M2 Technical Topics > Suspension | Brakes | Chassis > Ohlins R&T (Lowered) and tire wheel setup
      02-05-2018, 10:49 AM   #1
alscks0414
alscks0414's Avatar
689
Drives: MY18 X3 M40i, MY18 M3 ZCP
Question Ohlins R&T (Lowered) and tire wheel setup
Hey guys,
I was thinking if my questions should go Wheel/Tire Thread or Suspension, but decided to come post here as I think it would be easier to find answer here.
I am currently shopping for Ohlins R&T and wish to get wheels and tire setup along with that coilover purchase.
Planning to have the spring rates lowered 15% to 80N/mm front and 160N/mm rear. And looking to buy Gold 763M wheels once gets released NA (which is exact same wheel spec as 437M). However wish to go 265/35/19 and 285/35/19 (or 255/35/19 and 275/35/19).
For those of who have Ohlins already and running with different tire sizes front and rear than the stock, would the setup run without having camber plate?? I am fine to go little higher than my plan if that solves the issue of rubbing.
And what is the largest size F/R with stock suspension + stock wheels without having negative camber?? (Sorry of my ignorance if this was covered already)
Thanks!
tth86105.50
      02-09-2018, 03:46 PM   #2
F87_LCI
F87_LCI's Avatar
1787
Drives: 2018 LBB F87
Might not be much help yet...but I am waiting for this RIDICULOUS winter to end so I can get my R&T installed - been sitting in the box in my basement for two months now!
I went with Vorsteiner 107's with 255 in front and 285 in rear. FWIW...The installer tells me I should be fine an no camber plates should be necessary. I guess it remains to be seen...
      02-09-2018, 04:29 PM   #3
alscks0414
alscks0414's Avatar
689
I went to ask for quote on S2 package of Dinan to Budds BMW yesterday and I was quoted with different goodies that I wish to go with.
Dinan coilover recommends;
Up to 1" of lowering in front and 1 1/2" of lowering in back are possible depending on tire clearance although 3/4" drop in front and a 1/2" drop in the rear is recommended to maintain a civilized ride.
Dinan Wheel and Tire package comes with Tire sizes 265/35/19F 285/35/19R. Wheels are 19X9.5F 19X10.5R and they do not have offset info on the website.
With lowering 1'' front, 1 1/2'' rear, Dinan do not install camber plates.
They said MPS4S and SS and Pirelli P Zero Corsa do all fit just find with tire sizes mentioned above.
Although spring diameter between Dinan Coilover and Ohlins R&T will differ, thinking that they all will fit with 265/35/19F 285/35/19R if lowered by the same inches front and back.
I am also waiting for this bad winter to be over.... I did not order the coilover yet since I am still debating between Dinan and Ohlins...
      03-22-2018, 03:29 PM   #4
F87_LCI
F87_LCI's Avatar
1787
Did you get your Ohlins installed? I'm reading that some have zero drop from stock? Can that be right?
Chi_ZCP30.00
      03-22-2018, 04:17 PM   #5
alscks0414
alscks0414's Avatar
689
No not yet. Currently looking to have it all installed 31st Sat of this Month.
Ohlins says if u go with their recommended preload and spring rate front and rear, that should give abt 10 mm drop from stock. I am going as Ohlins recommendation 90N/mm and 190N/mm front and rear for my setup. Believe u can also adjust height alone by dial of height adjustment feature. Easily seen from manual
      03-22-2018, 09:33 PM   #6
F87_LCI
F87_LCI's Avatar
1787
Going with same spec. Mine are being installed tomorrow, along with my new wheels and tires. Also getting alignment and corner balancing done. The shop I'm using does a lot of Ohlins installs and runs them (custom set up) on their track cars. They said they are the only brand they would use. I didn't buy the coilovers from them so I suppose they had no reason to "talk them up". The shop I bought the coilovers from is apparently doing a promo video shoot of the install for their social media so I hope to get a copy.
specka71.00
      03-22-2018, 10:04 PM   #7
alscks0414
alscks0414's Avatar
689
Where r u getting urs installed. I believe i bought ur Ohlins from Alpha Motorsport. R u using the one Alpha recommended or did u make ur choice?
Let me know how low ur vehicle gets compared to stock after the installation. Wish i can do the comparison with my install which is next Saturday.
      03-22-2018, 10:24 PM   #8
F87_LCI
F87_LCI's Avatar
1787
I bought them from JRP in Mississauga. Getting installed at Burning Rubber in Oakville on recco from JRP. I took before photos with a tape measure (cms and inches) and I will do same after and post the results. I'm expecting the drop to be about 1 cm, they told me it won't be a drastic drop.
      03-22-2018, 10:28 PM   #9
alscks0414
alscks0414's Avatar
689
That is great. I gotta ask the name of the shop that installs mine tomorrow
Keep me posted please!!
      03-23-2018, 08:18 AM   #10
S1monQc
Drives: '18 AW M2
I ordered my Ohlins (recommended specs 90/190 N/mm)+ GC plates at Alpha too. Should have them soon me thinks!!
I want a 25 mm / 1 inch drop myself. Should look mean af
Don't forget to post pics guys
      03-23-2018, 08:44 AM   #11
alscks0414
alscks0414's Avatar
689
I wish that I can lower as 1 inch as well.
But just worried about my front splitter... that could be easily damaged anytime if dropped to an inch.
Will try 10 mm as Ohlins recommendation haha and will see what happens after.
      03-23-2018, 09:02 AM   #12
S1monQc
Drives: '18 AW M2
But them style points bro!
Just have to be careful with sidewalks!!
      03-25-2018, 02:55 PM   #13
F87_LCI
F87_LCI's Avatar
1787
So got the Ohlins and my new wheels/tires installed Friday and drove around for a bit on them yesterday - only for my buddy to notice that the tires that were mounted were all seasons and not summer tires as I had requested - WTF?!?...I just didn't notice when I picked the car up as they were Michelin's. I'll have to get those swapped...I digress.
Anyway, I measured the ride height before and after and the car has been lowered about 14mm (I won't bother with inches as this is the Canadian forum). in the front and 20mm in the rear. Is it slammed/dumped? No it's not, but I don't care for that look anyway...and it's a great way to demo your $2,000 CF front splitter. Is the stance perfect FOR ME...not exactly...I'm hoping the car settles another 3-5mm as that would be perfect.
The M2 fitment for the Vorsteiner vff-107 is spot on. Those guys did a great job there. No spacers needed. Also no camber plates (for now).
From the limited driving I did, the suspension is...in a word...F'N awesome! Ok, that was two words. It is still firm, but the "chatter" that I felt with the stock suspension is gone. It is on the softest setting for daily driving and the spring rates are the Ohlins recommended. The installers at Burning Rubber in Oakville, did a great job and even did a corner balance and alignment. I can feel the difference as this new setup seems to "suck up" the bumps much better than stock. I haven't been able to push corners (also don't want to ruin the tires that I have to take back), so I can't comment there yet.
Quick picture:
Appreciate 4
AngryBaby344.50
JL189.00
S1monQc223.50
      03-25-2018, 08:10 PM   #14
alscks0414
alscks0414's Avatar
689
Quick picture:
[IMG]http://i1356.photobucket.com/albums/q724/the_hawke/New Kicks_zpsxhr42si0.jpg[/IMG]
Congratz!!
Getting mine done next Sat. Right after Good Friday. And the heights that u mentioned is basically what i hoped for. As i also have front splitter which will not be much prone to damage as ur Vorsteiner but dont want to spend another 1300.
Yes, VFF107 is absolute killer. I personally believe they are the best looking flow form that Vorsteiner offers. It was on my list as well but decided to go with different choice, but sweet Jesus, they look incredible!!
Will be posting my result as soon as i get around and will be sharing with u guys as well.
I am planning to get my corner balance right before track day with my Apex wheels and Toyos on them. Will be getting alignment but figure it is better to get the corner balance with the actual wheels and tires that i will be using in those sessions.
Well looking forward to see ur vehicle at some point. And wish i will not regret the fact that i did not go with VFF107... LoL
      03-25-2018, 09:16 PM   #15
look585
look585's Avatar
311
Drives: M2CS
2020 BMW M2 CS  [10.00]
Can you get spring rates on the Ohlins that are softer than stock?
      03-25-2018, 09:19 PM   #16
alscks0414
alscks0414's Avatar
689
Yes u can get different spring rates depending on ur preference.
I was told that the Ohlins recommendation on their coilover springs (90/190) is actually stiffer than stock but i have seen ppl going like 60/130 and so on and was told that it will become softer than the stock. And of course then there u can adjust the damping with simple click mechanism.
      03-25-2018, 09:28 PM   #17
S1monQc
Drives: '18 AW M2
Quick picture:
All seasons wtf lolll
      03-25-2018, 09:33 PM   #18
look585
look585's Avatar
311
Drives: M2CS
Thanks for the info.
      03-25-2018, 09:36 PM   #19
look585
look585's Avatar
311
Drives: M2CS
Forgot to ask. What are the stock suspension spring rates?
      03-25-2018, 10:07 PM   #20
alscks0414
alscks0414's Avatar
689
There is a thread talking abt stock spring rates but no one knows the exact number i believe
mfurse182.00
      03-26-2018, 12:25 PM   #21
Vorsteiner_Info
Vorsteiner_Info's Avatar
188
Drives: bmw
Quick picture:
Thank you for the kind words. Your M2 looks perfect.
      04-02-2018, 09:26 PM   #22
S1monQc
Drives: '18 AW M2
Any updates on these
alscks0414
F87_LCI
