M2 Technical Topics > Track / Autocross / Dragstrip > Brake Pads Recommendation for TRACK use
      05-03-2018, 10:07 AM   #23
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
I use HAWK DTC 70 for slicks and DTC60 for NT01. They have really high heat ranges, good modulation and pedal feel, just enough initial bite and are a great value. I get about 8-10 days.
      05-04-2018, 05:59 PM   #24
bartman32
bartman32's Avatar
Drives: F87 M2
2017 M2  [0.00]
Originally Posted by kaosHunter View Post
My experience with the OEM pads is they overheat and drop uneven pad deposits on the disk causing shuddering. This only gets worse overtime and eventually a new disk is needed.
+1 - Did Buttonwillow without a problem but took it to Laguna Seca (Hard on brakes anyway) and torched the pads and rotors with overheating and uneven pad deposits. LOTS of shuddering. 6K miles and new pads/rotors!
      05-06-2018, 07:23 AM   #25
M2guru
2018 BMW M2  [10.00]
YMMV but just to throw my experience in this thread...I too had stock pads/rotors and after an event I got the shuddering and deposits that others speak of, but that went away after <1,000miles of driving.
      06-07-2021, 02:45 PM   #26
10011012
Drives: 2017 M2 Alpine White MT
Hawk HP?
Anyone run Hawk HPs?
Got deposits yesterday at Calabogie with the stock pads. Are they aggressive enough to clean the rotors? I use the car only for summer fun (i.e., spirited drives and track) so not too worried about noise, stop and go, winter, etc.
They're available through my favourite shop and cheap, so I thought I'd ask before going with the Pagids...
Cheers!
      06-09-2021, 10:06 AM   #27
Dean_Clevername
I was talked out of the HPS by someone who knows a lot about this stuff. Said they are harder on rotors than other equivalent pads. I was never impressed with my HP Plus for Autox use, so I wasn't in a hurry to try HPS any how.
The m2 is heavy enough that I think a dedicated track pad is worthwhile. I find the stock pads to be inadequate on track. Swapped to Ferodo DS1.11 and AP R4 fluid and was really happy. But I would not use those pads on the street other than to/from the track. You might want to look at DS2500. Better than stock, but not a full track pad that will need heat to work. I found the DC2500 to work great year round even at 25-30deg F track cross events.
Regardless, you should clear the pad deposits before you swap to another pad. Essex has some great videos on this. Basically you need to nearly do a bedding procedure, but not allow the pads to come up to temp to the point of leaving a new transfer layer. Essentially you just want to scrape the old layer/deposits off. Then you can swap to new pads and bed those in. You can even use that procedure to clean and then re-bed your brakes with a fresh transfer layer before events or if they develop a judder from unevenness in the existing transfer layer.
https://www.essexparts.com/support/learning-center--faq
bentom2335.50
      06-09-2021, 04:22 PM   #28
iWayne
///M2
iWayne's Avatar
Drives: M2C
I ran pagid RS29Ls/Castrol SRF fluid on the stock M2C brakes and they felt good. Only issue was pad knock back, especially after chicanes that required a quick tap before really getting on the brakes for full power. Annoying...
      06-09-2021, 05:36 PM   #29
DrKevM5
DrKevM5's Avatar
Drives: G05 X5, F87 M2
Pagid RS29s. Hard to source right now, but they stop like the hand of God.
      06-12-2021, 11:29 PM   #30
aw1473
Drives: Acura ITR
Are people having the same issues with stock pads and the 2NH / M2C brake setup?
Also, are most people running stock pads on the rear?
Thanks
      06-13-2021, 10:39 AM   #31
NISFAN
NISFAN's Avatar
3489
Thanks
Always a bad idea to mix pads unless you know what you are doing and need to correct a particular problem. Dedicated track pads have higher COF and also COF temperature curves.
      06-13-2021, 12:01 PM   #32
tux2005
234
Drives: 2017 M2
And temp curves for the rear brakes will be really critical if you're not running with TC fully off.
      06-14-2021, 05:14 PM   #33
RSXDC5
RSXDC5's Avatar
707
Drives: M3
You need the EBC RP-X race pad. High coefficient of friction, very high temp range, no squealing, slow wear rate, nice on rotors. Pairs VERY well with Girodisc 2-piece rotors
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs
      06-15-2021, 02:02 PM   #34
richard in NC
Drives: 2009 Z4 35i
I did the Ferodo DS 2500 pads front and rear. Expensive but worked well at Barber. Also decent on street and no more noise than stock pads.
Although the real test will be Carolina Motorsport Park, which is hard on brakes.
2020 X3M non-comp, Alpine White over black : Exec Pkg, ventilated M Sport seats, 20"s
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims
Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i
      06-15-2021, 03:22 PM   #35
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro SS 1LE
Have you tried DTC60s with a 200ish thread wear tire?
Thinking about using DTC60s with 285/305 Goodyear F1 Supercar 3 tires. (on a Camaro 1LE)
2017 BMW M2 German Spec
6MT, Driver's Package
--> SOLD
2018 Camaro SS 1LE. Because race car!
"Redline a day keeps the mechanics away"
      06-17-2021, 08:07 PM   #36
Fabb
Fabb's Avatar
Drives: 2019 M2C SO
I recommend against using DS2500 for brake heavy track. I melt half of my pad material after one day at laguna and it was getting really soft when heated.
Try DS1.11 or some more aggressive pads for track duty.
IG: M2C_SO
      06-17-2021, 08:16 PM   #37
Fabb
Fabb's Avatar
Drives: 2019 M2C SO
I had good experience with DS1.11 but they were too expensive to run. I recently switched to Gloc R18 and R12 combo and had very good experience on my laguna seca track day (very brake heavy track).
IG: M2C_SO
      06-17-2021, 08:40 PM   #38
5.M0NSTER
5.M0NSTER's Avatar
Gloc/Carbotechs are good. They don't leave uneven deposits, and have great fade resistance. But at least the R12 disappears in 4 track days when up front. Never used the 18. Curious how long they last for you.
--> SOLD
      06-17-2021, 09:52 PM   #39
ABenLauda
ABenLauda's Avatar
Drives: 2020 M4 CS
PFC11.
[SOLD] 2020 ///M4 CS
5.M0NSTER3353.50
tsk941522.00
      06-18-2021, 08:42 AM   #40
SEAT TIME RULES
SEAT TIME RULES's Avatar
1103
2020 BMW M2C  [5.00]
Ferodo DS3.12's
Great feel, rotor friendly, and now my go to pad after running Carbotech's & Porterfield R4's for over 20 years. Stunning stopping power and linear thru the entire heat range...
I swap out to the 2500's for street use.
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
F87source7251.50
      06-19-2021, 03:53 AM   #41
Fabb
Fabb's Avatar
Drives: 2019 M2C SO
Will report back. Only one day from that set, but r18 is supposed to have better wear and high temperature band than r12. For half price of the ds1.11, they can last 4 days only and I'm still happy about it.
IG: M2C_SO
5.M0NSTER3353.50
      06-19-2021, 02:20 PM   #42
5.M0NSTER
5.M0NSTER's Avatar
I hear ya. I ran PFC 08 and was very happy with it. After 7 days they had 60% pad remaining. And the pad never faded, was very controllable and played nice when swapping to OEM pads. PFC 11 is also a good choice with higher bite.
That said I just ordered a set of Hawk DCT60 for the Camaro. Less that $500 a set, and supposed to last 6-8 days from what I hear.
--> SOLD
Fabb228.50
      06-19-2021, 08:59 PM   #43
Fabb
Fabb's Avatar
Drives: 2019 M2C SO
Unfortunate PFC never made anything for 2NH options. I have to work with limited choices on this one
IG: M2C_SO
5.M0NSTER3353.50
      06-19-2021, 11:12 PM   #44
F87source
F87source's Avatar
Drives: Bmw M2
Originally Posted by SEAT TIME RULES View Post
Ferodo DS3.12's
From what I hear those are really bitey because their coefficent of friction is so high, but yes they have fantastic linear performance throughout their heat range. It might not be the best for everyone because of how aggressive they are, so maybe a DS1.11 or DSUNO would be better, lower coefficent of friction so they don't bite as hard and offer better modulation - again good on rotors, and linear throughout their heat range.
But yeah I liked using Ferodo in the past too, really good stuff.
