M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > M2 Wheel Pictures
      12-22-2017, 07:49 AM   #265
TuningTech FS
TuningTech FS's Avatar
Drives: BMW, Mercedes, & Porsche
Originally Posted by wolfbane1967 View Post
That looks great!
      12-27-2017, 09:47 AM   #266
wolfbane1967
Thanks man, heres another one
Porsche 991.2 GTS
Appreciate 7
OG///M1003.50
BSMF87139.50
Ymalo22113.00
ewohar21.50
S1monQc223.50
DaFish157.50
      12-27-2017, 10:21 AM   #267
jonahk
jonahk's Avatar
Drives: 2021 G80 M3
2021 BMW M3  [0.00]
2018 Porsche Macan  [0.00]
2018 BMW M2  [0.00]
Those style 763's look so good on the M2. You've helped me make my decision thank you
      01-01-2018, 10:03 AM   #268
NorthernM2
Finally got my winter set-up fitted and just in time for the snow last week. 2Forge ZF02 8.5x19 gunmetal ET25 with 245/35 and 255/35 Michelin Pilot Alpin PA4s.
Originally was planning on 235/35 for the front to match the OEM winter tyre sizes but the 245 was cheaper.
Had a nightmare getting the TPMS valve to seat correctly on one wheel, had to have it swapped out 3 times as it kept leaking air (new OEM valves) but finally sorted.
Wheel weights appear, based on nothing other than lifting the wheel, to be similar to OEM for the front and but lighter for the rear (much narrower rim).
Had a good opportunity to try in snow a few days ago - car easily went up a quite steep hill with two inches of snow whereas my dad couldn't get his front drive car (on normal tyres) up the hill and even coming down from the top was tricky for him. Overall, performed much better than I expected.
Photos below.
      01-02-2018, 02:43 PM   #269
OG///M
Always +10MPH
OG///M's Avatar
Drives: 6MT
Nice pic! any spacers on this?
Saanen180.50
      01-04-2018, 12:03 PM   #270
wolfbane1967
Thanks,
Yes H&R 10mm in front due to negative camber (camber plates). Nothing rear
Porsche 991.2 GTS
      01-04-2018, 12:26 PM   #271
rwalker
Drives: the wheels off
Thanks,
"...due to camber plates"
Do I understand that you think camber plates require spacers? Can you explain why you think that?
Camber plates do not affect wheel->strut or wheel face->brake clearance.
      01-05-2018, 01:09 PM   #272
wolfbane1967
Whit camberplates on and negative camber in front causes the upper part of the Wheels to lean invards. I hope i explaind this right
      01-05-2018, 01:20 PM   #273
wolfbane1967
      01-06-2018, 10:40 PM   #274
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
There is not a technical reason that you would need to add spacers after installing camber plates and adding more negative camber. They will, however, help reduce the additional gap that you will see between the tire and the fender.
      01-07-2018, 01:26 PM   #275
Jeffster_
Drives: 2017 M2
Here are a few phone pictures of my Alpine White M2 in Winter Attack Mode!
square setup with
Matte Black Apex ARC-8 19x9.5 ET22
Studded Hakkapeliitta 8 255/35/19
H&R Lowering Springs
it's amazingly good in the snow and ice with the studded tires!
Appreciate 16
Kimbo6319.50
adisz165.50
///cbrash226.50
DETRoadster11462.50
Scrape37.50
JTO245276.00
Nkc1600.50
808elise378.00
csbear1118.00
M3 Alex122.50
      01-07-2018, 01:45 PM   #276
Aerosoul Bastard
Switzerland
145
2018 BMW X1  [10.00]
2018 BMW M2  [10.00]
how she drives on snow?
      01-08-2018, 09:14 AM   #277
wolfbane1967
Nice snowpics and wheels :-)
      01-08-2018, 09:26 AM   #278
JKen_0115
JKen_0115's Avatar
Drives: 2017_M2
square setup with
Attachment 1747763
Attachment 1747764
Attachment 1747765
Attachment 1747766
Attachment 1747767
Nice setup, very like this wheel on this AW M2.
      01-08-2018, 07:34 PM   #279
matt@supremepower
matt@supremepower's Avatar
Drives: BMW
BBS Motorsport E88
Toyo R888R
Ohlins Road & Track Coilovers
Appreciate 4
      01-08-2018, 10:56 PM   #280
adisz
Drives: 2023 BMW M3
Originally Posted by Andrew@SupremePower View Post
BBS Motorsport E88
Toyo R888R
What are the specs on these bad boys? Looks great
      01-09-2018, 02:53 AM   #281
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Spacers also mess up geometry by changing scrub radius and put unnecessary load onto ePAS steering rack and associated joints/swivels....
Current '22 X3M LCI..
      01-09-2018, 03:05 AM   #282
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
square setup with
What camber are you running up front ?
Are you using camber plates or is the camber just from lowering on H&R springs ?
Either way, your car's stance looks great !!!
      01-09-2018, 03:08 AM   #283
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
My stock AW M2 with its winter boots on...
OE style 640m 8.5"/9" in orbit grey c/w OE starred Mich PA4's 235/40/18 all round....
      01-09-2018, 07:10 AM   #284
AGM2
AGM2's Avatar
Drives: M2 LBB 17
Originally Posted by PRustan View Post
M.B. - have you received your wheels yet? Any pics? Really like the look of these wheels and wondering if they turned out as good as you were expecting.
+1
      01-09-2018, 09:47 PM   #285
Jeffster_
Drives: 2017 M2
it handles amazingly well in the snow. RWD is slow off the line even with the studded tires but its a ton of fun to slide around. I'll usually take a 30 minute detour on the way home to slide around when it snows.
Scrape37.50
x233284.00
JTO245276.00
      01-09-2018, 09:48 PM   #286
Jeffster_
Drives: 2017 M2
Thanks Man! I just have the lowering springs, no other modifications to the suspension, It's even the stock alignment. I had it on the alignment rack at BMW after the springs were installed and it was still within spec.
