M2 Technical Topics > Track / Autocross / Dragstrip > Heads up! TPMS disabled turning off DSC
      12-15-2021, 03:25 PM   #45
inTgr8r
inTgr8r's Avatar
2432
Drives: M2 Comp
For me, I think this is the best way to go.
I tried doing the TPMS reset when heading out and it didn't work for me.
I plan to run my track wheels w/o TPMS sensors and be done with the headache.
...I will miss having that data display though
      12-20-2021, 10:50 PM   #46
Robbyjai
Drives: BMW M2C
Originally Posted by Twt View Post
I was looking into coding and noticed that TPMS can be disabled ( #16), this might be the easiest way to track the car.....as for street use, I drove for 30 years without it and used my right foot and a tire gauge instead.
cant be .. i tried it. i ended up ripping the feckers out i hated them that much
      12-20-2021, 10:51 PM   #47
Robbyjai
Drives: BMW M2C
Originally Posted by kenneth View Post
Anyone knows what happens if we use wheels without TPMS sensors? Will the car throw a code and DSC cannot be turned off?
yes it can be done. i run track wheels and tires and ripped out the TPMS. You just need to code out the error its not a big issue. car runs fine
      01-13-2022, 10:52 AM   #48
Dean_Clevername
Originally Posted by blacksh33p View Post
Adding to this as well and can confirm my 18 LCI with track/winter wheels and no tpms sensors AND tpms NOT coded out work fine in all modes, just the annoying reminders present that TPMS malfunctioned.
What steering/throttle mapping does your 2018 default to with no TPMS? Comfort steering and comfort throttle? Assume it is running with no traction control 100% of the time and nothing changes if you try and through comfort, sport, etc
      01-13-2022, 12:51 PM   #49
blitzyo
Drives: 19' M2C
Is this a US only thing? Doesn't happen on my EU car.
      09-15-2022, 04:19 AM   #50
pal
pal's Avatar
433
Drives: Z4 M Coupe
Originally Posted by "intgr8r"
So, it would appear that 28psi is the threashold??
That seems right. Recently, I dropped to 27 on the out lap and it put the car into comfort (started with DSC Off) but when I came into hot pits that lap, psi was up to 28 and I was able to simply put the car back to DSC Off and get back on my merry way. Also found that the display reads 1'ish psi lower that what I was measuring with my physical gauge.
