01-27-2018, 05:11 PM | #67 |
381
Rep 731
02-07-2018, 11:37 AM | #70 |
3843
Rep 54,362
Drives: F80 M3
02-18-2018, 03:49 PM | #71 |
Rep 1,367
So, just curious, installed these today and just did a little test drive around the garage. Everything feels fine but I get a little pop/knock when I switch from forward to reverse direction (like backing up - and vice-versa). Assuming this is normal for the track pads on Brembos?
All 8 pins are fully seated and the tension-er is tight under each pin. Haven't really warmed them up or gotten them close to bedding in... Thanks in advance See someone else mention the same clunking issue here: https://f87.bimmerpost.com/forums/sh...6&postcount=19 |
02-18-2018, 03:50 PM | #72 | |
Rep 923
02-18-2018, 03:54 PM | #73 |
Rep 1,367
02-18-2018, 04:17 PM | #74 | |
Rep 444
Drives: 2017 M2 6MT, 2022 X7 M50i
02-26-2018, 11:07 AM | #76 |
3843
Rep 54,362
Drives: F80 M3
04-02-2018, 04:01 AM | #79 |
Rep 82
Almost settle for DS2500 but I saw a youtube video where the guy taped the wear sensor and zip tied it to a hose in the fender. Asked him if that is necessary and he replied that the hole where the sensor should be attached to the pad is way to small and it requires some drilling. Since I'll be driving with these pads daily I don't like having things taped to braking ducts nor pads modded by me to make way for the wear sensor.
So... was this just an isolated case or all DS2500 share the same faith? How did you deal with the wear sensor? Pagids RSL29 can properly receive the wear sensor? |
04-02-2018, 02:20 PM | #80 | |
3843
Rep 54,362
Drives: F80 M3
04-02-2018, 02:23 PM | #81 |
3843
Rep 54,362
Drives: F80 M3
04-03-2018, 02:42 AM | #82 |
Rep 82
04-03-2018, 02:06 PM | #83 |
3843
Rep 54,362
Drives: F80 M3
05-08-2018, 08:40 PM | #84 |
Rep 3
Can you confirm if the RS29 pads for the M3 F80 (iron brakes) works/its the same for the M2?
I had an M3 F80, and bought this pads for it. Sold the M3 and now i have an M2 and this pads lying around. Do they work? Thanks in advance! |
05-08-2018, 08:45 PM | #85 |
3843
Rep 54,362
Drives: F80 M3
Yes, direct fit. Also fits M235i and F3x with the blue sport calipers!
06-05-2018, 02:29 PM | #88 |
3843
Rep 54,362
Drives: F80 M3
These are back in stock with limited quantities. Order yours soon!
