11-30-2022, 10:41 PM | #45 |
Rep 1,243
Drives: 2017 Big Turbo BMW M2
I was told no. it really only helps if your pushing lot of power with high boost, which basically involves ethanol. stock injectors worked fine for me all the way to 550-590whp range. anything above basically has been giving me spark issues. it probably wouldn't hurt though and probably lasts longer.
12-08-2022, 06:37 AM | #46 |
Rep 2,515
How does this kit compare with the Precision Raceworks ignition kit?
12-08-2022, 02:04 PM | #47 |
Rep 7,470
DrKevM52277.50 shaneguags1196.00 |
03-22-2023, 12:40 PM | #48 |
Rep 1,243
so I installed the B58 coil conversion kit and the shop started with 0.025 gapping on the new B58 spark plugs but said it kept misfiring on my kill map. he then said he had to bring it back down to 0.020. this was on E60 making 653whp and 609lb-ft
03-22-2023, 12:47 PM | #50 |
Rep 1,243
03-22-2023, 01:25 PM | #52 |
@lbb_kev
494
Rep 516
We found that if you're using B58 plugs you have to keep the OEM boot on the b58 coilpack. If using N55/S55 plugs then you can use the boots that come with the Nexsys kit.
03-22-2023, 03:31 PM | #53 | |
Rep 7,470
Btw did your shop use anti seize on the plugs? |
03-23-2023, 07:19 AM | #54 |
Rep 1,243
yea we started with 0.025 and then my tuner and shop agreed to drop to 0.020. this is what my tuner said. and I’m assuming they used anti seize when installing but I didn’t ask
03-23-2023, 07:20 AM | #55 |
Rep 1,243
the shop did not mention any of that. I’m assuming that’s what they did though ? what does the diffence in the boot do ?
03-23-2023, 09:10 AM | #56 |
@lbb_kev
494
Rep 516
Doesn't hurt to ask. The tip of the plug makes better contact with the coil.
03-23-2023, 11:11 AM | #57 |
Rep 1,243
ah okay, I mean they didn’t leave anything in the box with the old spark plugs and coils I had so I’m assuming they used the extended one. plus, I think I’m switching to a new shop due to overcharged pricing so I rather not contact them now to be honest lol
03-23-2023, 02:31 PM | #58 | |
Rep 7,470
Your tuner knows best, if the car needs to be gapped down it needs to be gapped down. Just make sure the mechanical side is correct so he's not confusing other factors for spark blow out. |
03-25-2023, 10:22 PM | #59 |
Rep 1,243
well considering we have been through 3 different plugs with no burn out, I’m assuming he did it correctly
03-25-2023, 10:24 PM | #60 |
Rep 1,243
car has been running really good with no misfires so I doubt he installed it wrong
03-25-2023, 10:34 PM | #61 |
Rep 7,470
In that case you need to gap down, its a valid possibility. I just never expected it to be at only 600 whp, since S55's push far more before needing to gap down. Especially on the B58 coils which are significantly more powerful than stock coils, and even more powerful than the precision racewerks stuff.
03-26-2023, 02:33 AM | #62 | |
Rep 1,243
03-26-2023, 02:50 AM | #63 | |
Rep 7,470
But 650 whp for 0.020" on coils that are multiple times more powerful than stock vs. an s55 which makes 700 whp+ on 0.018" gap with stock coils. So this leaves me wondering if there could be a setup issue, since the goal with more powerful coils is to not run these miniscule gaps. But if everything is going well then it is fine, your tuner knows best. It just good he's not starting small, he went down as needed. |
shaneguags1196.00 |
