BMW M2 Forum > M2 Photos, Videos and Builds > Tano's LBB M2 LCI
      04-19-2019, 03:54 PM   #155
H20neun
H20neun's Avatar
Germany
114
Drives: M2 LCI
Originally Posted by Tano View Post
Thanks!
I'm running them with 255/35 on the front and 265/35 on the rear.
The suspension is stock for now but i'm planning to upgrade it with millway camper plates soon to reduce uneven tire wear on the track.
okay, I am planning on buying some tracktires for my 513m soon and im not sure if I want to go 245/40 in front or bigger, any rubbing with 255 in front?
      04-20-2019, 02:24 PM   #156
Tano
Tano's Avatar
Hungary
375
Since my tires are /35 the overall diameter is smaller than stock thus there is no rubbing for me. Of course my speedometer cheats more but it's not an issue on a track.
      05-02-2019, 12:05 PM   #157
Tano
Tano's Avatar
Hungary
375
So my car is back and it's as good as when it was new. The repair is perfect.
Now i can continue with my small modifications. Yesterday I painted some matte black eyebrow for the headlights with "Plasti Dip" to make the look a bit angrier, 'cos i don't like the white part on the upper part of it. Here is the result.
      05-03-2019, 12:12 AM   #158
Yvette
761
Drives: M
Looks like you put a eye liner, it kills the front imo
Appreciate 4
      05-25-2019, 08:46 AM   #159
terrywang
terrywang's Avatar
94
Drives: OG F87 M2
2016 BMW M2  [0.00]
Glad to see your M2 back.
I prefer the pre-LCI headlights where the eyebrows are actually LEDs. The LCI headlights do not have this effect any more (but the tail lights look more modern and are full LED...).
2016 F87 M2 DCT LBB
Tano374.50
      06-02-2019, 09:31 PM   #160
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
My favorite part is the plants inside the used tires!
Tano374.50
      06-17-2019, 03:51 PM   #161
Tano
Tano's Avatar
Hungary
375
Last sunday i managed to go to the Euroring again, first time this year. It was a great although very hot day. The ambient temp was 34C in the shadows, but there were no shadow on the track.
I managed to improve my laptime with nearly a second this time. Unfortunately my dashcam did not record anything on the SD card so i couldn't make a clip from it, i have only the data log files. I suspect it was the SD card's fault so i did a reformat on it and will see if it works again.
In this high temps my IAT reached 54C but i didn't noticed any performance loss and the logs are looking good too. However it's a small track and there aren't long straights there and I'm using 100 octane fuel.
Maybe it's time to buy a separate action cam for recording.
      06-19-2019, 05:33 AM   #162
Hans Gruber
Hans Gruber's Avatar
Drives: XC60 T5, R32, M2
lambda spacer ?
Hi there,
Just reading through your thread, you are on a mission
It looks like you fitted a spacer to the second lambda sensor (was this enough to avoid the ecu throwing a error code)
I just got back from le mans as a spectator and may have caught the bug.....
dtmurf481.50
Tano374.50
      06-19-2019, 02:37 PM   #163
Tano
Tano's Avatar
Hungary
375
Originally Posted by Hans Gruber View Post
Hi there,
Thanks. Yours also looks cool, i like those strip accents.
I think it works because i didn't get CEL while I've run on stock and stage 1 maps. Although after i updated to stage 2 I got CEL, but it was about rich mixture not because faulty cat.
      06-20-2019, 07:20 AM   #164
Hans Gruber
Thanks
Thanks, this is definitely going on my list
All the best with your ongoing project, I have you bookmarked
Tano374.50
      07-05-2019, 10:12 AM   #165
Tano
Tano's Avatar
Hungary
375
After my last track session it is time to change the front brake pads again. I've been browsing the net when i found there is a new track compound (RP1) from EBC so i decided to give it a try. Will see how it performs on my next trackday on tuesday.
      07-12-2019, 01:38 AM   #166
Tano
Tano's Avatar
Hungary
375
Finaly I managed to get free from work to have a fun day at the Hungaroring again.
It was a bit busy this time but i enjoyed all of it. I had the luck to follow a nice old Porsche, it was great to watch it during its run.
I managed to improve my best time with a couple of hundreths of a second.
Some words about the new EBC RP1 compound. It worked well for me, i did not experience any fade and it was consistent during the 5x20 minutes run.
This time i took a digital thermometer so I measured the brake temperatures after my cooldown lap in the pit. The valueas were variable a bit depending on the time when i did the measure and the intensity of the session.
Front: rotors 250-330C and calipers 170-210C.
Rear: rotors 190-230C and calipers 120-150C.
I couldn't get to the pads precisely but they must be between the rotor's and caliper's temperature.
Then in the final run I have met with an unpolite Mercedes too which kept me up for a whole lap.
And here is my usual video with the noticable moments.
      07-12-2019, 02:48 AM   #167
Tano
Tano's Avatar
Hungary
375
Looks like it doesn't display the picture i uploaded so here it is again.
      07-19-2019, 03:54 PM   #168
Tano
Tano's Avatar
Hungary
375
The next project will be the installation of the Millway camber plates.
FIDDIE12.00
      07-20-2019, 04:26 AM   #169
Tano
Tano's Avatar
Hungary
375
Today I did some logs with BM3. It was 3x3rd gear and 2x4th gear pulls, ambient temp was 27C, Stage2 91 octane v5.7 map with 98 octane fuel.
Here is the log.
Please comment if something seems wrong with it.
What i noticed and I'm curious if there's a problem or not.
HPFP seems ok up to the max rpm, it doesn't drop, and i didn't have any knock.
I noticed some difference in ignition timings:
- During second pull at about 4k RPM cyl 3&5 dropped 3 deg then gradually they caught up with the rest at about 6k RPM.
- In the 3rd pull only cyl 3 did a drop around 2.5k then another at 3.5k, then gradually caught up.
- In the 4th run cyl 3 again dropped at 5.5k then caught up with the rest but later cyl 1 dropped at 6-4k.
- In the last 5th pull cyl 1 and 4 did a drop around 6.4k.
So the question is that are these drops normal or they're related to octane problems or bad ignition plugs or something else.
My mileage is 29k km and i'm planning to switch to the recommended colder NGK plugs with 0.05mm gapping. And should i give a try to 93 octane map?
      08-02-2019, 02:33 PM   #170
Tano
Tano's Avatar
Hungary
375
Today I had some time to do some maintenance work since my car is getting to 30k km.
I changed the oil in the rear differential (Castrol Syntrax LS 75w-140 [SAF-XJ]) and changed the spark plugs too. I installed NGK 97506s gapped to 0.55 as recommended by PTF for Stage2. Will see how they perform.
I also have bought fuel filter but unfortunately i found that there is no fuel filter in my M2 under the driver seat area. I checked and there are two version in the RealOEM, so it tricked me.
And a small tuning with the BLACKLINE Taillight Overlay Kit.
Tomorrow I will continue with the installation of the Millway camber plates.
      08-04-2019, 05:32 AM   #171
Tano
Tano's Avatar
Hungary
375
So yesterday the camber plate install was successful. The first one was a little bit harder but the second one went quicker based on the previous experience.
Today i finalized the camber setting, it will be about -2.5 degrees according to my home made measurement.
I changed the toe also but tomorrow I will take it to a tire shop to adjust it properly.
Here is how it looks like. Later i will reinstall the rubber covers too.
dtmurf481.50
      08-05-2019, 01:07 PM   #172
Tano
Tano's Avatar
Hungary
375
The alignment was done today. The front camber was just 0.1 off from my desired value so we didn't have to make big adjustment during the setup.
What's more interesting is that the rears (which was not modified anytime) were much more off from factory settings. Thanks for the bad road quality in Hungary. I wanted a bit more camber on the left rear than the right based on my tyre wear on the track. Will see how this 2.5 front camber works on the track.
Anthony1s755.50
      08-07-2019, 09:16 AM   #173
MN.BIMMER
No Cop No Stop
MN.BIMMER's Avatar
Drives: 2012 BMW 135i
I really enjoyed going through this build. Nothing flashy, just a man properly using his M2 as the engineers designed it, plus a few power mods.
Current Garage!
2012 BMW 135i - 6MT w/ OEM 550i clutch & MFactory LWFW, Pure Stage 1, MFactory LSD, VRSF Catless Downpipe, JB4 w/ MHD BEF
Tano374.50
      08-12-2019, 03:38 PM   #174
Tano
Tano's Avatar
Hungary
375
Here is the short video of my last trackday on the Hungaroring last weekend. Unfortunately without telemetric overlay because i had to use my old phone which did not worked as i expected. Anyway it was great although a very hot day. 34C in the shadow!
The previously installed parts worked well and i'm satisfied with the bigger camber. I saw better wear pattern on the front tires.
I had a moment in the first session because i wanted to pass an E36 so i applied a bit too much throttle too early.
This time i didn't went for better time but turned DSC OFF and tried to experience the car this way.
dtmurf481.50
      08-17-2019, 03:22 PM   #175
Tano
Tano's Avatar
Hungary
375
Today I've taken my car to Karcagtuning for a dyno run. We used the Insoric sensor system. I don't know how precise is this system compared to a dyno bench but it measures under real circumstances.
I also recorded with Racechrono to have a comparison using TTDyno software. There is some difference between the 2 calculation as you can see below on the pictures.
Note: TTDyno shows the Wheel parameters while the Insoric shows the crank ones.
In order to get the most precise result i measured the car's weigh with a precise scale at the Mill next door. I was a bit shocked cause it is quite heavy. With my 75 kg body and 50% fuel (cca 20 kg) it weighed 1630 kg. Which means its empty weight is 1535 kg. In comparison the factory claim is 1495 kg with 90% fuel, so its 80 kg heavier. Of course some of my mods have some noticeable weight (for ex. FMIC, splitter) but it still looks too much for me.
      10-05-2019, 09:26 AM   #176
Tano
Tano's Avatar
Hungary
375
Yesterday my car was updated with the newest software, so now its I-Level is at F020-19-07-539. It went well, took about 2 hours.
Then today i flashed it with the most recent v5.8 Stage 2 93 octane map. Next week i will make some measurement to see how it works. I already made logs on the stock map this week so i could compare the results.
