BIMMERPOST Universal Forums > General BMW News and Cars Discussion > Is this a head gasket issue? N55
      11-21-2023, 03:51 PM   #1
moneypitlexus
Drives: e46
Looked at a vehicle and saw this under the cap. Is this a head gasket issue? It’s cold but not that cold.
There is no dipstick and can’t get confirmation if it’s milkshake or condensation.
      11-21-2023, 04:01 PM   #2
Car-Addicted
Car-Addicted's Avatar
Drives: 2020 BMW M4 CS
2020 BMW M4 CS  [9.87]
Assuming the engine isn't:
Overheating
Loosing coolant
Down on power
White exhaust smoke
There are a lot of tests for a head gasket failure, easiest is a coolant system pressure test. After that a leak down test will tell you if there is a issue.
A oil change is on order either way and that will also tell a lot.
Good luck.
      11-21-2023, 05:05 PM   #3
moneypitlexus
Drives: e46
I know I can do all that but I can’t perform all that until after I purchase it.
Anyway to find out prior before purchase?
      11-21-2023, 05:14 PM   #4
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
Take it to a good independent shop and get a prepurchase inspection.
      11-21-2023, 05:18 PM   #5
tracer bullet
tracer bullet's Avatar
Drives: '11 135i , '15 X3 35i
Drive it a bit and change the oil. If it's normal looking and only like that under the cap, it's fine / normal / from cold and short drives. If more oil is milky walk away.
Does cost an oil change though. If you're very serious about the car it could be worth it.
Both my N55's can sometimes look like that and I'm certain that neither has a head gasket issue. But it doesn't mean that particular car doesn't.
