M2 Technical Topics > Suspension | Brakes | Chassis > Retrofit M2 CS upgraded brakes
      04-18-2018, 05:39 PM   #1
Maniax
Maniax's Avatar
26
I’m wondering whether we can order the M2 CS big brakes and retrofit onto our M2.
It should be a like for like replacement right?
Bmw F87 M2 DCT
Ex-cars: Alfa Romeo 147 1.6TS manual
Ford Focus ST 2.5T manual
Bmw E90 325i auto
Bmw F20 M135i auto
gsrbri559.50
skiparock182.50
      04-18-2018, 10:01 PM   #2
F87 2018
2018 BMW M2  [0.00]
Bump. Also interested. As well as retrofitting the seats!
      04-19-2018, 12:52 AM   #3
GreyF87
HawaiiM2
GreyF87's Avatar
31
Drives: 2017 M2, 05 G35
me too....but the co$t....the hole in my pocket grows
MSR Intake, CTS IC, Fabspeed DP, FTP Charge Pipe,3d Design Guage Pod with Stack Guages.
      04-19-2018, 01:35 AM   #4
fullstack
338
Drives: around in circles.
...and if the seats can be retrofitted, does that mean the m4 zcp seats can be retrofitted as well?
      04-19-2018, 02:25 AM   #5
Yellowflash21
Slovenia
370
I'm sure that existing front breaks and calipers would be possible to retrofit on the back, while it would be required only to get the front ones from the CS.
      04-20-2018, 02:48 AM   #6
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Not sure about the F -> R calliper swap but rear discs/rotors are totally different to fronts. Rear disc bells incorporate a drum and shoe arrangement for the parking/hand brake.
Current '22 X3M LCI..
      04-20-2018, 03:01 AM   #7
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Given that F8x CCB can be retrofitted to M2 I see no reason why M2C 400/380 6p/4p sport brakes can't be retrofitted to M2.
For those of us who want to run 18" wheels [winter and track] its a no-no tho which is a shame. AFAIK, the only OE 6p/4p retrofit that is 18" wheel compatible is from Racing Brake 374/370 kit
http://f80.bimmerpost.com/forums/sho....php?t=1247681
      04-20-2018, 07:29 PM   #8
dc5s
Drives: m3
if i'm reading this correctly...
assuming the m2c 6/4 brake option uses the same front calipers as the m3/m4 ccb's, this kit will allow the optional front 6-piston m2c brake caliper to accommodate the non-upgraded rotors and the adapter bracket will change the position of the 6 piston front caliper to allow for fitment of 18" wheels? or are the RB rotors required as well?
      04-21-2018, 01:14 AM   #9
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Yes I believe so for F&R as F rotor is smaller and thicker than OEM and rear is just thicker - to suit oem 6p and 4p callipers.
      04-23-2018, 04:59 PM   #10
Franzino
Franzino's Avatar
Belgium
860
Drives: M2 MY17 / Alpine A110 MY19
Following this.....and I'm planning to do this mod the coming winter...
      03-04-2019, 12:42 PM   #11
M Fifty
844
Drives: M2 & 330CI
How are you getting on?
      03-04-2019, 02:38 PM   #12
Anthony1s
756
Drives: 2018 Mineral Grey M2
I'm too concerned with rocks getting caught between the caliper and wheel from the bigger brakes. Especially cause in winter here, the city covers our roads with gravel. I've seen a bunch of threads on the m3/m4 section of people's wheels getting destroyed and BMW won't replace them unless you have the wheel protection package. Otherwise, I would LOVE to have the CCB's. But brake ducting seems to do quite a good job for the stock brakes.
      03-10-2019, 01:27 PM   #13
M2C_PLUS
M2C_PLUS's Avatar
1774
Drives: BMW 1M
2020 BMW M2 Comp  [0.00]
2020 BMW X3M Comp  [0.00]
2011 BMW 1M  [0.00]
Buy gold M4 CCB Calipers and M2C big brake kit discs and they are a direct bolt on to a M2 and M2C.
One I prepared earlier....
M Fifty844.00
AndrewC198910931.00
      03-10-2019, 01:55 PM   #14
M Fifty
844
Drives: M2 & 330CI
GreatWhite - looks good. How does the price compare to buying the official retrofit? Or was this from a salvage?
      03-11-2019, 11:52 AM   #15
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
m50
page 4 of this thread - I summarised parts costs
https://f80.bimmerpost.com/forums/sh...104&page=4
BP
M Fifty844.00
      03-11-2019, 03:05 PM   #16
M Fifty
844
Drives: M2 & 330CI
Interesting bit of detective work.
Cotswold recently quoted £3421.26 for the official retrofit kit shown here:
https://www.realoem.com/bmw/enUS/sho...diagId=03_5003
      03-16-2019, 02:26 AM   #17
M2C_PLUS
M2C_PLUS's Avatar
1774
Drives: BMW 1M
2011 BMW 1M  [0.00]
Hello mate, missed this.
All parts brand new directly from BMW. Ot costs slightly more than the retrofit kit but not much. Gold calipers have titanium pistons too.
This upgrade was planned for my old LCI M2 but I ended up doing it on my M2C as you can see.
I used BMW F10 M5 Ferrodo DS2500 pads for the front and R35 GTR (same pad shape) Ferrodo DS2500 pads for the rear.
M Fifty844.00
      03-16-2019, 01:51 PM   #18
DOMs335D
221
Drives: 1991 318is; 2017 M2
1991 BMW 318is  [0.00]
2017 BMW M2  [0.00]
2011 BMW 335is  [0.00]
Before adding the M2C brake kit I would go with a set of AP Racing Brakes. I bet they will cost less and perform better.
      03-21-2019, 03:18 PM   #19
Mark 1M
Mark 1M's Avatar
349
I was speaking to my Local BMW dealer here in Scotland and they have ordered
Carbon Brakes front and rear for a BMW M2 Comp for a customer List is 4.5K they are doing a set for 3.5k to the customer that ordered them he said they should be with him April / June
      03-22-2019, 01:54 AM   #20
MR RIZK
MR RIZK's Avatar
758
Drives: AW M2C
Is that with rotors and pads? Just seems too affordable.
      04-18-2019, 07:59 AM   #21
jritt@essex
jritt@essex's Avatar
Drives: e90 335i, NSX, 997.2, 987.1
If you're going to spend $4,000+ on OEM brake parts, you should seriously consider one of our Essex Designed AP Racing Brake Kits instead.
Many people think they need to swap out all four corners, but we have lots of customers who run our front-only system. From a performance standpoint, you'd be far better off with our front kit mated to your standard M2 rear brakes vs. going all four corners with the N2H setup. You'd have far less unsprung weight, more fade resistance, more pad choice, be able to run 18" wheels (which are lighter and have less expensive 18" tires). Our Radi-CAL systems have the OEM setup beat on every performance measure.
Here's a recent M2 owner's review after spending some time with our system. He even says, "These completely outperform BMW M brakes in every single way. They consistently wow instructors at the track who have been in all kinds of cars and supercars.":
https://www.essexparts.com/news-blog...ving-technique
  • Our front kits are 24-26 lbs. lighter than the OEM 2NH brakes, and our rears are 12 lbs. lighter.
  • Our kit fits inside 18" wheels, allowing you to run lighter wheels and less expensive tires, with more tire compound options
  • Our 9668 front kit takes a 25mm thick pad, and you don't have to remove the caliper to change pads (the 2NH needs to be removed to change pads)
  • Our kits have a huge range of pad choice in all different types of material, whereas the 2NH calipers have a very limited range of options
  • Our kits integrate seamlessly with OEM master cylinder/ABS
  • Our discs are far lighter, will flow more air, last longer, and fit in many more wheels
Videos about our product features:
https://www.essexparts.com/essex-des...ion-brake-kits
You can see lots of customer reviews on our blog, including many from M2, M3, M4 owners.
Here's a blog post with pics and weight comparisons:
https://www.essexparts.com/news-blog...m2-competition
More owner reviews:
Front disc weight comparisons between the OEM N2H kit and our front 372mm disc systems:
Gigantic fixed caliper bridge that requires removal of caliper to change padds:
Our 9668 caliper doesn't even require tools to change pads...you just squeeze the spring clip!
Pads from our 9668 front kit:
MR_M2519.00
      04-24-2019, 04:19 PM   #22
swifty
Drives: F80, Levante & Tesla 100D
Ok Mister but do they come in GOLD???
sdjro27.00
