11-15-2023, 09:45 AM | #1 |
Rep 12
Rear shock tower access from interior for coilover adjustment
I've searched the forum to no avail. Has anyone found a way to access the rear shock top mount so I can adjust the damping on the coilovers without unbolting the rear shock? I don't see any access after removing the trunk liner, so I imagine you would have to drill a hole. If so, does anyone know where to drill?
11-15-2023, 04:06 PM | #2 | |
4693
Rep 2,542
11-16-2023, 12:06 AM | #3 |
Rep 12
I have the ground control coilovers with the Koni double adjustable race shocks. I adjusted the rebound (on top of the shock, hidden in the shock tower) to the middle before I installed it but I would like to fine tune at the track without taking the whole thing apart. Compression adjustment is on the bottom and is easy.
11-16-2023, 04:39 PM | #4 |
Rep 1,336
Personally I would not be drilling a hole, since I’m assuming the size required would be massive.
Alternatively and not knowing much about the Koni DA’s the below post may provide some ideas if you are kinda handy in fabrication https://forum.miata.net/vb/showthread.php?t=770266
