tell.
Installation is easy, just used my fingers. Search the forum there are multiple references. MJ |
04-26-2017, 02:18 PM | #9 |
Rep 424
www.bmwpartsworldwide.com has the best price including shipping. Copied the part #'s from the 2addicts thread.
2018 M4 convertible SBM
1990 E30 Convertible 2003 E39 |
04-26-2017, 02:35 PM | #10 | |
this is the way
18122
Rep 8,513
04-26-2017, 04:20 PM | #12 |
Rep 246
I used these:
Sealing side panel, left #51487300693 Sealing side panel right #51487300694 Lowered them in from above the lower door hinge, then slid them back up to the top hinge from below. Start pushing in with fingers from the top until the bottom, and you might need to cut a small amount away from the bottom. MJ |
Tag18122.00 |
04-26-2017, 06:50 PM | #13 |
Rep 1,514
Has been discussed here previously, thread with some more info:
http://f87.bimmerpost.com/forums/sho...ighlight=seals |
04-28-2017, 08:12 PM | #14 | |
Rep 3,293
Mike
04-29-2017, 10:23 AM | #15 |
Rep 1,124
Ordered today for my M2.
