M2 Technical Topics > Track / Autocross / Dragstrip > Track setup - yeah, I know, another thread
      01-16-2020, 07:43 PM   #67
243Racing
1448
Why’d the rotor have to come off?
      01-17-2020, 12:40 AM   #68
mcgarnigle
Drives: M2C
Can you post pics of the rollbar installation?
Your previous alignment was wack!
      01-17-2020, 09:55 AM   #69
K-Fab
Dirt Junkie
K-Fab's Avatar
Drives: 2020 BMW M2 Competition
Was informed that it made room, made things easier, lightened up the components to work with, etc.. Made it simpler.
Not a lot of "install pix" were taken - but I did snap a couple to share with Studio RSR.
The install video they have is of an M4 (four doors). It's a bit different with just two doors.
RSR also doesn't expect you to put the side bolsters of the back seats or the seat belt covers back in. I wanted to keep it as "stock" as I could. I think they expect you to put in the seat delete - I'm not paying a bunch of bucks for a piece of pressboard covered in Ozite.
First thing was to cut a clearance notch so the top bolster attachment hole was accessible again. Cutting this plate where I did does absolutely NOTHING in damaging structure or strength. The tab just hangs over the lip that the seat belt attaches to and the mounting point for the down bars is the seat belt mount - you can see the hole at the back.
Then I trimmed the seat belt covers:
Stuck them back in, marked the bolsters and didn't quite take enough angle into account - both holes ended up being a tad biased outward so the fit left a small gap as seen in the pix below:
RSR wants an X cut into the carpet where the legs of the main hoop mount. They just tucked the ends up against the legs and I thought it looked a tad unfinished.
I went about it a bit differently (as usual...) and tried to make the fit "more better". My cut outs ended up being about 1/2" forward of where they needed to be but I was able to cheat it out and trim the pucks I pulled out and fit them into the gaps:
Here are the gaps at the rear cage where it goes into the bolsters:
Yes, that's a grinder slip. While cutting the clearance hole of course the cut off wheel caught and scraped the powder coating off of the bottom of the down bar. Crap happens.
At least my consistency at missing is the same - just a quarter inch.
If someone's going to take enough time to look in and state that I missed I'll just kick 'em in the shins and say "You go do it by yourself."
Yes, previous alignment was completely dorked. Looks like I need to go on a little solo breakfast run in the twisties and see how things feel now this morning.
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming 'WOW-What a Ride!'" - Anonymous
CrashFL137.50
      01-17-2020, 10:45 AM   #70
243Racing
1448
Super clean cage install. Bravo.
      01-18-2020, 10:19 AM   #71
K-Fab
Dirt Junkie
K-Fab's Avatar
Thank you, thank you very much. (in my best Elvis, of course!)
      01-19-2020, 04:34 AM   #72
mcgarnigle
Drives: M2C
Does the main hoop drill into the floor with plates, or does it bolt to an existing location (like the seatbelt mounts).
      01-19-2020, 08:47 AM   #73
mcvaughan
mcvaughan's Avatar
Drives: F87 Competition
The former. Not ideal, but aside from that they build a nice cage.
Matt
      01-20-2020, 02:07 PM   #74
K-Fab
Dirt Junkie
K-Fab's Avatar
As stated above.
Rear down bars bolt into the seat belt retractor mounts, using the OEM fasteners and the legs are held in with three nut/bolt/washer. You drill three holes in the floorboard for each leg - outer rear is not mounted.
There are three or four 8mm head screws on the bottom of the car and five or six push pin retaining clips along the bottom edge of the belly pan just at the rear of the door - pull them and then pull down on the belly panel (discovered some swearing seems to help at times) and you can get to the location of the nuts. It's a tight fit but doable.
They supply nice zinc coated Grade 8 hardware and large washers to spread the load over the floor. Only thing I'd change is going to a shorter bolt than they supply - about half an inch of thread is just sticking out and there for nothing more than threading over. As a rule, you only need 1.5 to 2 threads extending out of the nut.
      03-06-2020, 09:14 AM   #75
K-Fab
Dirt Junkie
K-Fab's Avatar
Looking forward to tomorrow: Have an HPDE day at Arizona Motorsports Park (gonna be busy too - have two students, one's a friend who'll be driving my car. She's excited!).
I'm really excited to see how the new set of Ohlins and CORRECT camber & toe settings work. New rubber, new dampers, new settings - woo hoo! (:
In the process of securing a Cobra Nogaro seat so I can take advantage of my harness. It doesn't work safely with the OEM seat.
243Racing1447.50
Ex_Stig2594.00
      03-06-2020, 09:36 AM   #76
Conissah
Conissah's Avatar
1576
Drives: 2018 M3
Originally Posted by K-Fab View Post
The settings up front were WAAAYY off.
Looks like the company I use had no clue (and I will admit I kind of wondered - I felt like I understood the system better than the guy running it - who was not the regular guy) Camber was at 3.4 and toe was in three degrees. Explains the sever cording.
Aligned on the latest Hawk-Eye system:
Car is now set at 3 degrees camber, zero toe front
1.9 camber, presently mentally blank on toe in - 1 degree or did he say 1.8...
And now that I type this I realize I didn't get a sheet from this guy either (although I trust him - It's very obvious he does know his stuff.)
3 DEGREES OF TOE? Good lord I hope you meant 3 tenths...
Interesting thread, seems like a knowledgeable lot here. Only experience I have with the R888 is that they're LOUD on the dyno, almost louder than the exhaust of the car we had in the shop. Is it the same in the car?
243Racing1447.50
      03-06-2020, 09:41 AM   #77
243Racing
1448
I LOVE AMP.
      03-06-2020, 04:33 PM   #78
K-Fab
Dirt Junkie
K-Fab's Avatar
I'm almost positive they said degrees.
Regardless, it was WAY off.
Yup - they are loud everywhere.
Conissah1576.00
      03-06-2020, 05:08 PM   #79
Montaver
Montaver's Avatar
Drives: G87 M2 & M340i LCI
Are you running spacers up front for extra clearance or do the Apex clear the Ohlins no issue? I'm considering Ohlins (had them on my M3), but JRZ RSOne's are effectively the same price with camber plates which definitely don't have clearance issues.
      03-07-2020, 06:53 AM   #80
K-Fab
Dirt Junkie
K-Fab's Avatar
Yes. Apex wheels, Ohlins struts & Ground Control camber plates.
No rubbing anywhere.
      03-07-2020, 09:19 AM   #81
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Are you running ohlins r&t? Do they fit the oem top hats?
I have a set of tc kline plates with the oem strut adapter on them, so I was curious if the ohlins would mount up.
Thanks.
Motorcity BMWCCA Member
Instagram | YouTube
      03-07-2020, 04:46 PM   #82
Montaver
Montaver's Avatar
Interesting, how much camber are you running? tire width / brand? - Looks like 888, and -2.8?
Edit - are you using the standard spring setup or are those custom?
Appreciate it!
      03-07-2020, 10:51 PM   #83
SEAT TIME RULES
SEAT TIME RULES's Avatar
1103
2020 BMW M2C  [5.00]
What is your rear seat still doing in the car with that cage? You will drop 60lbs taking it out...
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
      03-08-2020, 11:14 AM   #84
K-Fab
Dirt Junkie
K-Fab's Avatar
Thanks.
Yes, using the R&T setup. Can't tell if you they use the OEM top hats or not - I have Ground Control camber plates and I believe all the upper spring stuff was changed with the Ohlins kit. Can't hold me to that though, as I didn't do the work. 95% of the time I'm totally hands on and the one doing the work but I'm tired of working on street stuff. I wanna get it, hit the key, go play.
Appreciate it!
1.9 camber, toe in - 1 degree. Yes, Toyo R888R sneakers. The springs came with the Ohilns.
I kept a pretty close eye on temps across the tire's face (Longacre gauge with pyro temp sensor - http://www.longacreracing.com/produc...auge-0-100-psi) and was pleased with the consistency of the measured temps (140ish outer to 155ish inner tread temps up front, 150-155 rear).
Two aspects.
First, I wanted to keep the back interior of the car for aesthetics. That'll probably change as I move onward with the car. It's only 6 months old with 3100 miles (of which around a third are track) so I'm not quite ready to start yanking out and shelving stuff.
I know I can loose quite a bit of weight removing it but I don't care to spend close to 2K for a sheet of press board covered in Ozite for the "back seat delete".
I'm capable of doing the seat delete on my own, just don't have the time/desire to spend on it right now - that's all taken up with my present (5 year long) project in the pic below. Once it's done I'll probably direct more attention to the M2.
New suspension - Thoughts and observations.
With the stock suspension, coming out of turn 8 and into 9 at AMP there are chatter bumps and it's slightly off camber. The back end was twitchy, skittish and never felt planted at all.
I had a student with an M4 that has adjustable ride suspension (guessing magnetically controlled - I'm not up on BMW's technology - still new to it) and it was silky smooth over the section and felt very compliant and planted.
My car, with the Ohlins now, feels the same way. It was stuck down, planted and put the power down w/o getting all skittish.
Cornering seems much better too - more confidence going into them and less understeer unless pushed. The balance is better. I can stick/slip either end as desired with a little pedal dancing (left foot braking helps SO much in being able to overlap inputs for chassis balancing).
Back end seems much more planted too - still seems like I get oversteer pretty badly on throttle & exit but that's all controllable with my right ankle. Do have to admit that the four wheel drift at 80+ out of a couple of the corners at AMP are a lot of fun.
I'm impressed with just how controllable the M2 is even when the tail is out wagging in the breeze like a happy puppy.
Overall I'm VERY pleased with what I've done to the car for the track.
I do have one complaint/desire to change: My brakes are great, no issues (Pagid yellows), would just like something a tad more "personalized".
They stop well, have good modulation, blah, blah. What I'd like, though, is a bit more pedal meaning I wish it would stiffen up sooner in the throw and have a more solid feeling.
The pedal has a soft zone when initially stepping on it and then once it gets into the braking area of it's throw, it's on the softer side with a tad more travel than I'd like. Gives me a mushy feeling with less modulation feel than I'd like.
I'd prefer a slightly stiffer pedal with less throw - What'd I'd do in my off road stuff to solve this would be to up the piston size in the master cylinder and change the ratio between the pedal and the pucks along with adjust the pedal throw and where it enters the brake pressure zone.
      03-08-2020, 11:19 AM   #85
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
The rear seat weighs 60lbs? Pulled mine out when doing some wiring and it didn't seem that heavy. Maybe 25lbs? Dunno, maybe I'm just super buff. (definitely not)
Instagram | YouTube
      03-08-2020, 12:37 PM   #86
FaRKle!
It's a monotube damper that adjusts via traditional methods (valve orifice sizes) and not magnetorheological.
Pagid RSL29s defintely lack bite and require a long pedal throw before they really start to grab and slow the car down. Moving to a different pad compound (like PFC08) will provide more immediate grab and feedback. When I first made the switch from RSL29 to PFC08 I kept pushing the pedal in like I did with the RSL29s, and ended up engaging ABS with the PFC08s till I learned their behavior.
      03-08-2020, 12:45 PM   #87
FaRKle!
Thanks.
Ohlins use the OE top mounts (front and rear). They come with an adapter that sits against the OE top mount thrust bearing that necks down the spring size (IIRC they use 65mm springs).
      03-08-2020, 12:58 PM   #88
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Thanks.
Thanks. So with that said, they should be able to mate up with my TC Kline plates.
Instagram | YouTube
