06-15-2021, 03:04 PM | #265 |
Rep 303
I’m actually going to try a 10mm spacer on the rear and run et 35 10.5 x19 with stock then I’ll probably fit 285/35 and remove the spacers, I’m running 22 fronts
06-16-2021, 02:46 AM | #266 | |
Rep 303
I will try 10m spacers on the back with 10.5 et45s, which is less aggressive than et25 with 10" rims |
Expert@ApexWheels3561.50 |
06-16-2021, 07:12 AM | #267 |
6643
Rep 4,145
Drives: '18 M2 6MT
06-16-2021, 12:48 PM | #269 |
Rep 303
A longer trip trying to get as much movement as possible, nothing so far
VisualEcho6642.50 |
06-18-2021, 01:37 AM | #270 |
Rep 303
With a 35m lens easier to see offset, 9.5 et22, 10.5 et45 245/265. No rub so far
06-23-2021, 01:32 PM | #271 |
Rep 303
Still zero rub and have been out 5 people up dropping people at the train station....
Rundskop148.00 Expert@ApexWheels3561.50 |
06-23-2021, 06:26 PM | #272 |
Rep 4,255
these look really good. I wonder if I can get away with them as winter wheels with a 35 aspect tire.
///M Power
06-24-2021, 05:00 AM | #273 |
Rep 303
I'm sticking with 35 profiles, 245 and 265 35's at the moment and will move to 255/275 35's possibly 255/285 35.
I don't want to run 30's personally |
GarageMadness665.50 |
06-24-2021, 01:01 PM | #274 | |
3562
Rep 6,799
We recently launched our M2 Competition fitments in our SM-10 design as well to give our customers more options on the design front for this fitment. Those wheels are in stock and can be viewed here: https://www.apexraceparts.com/store/..._diameter=%2C6 The fitments mirror our EC-7 M2 Competition fitments with 19x9.5 ET28 for the front and 19x10.5 ET45 for the rear. We've also released a 19x9 ET30 EC-7 wheel for the first time for those looking for a narrower front wheel or a square winter wheel option that still clears the 2NH brake package. -Tom
06-25-2021, 02:49 AM | #275 | |
Rep 303
I will be fitting Milway Camber plates and expect to settle on around 2.25-2.5 of negative camber. I think this will pull the top mounts in by 5-10mm and add about 4-6mm outer arch clearance if my scruffy pythagoras still works ! |
06-25-2021, 01:37 PM | #276 | |
3562
Rep 6,799
-Tom
06-25-2021, 02:47 PM | #277 |
Rep 118
I ordered 19x9.5 et28 and 19x10.5 et45 EC7.
Will I be able to fit OEM PSS (245/35, 265/35) fine without any additional negative camber (will max out what the car can give, no plates atm)? Running on Ohlins pretty low right now but can raise height a bit. |
06-25-2021, 06:07 PM | #278 | ||
Rep 147
06-26-2021, 02:39 PM | #280 |
Rep 303
150 miles trip an on the motorway, zero issues. I checked my camber I am currently -1.75 degrees with no camber plates. I will add another 0.5 degrees and this will pull the tyre in by about 4mm at the arch. So I have no doubt 255s will be fine with -2.25 degrees of camber et22 9.5x19
06-28-2021, 03:24 PM | #281 | ||
3562
Rep 6,799
One thing to keep in mind is that your Ohlins coilovers may limit inner clearance up front. You may need to run a 5mm spacer to provide enough clearance on the inner edge for the wider wheels especially if you go to wider 265/30-19 tires in the future. The spacer will move the wheel outboard and the tire closer to your outer fender. Depending on your ride height, this may cause rubbing which you can alleviate with additional negative camber up front. Quote:
-Tom
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 06-29-2021 at 01:42 PM.. |
06-29-2021, 01:41 AM | #282 | |
Rep 303
I would recommend you assess the inside of your coilovers. with AST based Litchfield I would not have fitted et 28 as my inner clearance was not enough to have the wheel come in any further, it would have touched the smaller spring with the tyre with et28 as the tyre would have come in by 7mm from stock If you check your front camber then you will see if you will be okay without camber plates (I seem to be 100% okay running stock tyres and no camber plates and et22) my camber lowered without plates is -1.75 degrees |
06-29-2021, 09:33 AM | #283 |
Slave at the company
238
Rep 58
Drives: BMW M3 F80
I need it! replacement for my 18-inch EC7!!
setting of 255 35 / 275 35 appropriate? Last edited by HONGCHUMZI; 06-29-2021 at 09:59 AM.. |
06-29-2021, 01:10 PM | #284 | |
Rep 100
06-29-2021, 01:36 PM | #285 | ||
3562
Rep 6,799
Front: 19x9.5" ET28 with 265/30-19 tires Rear: 19x10.5" ET45 with 295/30-19 tires -5mm front spacers or larger may be required with certain aftermarket suspensions -Front negative camber recommended if using aggressive tire compounds. The M2C wheels were really designed with wider tires in mind but we did have to compensate for that by using the shorter 30 aspect ratio to prevent rubbing. We haven't tested the taller/narrower setups. I'm sure you can make them work, but you may get rubbing during compression and may need alignment adjustments et c. Quote:
-Tom
06-30-2021, 09:00 PM | #286 |
Track Rat
17
Rep 9
265/35-19 and 295/30/19
Did you find an answer with respect to that setup? I've been digging into the same issue, and have been told it comes down to 2 things: trial and error. If anyone else has tried it, I'd love to hear from you!
