M2 Technical Topics > Suspension | Brakes | Chassis > DIY brake pad change
      09-03-2017, 01:00 PM   #23
M2 Belgium
Thanks :-) It was kind of fun actually. Not hard at all. Didn't apply copper grease for the simpel reason I didn't have any and I really wanted the pagids on for spa francorchamps tomorrow. Driven a few miles and yes the schreeching is quite loud but I will change them again for road use
      09-06-2017, 10:03 AM   #24
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Make sure you open your master cyl before you compress the pistons back into the caliper. I also use a digital caliper and measure my brake pad thickness and write it on the backing plate when taking pads out so I can keep an eye on my usage.
I tie up my sensors and don't put them in track pads.
I use a Lisle to compress the pistons, beats a wrench any day.
      09-06-2017, 11:54 PM   #25
OLO-M2
Belgium
38
How do you open the master cylinder ? Why ? First time I read such instruction...
And what is a lisle ?
      09-08-2017, 12:04 AM   #26
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
When you push back the pistons, the brake fluid has to go back to the reservoir. If there is an air bubble in the top of the reservoir (there normally is), you're fighting against that. It's easier to push back the pistons if you loosen the lid of the fluid reservoir.
Lisle part # 29100 is probably what Cosmos is referring to.
OLO-M237.50
      09-09-2017, 08:02 AM   #27
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
You can push the pistons back in with your fingers. Super easy to do. No tools necessary.
OLO-M237.50
      09-10-2017, 12:34 AM   #28
OLO-M2
Belgium
38
Is the reservoir sealed ? I thought that air could pass through the cap for that purpose
      09-10-2017, 12:35 AM   #29
OLO-M2
Belgium
38
That's also my experience!
      04-17-2018, 12:47 PM   #30
McPurrs
The deuce gets loose
290
Drives: '17 M2 BSM 6MT
Originally Posted by CommitConfirm View Post
Proof you say? RTM
You misspelled RTFM
      04-22-2018, 06:37 PM   #31
PackPride85
You guys have any issues swapping back and forth between stock/track pads on the same rotors? Wasn't sure if putting down an extra layer of deposits with the track pads would affect the rotors at all after putting the street pads back on.
      04-23-2018, 05:57 PM   #32
eeyang92
Drives: LBB M2 LCI 6MT
Curious as well.
My plan is to let the racepads scrape off the deposits on the way home from the track (when they're cool and abrasive) and swap the stock ones back on and then bed them in. Vice versa on the way to the track.
gsrbri559.50
      05-24-2018, 04:19 PM   #33
Tano
Tano's Avatar
Hungary
375
Today I swapped front pads back to factory because i think the front right pads wouldn't survive their 4th track day. The right pads are more worn than the left ones. See below.
All three tracks i've been on are clockwise direction, so i thought the left ones will get bigger stress but it's the opposite.
Do you think is it suitable to swap left-right pads between occasions? Will it cause any problems? It seems proper way to extend their lifetime.
gsrbri559.50
      05-26-2018, 01:47 PM   #34
gsrbri
gsrbri's Avatar
Drives: F87 6MT
I ditch my race pads as they get past 60% worn. Can't manage the heat well and it's semi-cheap insurance
