05-15-2018, 08:13 PM | #1 |
2018 BMW M2
230
Rep 149
Drives: 2018 BMW M2 - Widebody
Question about downpipe and tuning
Hey guys, I was wondering, would I be able to get a downpipe in July/August and not tune it until March/April? Would this affect my car at all?
Or should I wait till I'm ready for a tune? EDIT: The downpipe is the fabspeed Sport Cat Downpipe (catted obv), and also the Muffler Bypass by Fabspeed
LLB Widebodied ///M2
Ordered 5/6/18(112) | Production Started 5/16/18(150) | Production Ended 5/28/19(155) | Transport to PoD 6/1/18 | On Boat to US 6/11/18 | Arrived in US 6/28/18 | Pickup on 7/3/18 My M2 Build Instagram: Ryder.m2 |
05-15-2018, 10:49 PM | #2 |
Rep 2,577
Short answer: no negatives other than emission none compliance which you may or may not care.
Long answer: short term trim will be adapting until long term one settle. You will have significantly louder exhaust note and improved turbo spool up for increased toque at low down and a bit mid range as well. At top end DME will adjust to pre set air filling to maintain peak output, so no power gained there. Last word - down pipe power gain on stock tune is massively exaggerated by vendor. Even on flash it doesn't yield you a delta anywhere close to these claims, provided you're not modding crazily enough. Good luck!
Lemania 2320
Dav3948.50 |
05-16-2018, 02:58 AM | #3 | |
Rep 660
05-16-2018, 03:19 AM | #4 | |
enthusiasm > practicality
4021
Rep 2,247
Drives: 987 CS | G35x
Keep in mind, you're running 91 CA fuel so the gains won't be as dramatic.
05-16-2018, 05:33 AM | #5 |
Rep 1,644
Any gains from just a DP is a result of a small increase in airflow or decrease in pumping losses at a given rpm. A 3-5 g/s increase over the rpm range wouldn't be unheard of depending on how restrictive the stock one is. Its a bit of inexact science to relate airflow g/s and hp but generally more airflow = more fuel = more power combustion at a given point.
The other effects are quicker spooling of the turbo and lower EGTs. These factors allow for more aggressive tuning. I don't doubt the fabspeed graphs and I haven't looked at the details, but you have to take into account the ambient conditions between the two runs, as well as other factors in the DME such as: was it running max timing advance both runs? was overboost enabled on both? |
05-16-2018, 08:03 AM | #6 |
Rep 2,577
With all due respect, do not spread misinformation.
The 'air flow' as you mentioned is a pre turbo parameter measured by MAF sensor. Instead, our DME is really adjusting load by keeping MAP reading (measured post throttle) in check, which is completely irrelevant to turbo back design. To do that, wastegate, diverter valve and throttle plate are used at different times and different levels. DP makes power by 1) improving VE with lower back pressure, which with our platform is only noticeable when power goes way beyond stock, 2) early spooling up, so turbo makes boost or power earlier than it would without dp. When load target is hit (from 4k+rpm on stock tune) and DME starts to control power, DP isn't really helping, unless turbo couldn't achieve desired boost without DP, for example at elevation, or other kinds of bad condition. I will stop going deeper, English skill is my restriction
Lemania 2320
F87_LCI1787.00 |
05-16-2018, 08:21 PM | #7 | |
Rep 6,635
05-16-2018, 09:44 PM | #8 | |
Rep 2,577
The downside is the smell and emission which can be minimized by using HJS core, something I personally would and have done. At the end of day cost is 1k+ USD, for a little more you can do a STG1 turbo OMG...
Lemania 2320
///M TOWN16518.50 |
05-16-2018, 10:37 PM | #9 | |
Rep 6,635
05-17-2018, 02:17 AM | #10 |
Rep 2,197
have you got dynos to prove otherwise?
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
05-17-2018, 03:38 AM | #11 |
Rep 1,027
Do you really need dynos when the same vendors claim Hp/Tq increase with their own aftermarket Air Filters or Charge Pipes?
It's just marketing that takes advantage of buyer ignorance and the placebo effect This said, DP does indeed offer some benefits but the extent of the improvement to performance it provides is significantly tied to your other mods, primarily a flash tune/piggyback. |
05-17-2018, 09:21 AM | #12 | |
Rep 4,516
1st dyno stock 369/400 @ crank 2nd dyno DP upgrade stock tune 393/420 @ crank 3rd dyno more bolt ons stock tune 424/440 @ crank http://www.babybmw.net/forum/posting.php?mode=quote&f=86&p=1405241 |
05-17-2018, 09:59 AM | #13 | |
Rep 2,577
I knew that thread long back. I think you misinterpreted the results.
Their stock baseline was 308ps on E30, uncorrected. And with a little heat soak as they say because that's the last run without DP. On HJS 300 cell, the best they managed to get is 318ps, or a 10ps bump which is partially thanks to better IAT. This link works better http://www.babybmw.net/forum/viewtopic.php?t=84130 Quote:
Lemania 2320
05-17-2018, 10:47 AM | #14 |
General Moron
247
Rep 158
Couldn't agree more with the above post.
I've just got home from having an HJS 300 cell DP fitted and there was a VERY noticeable improvement in throttle response and power on the drive back. It just seems to rev out more freely. This is coming from someone who didn't expect much at all. |
M2C_PLUS1774.00 |
05-17-2018, 11:22 AM | #15 | |
General Moron
247
Rep 158
Although the exhaust noise was more subtle than I was expecting. Currently got the standard exhaust on there so a Milltek system may be next on the list. Last edited by Peasley; 05-17-2018 at 11:27 AM.. |
M2C_PLUS1774.00 nothingman522.00 |
05-17-2018, 06:20 PM | #16 | ||
Rep 4,516
This proves beyond doubt that m2 on stock tune responds well with the right combination of bolt ons...... BP
Current '22 X3M LCI.. Last edited by Bee Pee; 05-17-2018 at 06:26 PM.. |
05-17-2018, 10:09 PM | #17 | |
Rep 2,577
I'm speechless. Are you trying to tell us M2 gains 54hp crank power out of just full Bolt-Ons?
Have you ever doubt a bit its legitimacy? It's exactly threads and people like these that is why all the marketing hypes have been going on and on. I can show you a delta of 30whp on same day same car dyno, with no modification at all. What would that make you believe? I can imagine how true tuners laugh out loud reading thread like this. Why am I even responding like I have a dog in this debate...why have I been consistent sharing anything technical at all... Quote:
Lemania 2320
Dav3948.50 |
05-17-2018, 11:26 PM | #18 | |
Rep 2,197
05-18-2018, 12:04 AM | #19 | |
Rep 2,577
These days log is even a better tool to determine the power 'difference' than dyno sheet if you read and compare them many enough. Move on and just be happy with what you believe, as we all do in our life. All the best
Lemania 2320
05-18-2018, 12:10 AM | #20 | |
Rep 2,197
05-19-2018, 07:22 PM | #21 |
2018 BMW M2
230
Rep 149
So it's okay to do? Damn lots of people but it won't hurt me at all right with stock tune?
05-20-2018, 05:17 PM | #22 | |
Rep 1,644
Also, boost spikes can cause damage. It should be tuned out immediately. |
