08-03-2016, 04:54 AM | #222 |
Rep 1,644
08-03-2016, 05:11 AM | #223 | ||
Queen of Motorsports
235
Rep 282
Drives: BMW 2016 M2
Instagram @winterrogue_F87
Tai Winter Targaryen |
08-03-2016, 06:08 AM | #224 | |
Rep 310
Drives: 04A6 2.7T(DD), 16M2 BSM MT EP
I am affected by the recall. Confirmed with my dealer. I am on the list. Build date May 30. I have my car. With an M2 built before 5/12 any random diff noise might make me wonder if a bum diff is in my car! Hopefully BMW will be more transparent as to what has happened. Initially I was kind of pissed that the rear diff would need to be swapped by the dealer as opposed to the VPC. I kind of still would prefer VPC doing the swap. So I will probably not get a diff until all the hold vehicles at the ports get theirs! However I guess if there is any consolation at least I will get a replacement diff, probably later rather than sooner, and that will hopefully by then it will be a proper QC cleared diff and I will not have issues going forward. Then again it is a technology laden piece of hardware! BMW has not inspired much confidence with this episode at all! |
08-03-2016, 06:22 AM | #225 |
Rep 68
I wonder what will happen with my car. I've been told repeatedly both by my SA and BMW Genius that my car (MY17) which finished production on July 25 is not affected by the differential recall. I am scheduled for Performance Center Delivery in South Carolina on September 23 and have not yet been told it will be delayed...
08-03-2016, 06:37 AM | #226 | |
Rep 2,948
08-03-2016, 06:39 AM | #227 | |||
Rep 2,948
For example, they claimed 202 cars in North America, that number is up to 1,200+ now. Worldwide you don't even want to know... |
08-03-2016, 06:43 AM | #228 | |
2nd Asst to Dept Undersecretary
6704
Rep 1,298
Drives: People crazy
This space for rent.
08-03-2016, 06:53 AM | #229 | ||
3689
Rep 15,081
Drives: '16 M2, '23 GT4
IG: Trackinheels
08-03-2016, 06:57 AM | #230 | ||
7908
Rep 11,785
How can BMW inspire confidence in you when a supplier sends them a failed part ?? In truth, it seems like they held many parts, got new parts that were alleged to be good , and then the new parts *also* were bad. I wouldn't have a lot of confidence in that supplier... Do you ? So how are they to inspire confidence in *you* when they don't have any confidence in the part ? There is absolutely no reason to get all down in the mouth about BMW. By your account, I guess every person should be upset at any manufacturer that used a Takata airbag too ? |
4
08-03-2016, 07:13 AM | #231 | |
6704
Rep 1,298
So, the confidence would come from knowing that there is a definitive way to know that the ones "in the field" are indeed good. For example, something like "We had known issues with a supplier of a certain part in which some differentials were fabricated out of spec or used a sub-component out of spec based on where they were manufactured or on which line or which shift or using which Tier 2 supplier parts, etc. We know, based on lot codes, which ones were defective, so have recalled all of those." IN one way, the fact they found more bad ones in the new lot actually gives me more confidence. Clearly they stepped up the QC inspection. I would just like to know how or why they know which existing ones are good vs bad. Presumably, whatever it was that they used to determine bad ones already made would not have been repeated, so how did more bad ones get made? And, however the MORE bad ones got made, is that how the the ones previously presumed to "non-bad" got made? In THAT way, it is a little less confidence-inspiring.
Nine Lives602.00 |
08-03-2016, 07:25 AM | #232 | ||
7908
Rep 11,785
This stuff happens all the time. When I had an E30 M3, there were a ton of bad LASO water pumps. They were an OE supplier. The water pumps that were bad leaked * immediately * upon installation. For about 7 months, people kept finding these bad parts as they were so far into distribution. Some people got multiple bad pumps because the next one on the shelf also was bad. I've seen bad turbos for subarus, bad window switches for GMs, bad headlamps for Ford. We've all seen bad airbags now. It's a fair likelihood that the original vendor didn't acknowledge how many bad parts there were to BMW in the first place. Since the parts are delivered in a just in time format, it simply only makes sense that there likely are some vehicles that are in the wild that are affected and will have to come back. You would like to know which parts are good and bad ? I bet BMW would like to know which parts are good and bad ! As far as knowing for sure which parts are good and bad, I suppose only the original vendor has the ability to even determine that. As mentioned already , more than likely it was a failure of a part that alerted anyone to the manufacturing error, and parts already down the line are already .. Down the line ! I'm not sure why it seems you are concluding that BMW immediately knew the depth of the problem ? |
08-03-2016, 07:58 AM | #233 | |
6704
Rep 1,298
08-03-2016, 08:51 AM | #234 | |
Rep 1,345
08-03-2016, 10:46 AM | #235 | |
Rep 310
i.e. is it a faulty clutch, bad servoelectronics a, excessive noise/friction, back lash maladjustment, an employee error (forgot to torque an internal part to spec), improper fluid fill .. etc which prompted them to do this. They must have something which alerted them to this either from the supplier or recognized on the line or post delivery. ... we all know why the airbags are being recalled... All we know here is that BMW stops delivery and wants to replace the diff. So we all wonder what is the issue with these diffs? No one has really had a problem on the road, maybe the "screechy pebble in wheel cover" noise? How easy is it for BMW to identify the bad diffs? maybe easily, maybe not! Certainly at some point they will have this corrected but it would be nice for them to say the problem is a, b, or c and this is what we are doing about it! Keeping everyone, including the dealers, in the dark is not ideal. Until then this lack of information is what creates speculation and I would guess even "unaffected" M2 owners may wonder about their diff. That is where the "confidence" issue comes up. I assume I will get a new diff, whether I truly need it or not, and by then I am confident BMW will make sure the diff I get will be proper. So for that I am grateful! |
M3 Adjuster7907.50 Nine Lives602.00 |
08-03-2016, 10:49 AM | #236 | |
Rep 310
08-03-2016, 10:58 AM | #237 | ||
7908
Rep 11,785
it's not the " screechy pebble in the rotor issue" That's a known issue since the E9X M3 and also on the 1M. Definitely annoying .. But somewhat easily resolved either by reversing and stomping on the brakes or by manually lifting up the deflector/backing plate on the rotor to free the pebble (caution- floor jack and removing the wheel and tire may be required) |
08-03-2016, 02:08 PM | #238 |
Rep 89
Knowing some M2s produced in May were affected made me check again with my dealer to see if there was something new.
Mine was produced 20th May and I am not in the list for the recall. Makes me happy at one point but seeing there is a new part number for the diff makes me wonder what changed on this part and if I would ever have any issues related with this. As others said, even unaffected owners are now concerned. I am indeed. |
08-03-2016, 02:58 PM | #239 |
Rep 181
Just spoke to a contact I have through my company at BMWNA. He told me he expects 4-6 weeks for my car which is scheduled to hit the VPC in Oxnard on Friday. He's working to get my VIN on a priority list but just wanted to give people a possible timeline who are in similar situations.
08-03-2016, 07:09 PM | #240 | |
Rep 310
I suspect you may be, or will eventually be, on the list. Even my dealer service consultant had no idea by VIN number and initially said no. Took him two days to confirm with BMWNA and that was solely by production build date. While he did confirm I would eventually hear from them and that the dealer would do my swap beyond that he was quite wishy washy. Very obvious he has no idea what was going on. Starts telling me about how a rear LSD diff works .... duh!!! I reminded him we were talking about an Active M Diff. He stopped talking. This is one of the reasons I would be more happy if the VPC would replace my diff and I told him that! I even offered to drive it to Newark (New York Port location of VPC) myself! So don't be surprised if you end up on the list. I am not sure BMW has published a list. (I do have a database of ALL M2's with production dates through July 4, 2016). You may want to push the dealer a bit! |
NachoM67.00 |
08-04-2016, 03:15 AM | #241 | |
Rep 89
Same old story. Every M car I've owned (3 now...) had an issue like this...
Nacho Martinez
Alpine White M2 |
08-04-2016, 04:00 AM | #242 | |
Rep 20
Yes BMW are fixing it under warranty and no doubt they will pass that cost on to their supplier (who wouldn't?!) but as a customer, whether loyal and long-standing or not, some sort of compensation or gesture of goodwill would go a long way. I am not suggesting an iPad or a watch by any means, that is not sensible. A small token like £50 off the next service is small but goes a long way in boosting confidence, especially when you've waited years for a car. I don't see how that is unreasonable. Those of us affected haven't just bought a pack of peanuts so a gesture of goodwill is, in my opinion, appropriate. Despite the above, I'd take a couple of "hundies" any day of the week but I don't have an ash tray
2016 F87 M2 | Long Beach Blue | 6MT
2103 E92 M3 Ltd 500 | Santorini Blue | DCT - Sold 2012 F21 125i M Sport | Mineral Grey | 6MT 2012 F21 M135i | Estoril Blue | 8AT 2008 E92 M3 | Azurite Black | DCT | |
