05-15-2018, 10:01 AM | #23 | |
Rep 1,339
There should be many ppl with HAS kit, and surely some of them have done some track use. Maybe they can help you out better. FYI, OE shocks are known to be one of the parts of M2 that is not really designed to be abused with aggressive driving like using on track (at least by seeing my friends around me who tracks theirs often). I have couple of friends changed their shocks. One friend got new OE shocks only after 1 year, about 10 different track days which includes 5 of full 6 hours. Another one got KW V3 after 1 year of use as well but do not know he many times he made his day to the track. If you are planning to go change the springs anyways and also plan to go track/ autocross, I highly recommend to get aftermarket coilover (or MP coilover) with proper camber plates. |
Who?484.50 |
05-15-2018, 02:40 PM | #25 |
Rep 51
Rates
Hello All,
Have the same question as well, Don't have an M2 but bought a set of M2 DCT springs, to try out in a 2 series. The rear springs seem linear, so measured the rate installed in the car, (car on hoist with wheel on scale, and very slowly raise/lower and take measurement of wheel location) Being linear, droop and compression would be same rate. For the M2 DCT rear spring, I measured 268lbs/in wheel rate. The front, have not measured yet - as it is more involved to install than rear. However, I did use a similar calculator, and from my rough measurements N = 3.85, OD = 164mm l = 255mm wire = 14mm, E= steel ~ 11.25^6; I get approx 170 lbs/in. However the front springs are progressive it seems from coil windings; And using the hoist/scale method would only give the rate during droop not compression.. Cheers, |
05-15-2018, 03:50 PM | #26 |
Rep 51
H&R Springs
Had found some information on spring rates,
Seems the aftermarket springs makers have to make a certificate with specs. Germany's TUV certificate, For example for H&R it is on their website under service/product i.e. the 28802 product for M2 document, http://www.h-r.com/bin/28802.pdf From there and with the calculator you can get a ballpark estimate of drop and rate (assuming springs compresses linearly) Also, let's not forget influence on the spring rate of the rubber secondary spring..ie on a 235i seems 8mm of travel will start engaging rubber bumpstop. |
jetbill198.00 |
08-10-2018, 05:58 PM | #27 | ||
this is the way
18121
Rep 8,513
Did a little reverse math to figure out the stock spring rates. The Dinan HAS for the F87 states the following.
F87 Stock Suspension Spring Rate (Progressive) FRONT: 35 N/mm | 200 lbs/in REAR: 125 N/mm | 714 lbs/in Note: The Dinan springs are linear. |
12-15-2018, 06:36 PM | #28 | |||
Rep 883
M3/M4 front = 250 lb/in M3/M4 rear = 650 lb/in M2 front = 250 lb/in M2 rear = 750 lb/in (you are correct) Stock rates: M4 front = 169 lb/in M4 rear = 590 lb/in M2 front = 213 lb/in M2 rear = progressive 570-580 lb/in averaged
12-22-2018, 04:40 PM | #29 |
Rep 2,448
OP,
what did you end up going with?
Current Bimmer: '16 F80 M3, '20 F87 M2c Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40 Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335 |
