05-10-2018, 07:08 PM | #1 |
Rep 4,204
Tips on running BM3 E30 tune
Ok guys, those that are running the BM3 E30 tune. Any tips before I start? Clearing out the poor 93 & booster this weekend then flashing to E30 👌🏻..... Thanks Dzenan Becic
05-10-2018, 10:41 PM | #2 | |
IG @bmwF9xG80
3810
Rep 7,593
- Rinse ; Increase to E25 - Don't forget to log 0-100 or 30-100 to see everything is on track
60-130mph 6.5s X4M #HCP
05-11-2018, 06:59 PM | #3 |
Rep 102
Think its 3.3 gallons if i recall correctly. I put 3 gal and it didnt run well. I had to thin it down with 93 gas again after driving around some. I wasnt able to fine tune 100% as i think i went back to 93 stg 2 once i ran the tank down like 2 times. Bm3 had v4 and v5 and maybe v5.1 now so let me know what ver and how many gallons work for you as I'd like to try again
BTW - when on the bm3 wifi agent, are you only able to see latest OTS maps? Id like to go back to 93 stg 2 v4 with quieter cold start and only v5 shows up. I also noticed facebook mentioned the burbles slider was out, i have the latest agent update so not sure if im missing something |
05-11-2018, 08:15 PM | #4 | |
Rep 4,204
I am confused, so the right mix should be 3.3 gal but when you ran 3.0 it did not run well so you had to mix down more with 93? |
05-11-2018, 09:33 PM | #5 | ||
Rep 102
05-12-2018, 05:56 AM | #6 | |
Rep 4,204
05-12-2018, 06:14 AM | #7 | ||
Rep 1,348
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 |
FSociety3810.00 |
05-12-2018, 08:25 AM | #8 | |||
Rep 102
05-12-2018, 10:44 AM | #9 | |
IG @bmwF9xG80
3810
Rep 7,593
I am running E30 now and I worked my way up from E20 blend. IT cant tell you what amount to use because your tank size is different as long as you calculate up to 30% Blend You're adding 3.3gals to how many gals of gas ???
05-13-2018, 07:53 AM | #10 | ||
Rep 102
05-13-2018, 12:35 PM | #11 |
IG @bmwF9xG80
3810
Rep 7,593
Grab latest OTS version they released fueling adjustments
05-14-2018, 03:49 PM | #12 |
Rep 4,204
Its supposed to rain for the next few days but i just filled up with fresh 93 and 2 gal of E85 for a starting point By the calculator it should be E21 94.8 oct....
So here we go...bout to try out 2 gal of fun Last edited by horsepower_and_hounds; 05-14-2018 at 08:13 PM.. |
FSociety3810.00 |
05-15-2018, 06:45 AM | #13 |
Rep 2
Hello!
Here in germany i am able to get BP/Aral Ultimate 102RON/ROZ equal to 95 AKI Octane gas. Is it possible to run the BM3 E30 OTS Map with the 102/95 Oct gas? Is there a benefit instead of going with BM3 Stage2 93 Oct? Akra DP 300 Cell and Wagner Comp2 FMIC are already installed |
FSociety3810.00 |
05-16-2018, 01:40 PM | #14 | |
IG @bmwF9xG80
3810
Rep 7,593
10-06-2018, 02:32 AM | #15 | |
Rep 1,348
