05-17-2018, 05:01 PM | #23 |
Rep 780
It is certainly a different driving style. Remember driving a Lotus 30 years ago and besides being really quick you sat low and gearshift was way up there.
I pulled the armrest completely from my JCW. Was way better without. Thing is the Germans would love to get rid of the stick shift. So I figure these kind of details are unimportant to them
05-17-2018, 07:36 PM | #24 |
Rep 6
Sorry for making people notice this =).
I'm just biased because my track stripped Miata is kind perfect for driving after I gutted it =). Im 6'2 and I look like a clown crawling out of it but damn once your in... it fits like a glove and taking out the whole center console was the best day of my life for shifting! |
05-17-2018, 07:38 PM | #25 |
Rep 221
I was just thinking today how perfect the height of the M2 armrest is, I dislike the sliding however but that's just personal preference.
05-17-2018, 09:12 PM | #27 |
Rep 1,608
After following this thread awhile, I paid particular attention to my armrest as I drove to an event this evening. I have my seat pegged to its highest position with the electronic controls. Even so, my head is a couple of inches from any part of the roof, and Im 5'9" tall. The armrest at this height feels Perfect! Its where my arm naturally falls, and is in perfect position there to work the shifter.
As for the back and forth issue, the detente on mine is so stiff that the armrest doesnt budge unless I really try and move it off its stop.. So in general if BMW asked me, Id say the armrest is pretty damn near perfect (at least for those of us who like to see well over the hood and raise our seats high.)
Boostm3
randyt224.50 |
05-18-2018, 10:12 PM | #28 |
Rep 21
OK after trying the seat at all different heights I came to the conclusion that the armrest just doesn't work for me. Instead of driving around with it in the up position I just removed it today. I decided to make my own armrest/cover at a lower/thinner height .... and it won't slide around on its own either. So I made a pattern cut some wood and shaped some foam on top of it. The next step is to find some matching leather or alcantara and blue thread for stitching. But even unfinished it is SO MUCH BETTER for normal driving and shifting!
thegrinchboy56.00 |
05-19-2018, 12:53 AM | #30 | |
Rep 1,459
10-07-2018, 08:28 AM | #31 |
Rep 553
Well I ended up finding a 2nd hand F22 (RHD) armrest on eBay, pulled it apart and used the base piece for my modified armrest which is approx 45mm lower than the oem unit. Used the F22 dakota leather so it matches the seats & finish of the oem armrest minus the blue stitching, opens/closes identical to oem. I drive with the seat in lowest position and now my elbow barely touches the armrest during shifts, previously I had to push my elbow to the passenger side edge of the armrest so it wouldn't drag on the armrest. I tried raising the seat but found the feeling of sitting 'on' rather than 'in' the car was a bigger compromise. I no longer drive the the armrest up
If anyone wants I can post photos/details of how I did the new armrest. |
8
larry.beck217.00 fryh1n4.00 DarthFader133.50 clee1982797.50 ebisu81078.00 Capt Canuck704.00 Jay Dakota1.50 iam2slow78.50 |
10-07-2018, 08:47 AM | #32 |
Rep 289
I tend to rest my elbow on mine, but really appreciate the creativity of your solution!
///M2 - 2018 LBB DCT
10-10-2018, 09:33 PM | #35 | |
Rep 6
I love you David, stealing your idea asap!
Did you reuse the mounting hardware? Quote:
10-12-2018, 08:03 AM | #36 |
Rep 553
I re-used the base which has the hinges and catch. I found it a little difficult separating the top & base pieces (obviously didn't want to break the plastic base), with the top slid forward I was able to get a large flat head screw driver in and pry apart the bearing sliding mechanism. I didn't want to risk trying this with the M2 armrest in case things went pear shaped and BMW AU wanting $600 for a replacement.
Once apart I used an angle grinder to remove all the 'raised' plastic (on the sides & back part) but this still leaves the middle part of the base recessed. For a flat surface to cover, using the top leather covered piece as a template I cut a piece of steel sheet (I used 1.6mm galvanised). Fixed 1/8th countersunk bolts to the steel sheet using 2 nuts p/bolt to ensure they never loosen, covered the steel with self adhesive felt (idea being to reduce the leather on top slipping and also to soften edges of the steel plate) then covered with the dakota leather which I tied underneath using polyester ribbon through the existing holes in the leather. At the end I shortened the bolts so I could use dome nuts to leave a clean finish on the underside of the base. Some photos of the process (I had already removed the riveted steel brackets from the base before I took the 1st photo). I'm reasonably certain it will wear no differently than the oem armrest. |
clee1982797.50 Capt Canuck704.00 |
10-15-2018, 09:42 PM | #37 |
Rep 21
Nice job David! I finished mine too awhile back, SO much better for me now. I used BMW Alcantara and blue stitch (even thought it doesn't show in the pic).
TheMagician86.50 David.m437.00 clee1982797.50 Kattanah137.50 ebisu81078.00 Capt Canuck704.00 thegrinchboy56.00 |
10-16-2018, 02:59 PM | #38 |
Rep 326
Heh I have the same problem! I elbow my wife when her arms is on the armrest all the time when I'm shifting....
08-03-2022, 10:41 PM | #39 | |
Rep 1
David.m437.00 |
08-05-2022, 01:23 AM | #40 | |
Rep 553
08-07-2022, 09:19 PM | #41 |
Rep 289
I’m 6’3 and like to keep the seat nearly to the top setting, which eliminates any kind of armrest issue. I know most people feel like the seat in this car doesn’t go LOW enough, but raising it allows me to comfortably extend my legs without being too far from the steering wheel. If I move the seat back, I’m reaching uncomfortably (and I can’t get the clutch down as aggressively as I’d like.) If I move it forward, my knees are above my waist.
Highly recommend giving it a shot for a week or two until you get used to it. I never feel like I’m riding too high at this point. |
