12-20-2022, 01:30 PM | #1 |
Rep 894
Drives: OG M2
Not too bad to install - the wiring was the most complicated part! CSL yellow is my favorite mode so far! For anyone looking to do the same, I got them off of AliExpress and the white mode is exactly the same as OEM!
01-06-2023, 05:31 PM | #3 |
Rep 894
Drives: OG M2
09-01-2023, 08:49 AM | #4 |
Rep 22
samsamdar I have received this rgb leds but i have an issue, in EU cars we dont have idrive option to turn off the drl light.. do you know if i can Connect all without turning off the drl on idrive?..
09-06-2023, 04:51 AM | #5 |
Rep 894
Drives: OG M2
You can code in that option or just code out the original DRL lights from functioning entirely. It's not required per say but it will make the lights run a lot cooler and increase their lifespan. Also will prevent any light bleeding from the additional amber/orange LEDs that are on the boards.
09-18-2023, 02:12 PM | #6 | |
Rep 22
With drl off on idrive and connected 12v to fusible 44, drl doesnt power on when i unlock / lock the car, only with first position on inside car, do you know how to solve it? |
09-18-2023, 02:16 PM | #7 | |
Rep 894
Drives: OG M2
09-18-2023, 03:02 PM | #8 | |
Rep 22
09-18-2023, 04:09 PM | #9 |
Rep 894
Drives: OG M2
I couldn't find anything in the engine bay fuse box that operated as such but if you do, let me know!
09-19-2023, 11:48 AM | #10 |
Rep 22
09-19-2023, 05:37 PM | #11 |
Rep 894
Drives: OG M2
Yeah that was another problem I was having
09-22-2023, 10:10 AM | #12 |
Rep 22
I have found a solution, it is not 100% perfect, but I think it is better, I bought this device and I connected it to fuse 22, and the output of the device to the RGB controller, in this way the operation is as follows: car parked and closed, you unlock it and the DRL lights come on for 10-15s, they turn off and do not come on again until you start the engine, if you turn off the engine after 10-15s they turn off automatically. The only drawback is that if you have the car parked, you unlock it, the DRLs turn on, but if you lock it and unlock it again in a period of less than 3 minutes (the fuse still has power) the DRLs do not turn on until you start the car engine.
https://www.amazon.es/gp/aw/d/B08156...b_b_asin_title You can find it in AliExpress etc, searching for something like drl timer Another question that i have might you know it, is when drl power on, they light in random color and 1-2s later they light in the last color you select it.. i missing something to avoid this? |
09-24-2023, 04:04 AM | #13 | |
Rep 894
Drives: OG M2
03-31-2024, 06:21 PM | #14 |
Rep 648
Drives: 2018 F48 X1 xDrive 18D
How are these holding up? Thinking of buying the ICEDRIVER from aliexpress but I have concerns about the quality. Should I?
03-31-2024, 07:00 PM | #15 |
Rep 894
Drives: OG M2
Zero issues after over a year. Doesn’t matter where you buy it from - it’s all the same cheap Chinese stuff lol. Most companies (won’t name em) are just repackaging and doubling the price but they literally get them from Icedriver lol. It’s a pretty simple concept though - if you have basic soldering skills you can modify your OEM boards to be whatever color you want
mrpingu193.50 |
03-31-2024, 07:05 PM | #16 | |
Rep 648
03-31-2024, 07:09 PM | #17 |
Rep 894
Drives: OG M2
Honestly no idea - I can send you pics of my OEM boards when I get back to LA if you’d like to use those for reference
03-31-2024, 07:19 PM | #18 |
Rep 648
04-09-2024, 03:44 AM | #20 |
Rep 585
Is my understanding correct, that these don't function in the same way as the OEM lights? Fade in to unlock etc? Is it because they are the RGB version?
04-09-2024, 03:46 AM | #21 |
Rep 894
Drives: OG M2
Yes these don’t function like OEM because they’re the RGB version - the RGBs require their own separate 12V power source. The single colored versions will operate exactly like OEM.
04-09-2024, 06:50 AM | #22 |
The Seeker
14157
Rep 3,414
I've been interested in these for a while, but I'm after a very specific color, and color density. Everyone seems to be after these crazy bright yellow, blue or red colors, but I'm more after a light iced teal like in the pic below.
This is the same kit you use? Last edited by ///MPhatic; 04-09-2024 at 12:01 PM.. |
