M2 Technical Topics > Suspension | Brakes | Chassis > Camber plates
      07-07-2017, 04:38 AM   #23
Twt
Twt's Avatar
634
Drives: 2017 M2
Originally Posted by Reid View Post
I recommend camber plates from Ground Control or waiting for the units from Vorshlag.
+1. GC plates are very well made, quiet, and give over -4 camber if wanted. I run -3.2 track/street and don't change. Changing between track and street requires more than just loosening the top bolts, plus it wacks out the front toe.
      02-24-2018, 06:36 PM   #24
cngo
Drives: BMW
MagnusT _pancho_ How are the Millway plates holding up? Any problems or noises to report?
      02-25-2018, 01:49 AM   #25
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Originally Posted by MagnusT View Post
Agree on that, the Millway M2 plates I have on my car are the same as their F2x plates.
M2 plates are different from f2x plates as bearing etc are re-sized to suit larger dia f8x damper rod.
Current '22 X3M LCI..
      02-25-2018, 11:31 AM   #26
MagnusT
MagnusT's Avatar
Sweden
538
No problems whatsoever for me.
      02-26-2018, 06:30 AM   #27
_pancho_
_pancho_'s Avatar
Sweden
16
Drives: modified F87 M2 Man -17
They work great, easy to adjust and feels full of quality and no noise. My car have only around 5000 Km on it though.
      03-02-2018, 10:00 PM   #28
GVN*2FLY
Drives: ‘16 GT4|‘22 X3MC
So my shop installed GC plates and maxed out at -2.75. What are my guys missing?
      03-05-2018, 10:42 AM   #29
alscks0414
alscks0414's Avatar
690
Drives: MY18 X3 M40i, MY18 M3 ZCP
Did you go with stock sus or aftermarket coilover? Camber max value could be different depending on the suspension that you had fitted with.
      03-05-2018, 01:12 PM   #30
GVN*2FLY
Good point - the answer is totally stock suspension.
      03-05-2018, 01:17 PM   #31
alscks0414
alscks0414's Avatar
690
Yeah GCs and all other adjustable camber plates are made by the order detail including the coilover suspension setup that one has. Not sure if they will bring max camber value for sure but they could. I have GC ordered to fit my Ohlins R&T and they can give 30 mm max camber i believe.
S1monQc223.50
      03-07-2018, 09:11 AM   #32
MagnusT
MagnusT's Avatar
Sweden
538
I'm at 38 000 km. No problems.
cngo56.00
Kankles1484.50
JTO245274.50
      04-27-2018, 10:17 AM   #33
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Pancho,
What front wheel spec and camber are you using with 265/35/18's tyres - any rubbing ?
TIA,
BP
      04-27-2018, 04:00 PM   #34
_pancho_
_pancho_'s Avatar
Sweden
16
Originally Posted by Bee Pee View Post
Pancho,
TIA,
BP
18x10 ET 33 and added a 10 mm spacer per side to make the wheel run free from the strut, no rubbing att all.
I have almost "full" negative camber, haven't done e measurement but it's around 3 degree.
      04-27-2018, 08:58 PM   #35
gsrbri
gsrbri's Avatar
Drives: F87 6MT
If you change the plate settings between street and track, no telling what your alignment (toe) is when switching to the mode you didn't align to. Plus, variations in toe will degrade tires quickly and also result in rear alignment variations. I'm driving Street and about 10 events/season and I am going to run -2.0 camber, up front, locked-in.
      04-28-2018, 06:14 AM   #36
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Good to know.
Running OE 437m, 245/35/19 mpss, MP coils with -2 upfront for street and track days.
NSF
OSF
Considering buying extra pair 10” et40mm wide rears to use up front cw 265/35 tyres
      04-29-2018, 02:00 PM   #37
_pancho_
_pancho_'s Avatar
Sweden
16
Yes today I noted that the inner side of front tires are quite worn, have been running this setup to much on the street when it's aligned for track
      04-29-2018, 03:36 PM   #38
MagnusT
MagnusT's Avatar
Sweden
538
You probably wrote it somewhere but how much toe do you have?
      04-30-2018, 04:56 AM   #39
_pancho_
_pancho_'s Avatar
Sweden
16
Magnus,
I haven't done a proper measurement.. need to do that.
      04-30-2018, 09:16 AM   #40
eatingpizzainthef87rules
-2.5 on my GC plates with tons of room, I believe they should easily reach -4 if it was required. 0 NVH or noise
      04-30-2018, 09:57 AM   #41
MagnusT
MagnusT's Avatar
Sweden
538
...inner side of front tires are quite worn...
...I haven't done a proper measurement...
3 degrees camber doesn't wear any extra if you have minimal toe.
      05-06-2018, 02:33 PM   #42
K9GunSlinger
Drives: 2016 M2 MG 6-Spd
For someone that doesn't track and just Dailys / Canyons once or twice a month..would camber plates still be recommended? its mainly for the front outter tire wear correct? can't really tell if there is excessive wear yet.
      05-06-2018, 03:51 PM   #43
MagnusT
MagnusT's Avatar
Sweden
538
IMHO: no
      05-08-2018, 02:41 PM   #44
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
No
