08-23-2022, 10:53 PM | #50 |
3888
Rep 54,565
Drives: F80 M3
Not many enthusiasts are aware that OE and more importantly aftermarket sway bar effectiveness can be hindered by worn or inadequate mounts, drop links and lateral stoppers. Whiteline adjustable sway bar links are engineered to be up to the task with top spec, light weight componentry combined with a window of adjustability, eliminating sway bar preload on installation but most importantly ensuring the maximum output of the sway bar for improved grip and better handling.
Performance Whiteline Adjustable Sway Bar Links Are Designed To Increase Sway Bar Effectiveness And Improve Overall Performance. By Eliminating Flex And Compliance Associated With Original Equipment, These High Strength Links Provide Increased Rigidity And Responsiveness Which Can Be Felt Especially During Lane Changes And Initial Turn In. Construction Whiteline Adjustable Sway Bar Links Are Manufactured From High Quality Alloy And Include Heavy Duty Steel Ball Joint Ends Ensuring Maximum Strength And Durability. The Light Weight Alloy Bodies Are Anodized In Whiteline Gold Colour Providing A Long-Lasting Protective Barrier To Corrosion And Wear. Adjustable Eliminate Sway Bar Pre-Load Or Fine Tune To Your Liking, Whiteline Sway Bar Links Allow For On-Car Length Adjustment Of Up To 25mm Centre To Centre. Heavy Duty Ball Joints Adjust And Rotate To Any Angular Combination For Ease Of Fitment And Optimum Performance. Performance Whiteline Adjustable Sway Bar Links Are Designed To Increase Sway Bar Effectiveness And Improve Overall Performance. By Eliminating Flex And Compliance Associated With Original Equipment, These High Strength Links Provide Increased Rigidity And Responsiveness Which Can Be Felt Especially During Lane Changes And Initial Turn In. Construction Whiteline Adjustable Sway Bar Links Are Manufactured From High Quality Alloy And Include Heavy Duty Steel Ball Joint Ends Ensuring Maximum Strength And Durability. The Light Weight Alloy Bodies Are Anodized In Whiteline Gold Colour Providing A Long-Lasting Protective Barrier To Corrosion And Wear. Adjustable Eliminate Sway Bar Pre-Load Or Fine Tune To Your Liking, Whiteline Sway Bar Links Allow For On-Car Length Adjustment Of Up To 25mm Centre To Centre. Heavy Duty Ball Joints Adjust And Rotate To Any Angular Combination For Ease Of Fitment And Optimum Performance. Installation Guide: https://www.whiteline.com.au/docs/in...5146_Z5932.pdf Fitment: 2012-BMW-128I-BASE 2012-BMW-328I-XDRIVE-BASE 2013-BMW-128I-BASE 2015-BMW-M3 2015-BMW-M4 2016-BMW-M2/M2C |
