M2 Technical Topics > Track / Autocross / Dragstrip > Max rubber on the M2?
      02-15-2018, 01:52 PM   #23
arudeone
I have a set of Apex FL5s shipping shortly...the new configuration they added with 9.5 and 10.5. I'm going with Pirelli slicks, 265/645/18 and 285/645/18.
I'll report back after some track time in March and April.
@ZM2, maybe I'll see you out there...first outing will likely be Audi Club at Summit March 18.
      02-15-2018, 02:20 PM   #24
ZM2
Drives: 2017 LBB M2
Nice, let us know how they work. Unfortunately, I can’t make that date, but I’m guessing we’ll bump into each other sooner than later!
      02-21-2018, 03:28 AM   #25
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Originally Posted by DrKevM5 View Post
245s in front
Looks good with 245/295 - why didn't you go wider at the front ?
How's the balance with only wider 295 rears ?
What suspension mods have done to yr LBB car ?
Current '22 X3M LCI..
      03-02-2018, 08:47 PM   #26
adc
Drives: 2018 F80 M3 ED
Has anyone tried what us M3 owners run? Nitto NT01 275 fronts on an 18”x10” or 10.5” rim ET25, 305 rears on 18”x11” or 10.5” et44.
ZM2 you’re welcome to stop by my house and try it on.
I have an ulterior motive, I’m on the list for an M2 Competition...
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      03-02-2018, 09:02 PM   #27
ZM2
Drives: 2017 LBB M2
Hah, I might have to take you up on that. Based on my research the 275 front on an 18x10 is too large without adding more camber than what is really needed.
Below is my latest list. It looks like 19s are the way to go for a staggered setup on the M2. I also added an interesting 18/19 mixed setup.
18x9.5
265/35 Square – RE-71R, R888R, PSC2, Trofeo R
275/35 Square – R7 (tight squeeze)
19x9.5 & 19x10.5
265/30 & 295/30 – R888R, Trofeo R
265/30 & 305/30 – PSC2 (no longer made in 295/30)
18x9.5 & 19x10.5
265/35/18 & 305/30/19 – RE-71R
BAN_M2C4180.00
      03-03-2018, 03:15 PM   #28
arudeone
I had looked into those wheels, as a friend of mine with an M3 offered them to me...the feedback was it was "very aggressive" and it would require fender rolling and trimming of the inside liner.
I went with the new Apex FL5, 9.5 et28 and 10.5 et40 instead. I may try the Nittos in those sizes when I burn through my current tires. That was a recommended fitment.
      03-03-2018, 05:23 PM   #29
adc
Sounds like a plan. Especially with the S55 (and M4 CS tune?) in the car, running 305 in the rear might be a very good idea.
I got superb, incredible even and long wear on the rear 305 tires in my M3: 8 weekends. Didn’t even take good care of them in the winter, which I heard helps.
On the M3 the magical setup would be 305 square. Should be possible with correct offset, lowering, and camber.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      03-07-2018, 10:49 AM   #30
M3 Adjuster
Albania
7906
Originally Posted by macdude357 View Post
Originally Posted by M3 Adjuster View Post
I found some photos. The new Tire is the Maxxis RC-1 in 275/35/18 and the worn tire is the BF Goodrich G Force R-1 in 285/30/18.
The tires in that photo can't be an 275/35/18 RC1. Those tires run very wide. I have a set in my garage that that I just double checked and the tread width alone is 10.5 inches. Section width is 11.3 inches.
Any questions ??:bs:
omasou2088.00
      03-07-2018, 11:00 AM   #31
M3 Adjuster
Albania
7906
ZM2 youÂ’re welcome to stop by my house and try it on.
I have an ulterior motive, IÂ’m on the list for an M2 Competition...
I highly recommend you guys set this up. It doesn't take but 45 minutes and a floor jack and an impact to swap tires and wheels.
Even a test fit in the driveway is a great start.
      03-09-2018, 10:48 AM   #32
macdude357
macdude357's Avatar
467
Drives: IB E90 M3
Hmm, I'm baffled. Maybe it's the angle of the camera but Maxxis lists the section width on those tires at 11.3 inches.
      03-09-2018, 11:12 AM   #33
adc
I’m game!
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      03-09-2018, 12:02 PM   #34
M3 Adjuster
Albania
7906
That was kinda the point of the photos I took.
Tires are like tennis shoes and racing helmets . A Nike size 10 may fit differently than a Reebok 10 than a Skechers 10. It's imperative that you try them on for size.
One can make inferences from tire to tire when staying within the brand, because presumably they are all measured the same. However it's clear that tire measurements from say, hankook , aren't done the same as Goodyear or Bridgestone etc.
The shape of the sidewall of the tire also makes a difference.
I've actually fit a 285/35. Hankook RS3 on my 1M but the shape of the tire sidewall caused rubbing on the inside strut , not the width of the tread.
Treadwear ratings ... despite the name the Uniform Tire Quality Grading, ( commonly abbreviated as UTQG) are another boondoggle.
Many manufacturers have tweaked these ratings to either compete with other tires in a certain class or in some situations they have simply created a cheater tire for competition.. once again.. comparisons within a brand may be possible.. but assuming that a tire rated at 400 will last much longer than a different manufacturers 300 treadwear rating may lead to surprise.
Tire Rack even has a web page dedicated to this.
https://www.tirerack.com/tires/tiret...jsp?techid=48&
      03-09-2018, 04:21 PM   #35
dvas
dvas's Avatar
518
I'm going with a square Nitto NT01 fitment this year. 275/35-18 on Apex SM-10 10" wheels, but I went with a 33 offset to not need any rolling of my M2's beautiful fenders. It does, however, require a 12mm spacer in the front, per Apex. Also, car is lowered on Bilsteins and has GC camber plates.
I have the wheels already, just need to order and mount the tires. I can report back in a few weeks once I get and test the system out.
      03-09-2018, 04:59 PM   #36
ZM2
Drives: 2017 LBB M2
These and the M3 setup will fit statically. The rubbing and clearance issues arise on track under compression. I am a believer that this setup will work, but it will be very car specific (ride height, camber, offset, exact tire dimensions, etc) and likely take some dialing in over a few track outings. So, I’m very interested in hearing your feedback!
For now, I’m going the other way:
19x9.5 ET33 (with 5mm spacer) & 19x10.5 ET45 with 265/30 & 295/30 – Trofeo R
Work has me busy this year, so no track time til April/May. Test fit in a few weeks and will report back.
BAN_M2C4180.00
dvas518.00
      03-09-2018, 05:26 PM   #37
arudeone
These and the M3 setup will fit statically. The rubbing and clearance issues arise on track under compression. I am a believer that this setup will work, but it will be very car specific (ride height, camber, offset, exact tire dimensions, etc) and likely take some dialing in over a few track outings. So, IÂ’m very interested in hearing your feedback!
For now, IÂ’m going the other way:
If you can make April 9/10, Audi Club has a fantastic event at VIR. All day, open track...Mike Levitas and Randy Pobst running some classes and available for rides and tips. My favorite event of the year. Great time to test things out...
ZM22810.50
      03-09-2018, 05:28 PM   #38
ZM2
Drives: 2017 LBB M2
Now that sounds incredible! I’ll take a look and let you know. Thanks for the heads up.
      03-09-2018, 10:41 PM   #39
macdude357
macdude357's Avatar
467
Drives: IB E90 M3
OK, I see what is going on. When I saw your post, I went out and measured my RC1's and the the tread width is indeed 10.5 and the section width is ~ 11.3. So I wasn't sure why your photo showed them to be more like 10. I then took my own photo and realized that because of how close I held the camera to the tire, the tape measure actually is off by about 1/2".
My apologies.
      03-10-2018, 01:21 AM   #40
M2C_PLUS
M2C_PLUS's Avatar
1774
Drives: BMW 1M
2020 BMW M2 Comp  [0.00]
2020 BMW X3M Comp  [0.00]
2011 BMW 1M  [0.00]
245s in front
Do you mind telling me what tyres youbare running on the reads? They look better then the “stretched” standard pilot sports!
Cheers
      03-10-2018, 07:51 AM   #41
M2C_PLUS
M2C_PLUS's Avatar
1774
Drives: BMW 1M
2011 BMW 1M  [0.00]
I've been running 295s on the stock rear rims for over a year. No rubbing.
Is the 295 tyre 30 or 35 profile?
Thanks
      03-10-2018, 09:08 AM   #42
M3 Adjuster
Albania
7906
My apologies.
No worries.
They are mounted on the same wheels as I have eight 18x 10 wheels.
In my garage with 4 wheels and tires of each brand stacked up next to each other that .5" x 4 = 2 inches taller for one stack. That was what set me off on finding out if it wasn't an optical illusion.
But wait there is more. It's hard to see in 2-D photos but since you have the tires , look at the sidewall of the Maxxis. It's sort of rounded and the tread contact patch doesn't really make it to the edge.
In comparison , the Bridgestone tire shoulder is squared off making it so that tread goes ALL the way to the edge of the tire. This is part of why I took the photos of them laying down next to each other.
The width of tread that actually makes contact with the ground on the Maxxis is actually less due to the shape of the tire... indeed making the section width much greater than the tread.
At any rate .. whether it's .5" wider or .75" wider contact patch per corner ... the clear thing is that you are getting a LOT more rubber to the ground with the Bridgestone R1 than the Maxxis. That's hella important when trying to avoid wheelspin at the rear and also with trying to avoid having the tire roll over on the front when cornering.
The Maxxis have been hard for me to kill but when I do I will go to Bridgestone RE on one set for Autocross and driving to track and the BFG R1 as my track set.
      03-10-2018, 12:00 PM   #43
DrKevM5
DrKevM5's Avatar
Drives: G05 X5, F87 M2
Thanks
295/30-19
M2C_PLUS1774.00
      03-10-2018, 12:08 PM   #44
M2C_PLUS
M2C_PLUS's Avatar
1774
Drives: BMW 1M
2011 BMW 1M  [0.00]
295/30-19
