M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > OFFICIAL Wheel/Tire Fitment Thread - What has already been done to your M2
      03-23-2020, 09:45 PM   #67
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Originally Posted by CompetitionChris View Post
Hi all,
Looking to test the waters on the following wheel specs
19x9.5 +33 F (stock tire size)
19x10 +25 R (stock tire size)
Not lowered yet but want to ensure that there is no rubbing issues before committing to coils. let me know what you think
Fronts will hit the strut without a spacer. I was running an effective offset of 25 with 9.5 wheels to clear.
      05-31-2020, 06:00 PM   #68
oncogene1
Drives: M2C
Is the sport cup 2 actually taller/bigger tire than the super sport for the same manufactured stated size? Thanks!!
Phil
      05-31-2020, 11:32 PM   #69
j0oftheworld
j0oftheworld's Avatar
109
Drives: 01 S2k, 20 M2C
Head to tirerack or the tire manufacturer website for accurate specs. Tire diameter and tread width are important factors to compare.
      06-22-2020, 11:12 AM   #70
KevM2
KevM2's Avatar
BMW M2 Competition  [0.00]
  [0.00]
Originally Posted by UltraMagneticAL View Post
https://docs.google.com/spreadsheets...it?usp=sharing
here's the google sheet. Should be able to filter the data to find what you need. this list will expand once people enter more data in this thread.
Add me as an editor. I like the sheet. You gotta post your specs in the thread too and not just on the spreadsheet.
BBS fi-r 9.5x19 et 22 and 10.5x19 et35 with stock tires. I'm on kw v3 so rubbing is dependent on height. I've had to raise it up a bit because it would rub the front wheel wells on hard breaking and turn in at the track, but I've since fixed that.
How is it that with stock tires and 0.5 inch wider rims the tire side walls sit so perfectly flush with the rim?!!
      10-01-2020, 08:26 AM   #71
O8E92M3
Drives: 2017' F87 M2
I found a wheel setup on an M3 for sale.
I am wondering if they will fit on an F87 M2 with stock suspension.
20x9.5 ET18 265/30R20
20x11 ET37 295/30R20
Any idea? 🙏
Suggestions are appreciated
      10-01-2020, 08:48 AM   #72
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Just thought I would state for the record that what I had read over and over on this forum was absolutely true.
- M Performance suspension dropped to 595 front / 600 rear
- Stock 245/265 tires on stock sized wheels
- 12mm front / 10mm rear spacers
NO RUBBING and pretty well flush fitment.
Beyond that, the ride, like most everyone said, is actually better than stock.
Absolutely fantastic combination IMO, and would have loved if the car had come this way from the factory.
NOTE: Every single picture I take of this car shows the fitment differently. It has to do with where the sun is, and the shadow (from the front fender and rear quarter) on the tire.
      10-01-2020, 08:55 AM   #73
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Any idea? 🙏
The standard flush fitment on the M2 front is 19 x 9 +17. Your front wheel would be 5.3mm outside of that, and your tire is wider, so I think you'll poke at stock height, and rub on big dips.
The story is the same in the rear, you're 5.7mm outboard of standard flush, and the tire is much wider than stock, so my feelings are the same there.
Maybe someone with first hand experience with these sizes can give you better advice.
NOTE: You might very well get away with this wheel/tire combo if you drop the car, and also camber it to suit the fitment, OR if you leave it stock height and don't mind a bit of poke and don't drive it hard with passengers.
      10-01-2020, 12:43 PM   #74
O8E92M3
Any idea? 🙏
I have seen the below being recommended for M2.
I wonder how much difference will that difference in offset make
      10-01-2020, 12:49 PM   #75
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
20 x 9 +17 is flush for the front
20 x 10 +30 is flush for the rear
The specs you're saying are recommended are 3.3mm outboard of flush on the front, which isn't too bad. Camber can fix that easily.
The rear recommended specs are .3mm less than flush, so in other words, spot on.
      10-01-2020, 01:06 PM   #76
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Let me explain it better this way.
These specs are flush for the front, 19's or 20's:
19 x 9 +17
19 x 9.5 +23
19 x 10 +30
These specs are flush for the rear, 19's or 20's:
19 x 10 +30
19 x 10.5 +36
19 x 11 +43
The only difference is the tires. When you go to 20's, because of the way they fit, you can usually fit a bit wider tire. So if a 285 is an easy fit on a 19, a 295 is usually an easy fit on a 20. And this is simply down to the smaller sidewall and how it's stretched over the wheel.
      01-24-2022, 02:23 PM   #77
AAW187
Bahrain
19 x 9 +17
19 x 9.5 +23
19 x 10 +30
19 x 10 +30
19 x 10.5 +36
19 x 11 +43
Hello,
Im thinking of doing the following setup and want some help to make sure the front and rear offsets match to achieve a flushed look.
BC forged HCA383S 2 piece wheel
19x9.5 et22 with 265/30/19 front
19x11 et40 with 295/30/19 rear
Im going to lower the car on Ohlins R&T coilovers.
Your feedback is highly appreciated guys, thank you !
      01-24-2022, 08:10 PM   #78
DriftKr6l
Drives: 2020 BMW M2 Comp
Good stuff. Sub'ed
      02-09-2022, 03:15 PM   #79
Rundskop
Rundskop's Avatar
148
Drives: 2020 BSM 6MT M2C
2020 M2C  [0.00]
19 x 9 +17
19 x 9.5 +23
19 x 10 +30
19 x 10 +30
19 x 10.5 +36
19 x 11 +43
Hello,
That is basically a perfect spec for both.
9.5 +22 should clear almost any suspension at any height with a 265/30
The rear will be close but will also work.
You will need to add a little camber front and rear. I doubt more than -2 is needed for either.
      02-09-2022, 03:42 PM   #80
Carrera2RS
203
I am running 9.5 et22 and 10.5 et 40 with stock tyres. I intend to move to 255/275
