M2 Technical Topics > Suspension | Brakes | Chassis > Brake Rotor Question
      12-17-2023, 10:51 AM   #1
look585
look585's Avatar
312
Drives: M2CS
2020 BMW M2 CS  [10.00]
OK.
I have a CS red calipers.
Assuming that the fronts are 400mm. Ordered some Giros accordingly. It is advertised as using several color calipers including red.
The rears on the site are advertised as 400 mm as well. I thought they were 380mm?
Are the rears 400mm as well?
Thank you.
      12-17-2023, 02:34 PM   #2
medphysdave
medphysdave's Avatar
Drives: M2 CS | 85 of 592
Originally Posted by look585 View Post
OK.
Thank you.
Rears are not 400mm. I believe you are correct that they are 380.
      12-17-2023, 05:12 PM   #3
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Drives: OG M2 • Exige
Rears are definitely 380, and different from the blue brake front 380.
      12-17-2023, 05:27 PM   #4
look585
look585's Avatar
312
Drives: M2CS
Ok thanks guys I’ll call them tomorrow to clarify
      12-18-2023, 11:40 AM   #5
look585
look585's Avatar
312
Drives: M2CS
Didn’t doubt you guys as I’m replacing these for floating rotors
380 mm
Thanks again
      12-18-2023, 02:23 PM   #6
look585
look585's Avatar
312
Drives: M2CS
Can anyone confirm these are the correct part number Manufacturer Part Number
A2-220 for the rears
GiroDisc
      12-18-2023, 05:29 PM   #7
///MPhatic
The Seeker
///MPhatic's Avatar
13863
I always use Getbmwparts for the best prices and OE part numbers. Not sure about the GiroDisc number.
      12-20-2023, 04:36 PM   #8
look585
look585's Avatar
312
Drives: M2CS
Done
https://girodisc.com/bmw-f8x-m2-m3-m...m-rear-rotors/
BMW F8X M2, M3, M4 380mm Rear Rotors
SKU: A2-220
Other sites have it advertised as 400mm even though it's not.
Ordered.
      12-27-2023, 09:19 PM   #9
look585
look585's Avatar
312
Drives: M2CS
The rears on. The fronts coming.
Just getting her ready for the track.
Sorry about the pics.
      12-28-2023, 03:08 AM   #10
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
How did the bell look like on the inside? Is there a pressed in metal ring for the emergency brake like the OEM discs?
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87
///MPhatic13862.50
chris7197334.00
      12-28-2023, 08:56 AM   #11
///MPhatic
The Seeker
///MPhatic's Avatar
13863
It looks like you did a nice, clean job.
      12-29-2023, 07:30 AM   #12
look585
look585's Avatar
312
Drives: M2CS
No steel ring.
Thank you, it's appreciated.
      12-29-2023, 08:10 AM   #13
///MPhatic
The Seeker
///MPhatic's Avatar
13863
No steel ring.
How does the e-brake work?
      12-29-2023, 05:34 PM   #14
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
No steel ring.
Feels like the brake shoes will eat through the aluminium bell quite fast if there's no steel ring, no emergency brake turns for you mister.
      12-29-2023, 05:41 PM   #15
F87source
F87source's Avatar
Drives: Bmw M2
Really interesting how the girodisks don't have a rear bell for the emergency brake.
My 034 motorsport rotors had a separate steel bell that was removeable and replaceable if needed. It was held on via the lug bolts and rotor bolts.
look585312.00
      12-30-2023, 12:14 AM   #16
look585
look585's Avatar
312
Drives: M2CS
Regarding the steel ring. Whether the shoes are squeezing against steel or aluminum it really makes no difference. It's not like the shoes are doing anything to slow the car down like the rotors on a consistent basis.
It's the E-Brake, is either off or on.
Debate welcome.
      12-30-2023, 12:16 AM   #17
medphysdave
I don't think it matters as long as the hat is machined so there is contact. I agree with you. Not much wear going to happen unless you're using the brake frequently while driving.
      12-30-2023, 10:37 AM   #18
look585
look585's Avatar
312
Drives: M2CS
I'm thinking the steel is there for a reason. Maybe to stop the deformity of the alum hat. when the ebrake is applied.
I'll be sure not to apply after some hot laps
      01-06-2024, 01:52 PM   #19
HP Autosport
Drives: F80 M3
If anyone is interested in Girodisc or Paragon two-piece rotors, don't hesitate to reach out to us with any questions you might have or for quotes.
      01-14-2024, 12:51 PM   #20
M3SQRD
M3SQRD's Avatar
2161
Drives: E92 M3,G20 330ix,F22 240iX,F82
Coefficient of friction between steel on steel (assume metallic brake shoes) is 0.80.
Coefficient of friction between Aluminum and Steel is 0.61.
So the difference between an Aluminum and steel brake drum is you have to pull the handbrake farther to get the same parking brake holding torque. Deformation differences are negligible.
