12-30-2023, 07:58 AM | #199 | |
Rep 711
It would be a great tool for these guys to have power graphs with overlays of the range of Fuels 95% of their customers have access to. One graph with overlays of 91, 93, e30, e50, etc. Obviously you're not going to hit all fuel options and meth combinations what have you, but at least put something out there to bookend the possible performance range on different Fuels. Hell, even have seperate overlay graphs for hp and torque, so it doesn't get too confusing to look at. It's not like you need to see those figures on the same graph anyway. When I was searching for my turbo, I was struggling to find results on 93 because mostly the only people going to dynos and posting results just want to show a high number, so they're almost always an e-blend with meth injection. I gotta think the majority of users can't be bothered with that stuff. Thankfully in the end I found somebody with 95% of my planned mods who actually posted dyno results on 93 which I believe should validate what I'm hoping to get once I finally get my kit installed. |
CanadianM280.50 MetalM29.50 |
12-31-2023, 10:47 AM | #201 |
Rep 711
Hey Calvin, this guy made 500whp on 93 and a Dorch stage 2 hpfp, so I think I should be in the same ballpark. He's rwd though and I'm x-drive, so not sure if I'd have more drivetrain losses. Also he's got the internally gated version, and my external gated version has slightly larger turbine a/r, so that should improve my exhaust flow with a small trade off in spool. Probably a good tradeoff though since the external gate will stay shut below spring pressure.
https://f30.bimmerpost.com/forums/sh....php?t=1723999 |
CalvinNismo53.00 |
12-31-2023, 06:51 PM | #202 |
Rep 87
Well that’s that I guess.
hihowareyougood125.50 |
01-29-2024, 09:35 AM | #204 |
Rep 6
I know this is the wrong forum for this, BUT I recently pulled the trigger on the pure500 turbo with install kit for my e70 x5. There isn't much talk elsewhere on the pure500 kit so I figured this would be as good a place as any to post info/results.
Car is nothing special right now, just VRSF CP with JB4. Stock FMIC. Stock DP and Stock intake. This will be a decent baseline for stock power vs pure500 installed with piggyback jb4. EST ship date is 3/1 from Pure... Planning to do regular maintenance along with pure500 install - waterpump and t stat - belt and tensioner kit - 1 step colder plugs - new coilpacks - new crankcase vent hose cause i know that will snap - pure500 Chassis has 131k miles and n55 has 71k... replaced under warranty by BMW. tcase has 60k miles. edit: forgot to mention. I spoke to Pure about expectations for the pure500 kit. I plan to run 93 pump with jb4 on map 5...stock IC and DP... and they're guesstimating 450whp. Seems high to me. |
01-29-2024, 02:03 PM | #206 | |
Rep 4,174
450HP maybe - but not WHP. Expect that to be at 370whp at most.
Mods: Yes.
01-31-2024, 12:12 PM | #207 | |
Rep 4,174
Mods: Yes.
01-31-2024, 07:31 PM | #208 | |
Rep 711
I agree with others, this should be a great bump over stock, but on 93 Oct I think it will be sub 400 whp. |
02-02-2024, 08:01 AM | #210 |
Rep 6
I agree that their estimate seems very high. I don’t expect that at all. Just wanted to share their numbers.
I’m not sure if I’ll dyno. TTFS is down the road from me, so I could do that if I find the time. I just installed the Magnuson 2650 on my tundra a few weeks ago and trying not to make all my cars too far from stock. My kids are usually in the x5 so trying to go modest while still keeping reliability and being able to run stock map for when my wife drives it. I would think, if done right, it could spit out 400whp and maybe 450wtq with the right conditions on 93 and cool air. Stock hpfp on the older n55’s have a higher flow rate and can keep up a little better than 14+. Retaining stock dp for emissions reasons. Don’t want to swap it out every two years and don’t want to have any exhaust odor inside the car. I know it’s minimal but again, I’m not the only driver of the car and my kids are in there a lot. |
02-02-2024, 09:09 AM | #211 | |
Rep 4,174
I've actually seen one guy do it, (based on SAE correction factor) and it was all the bolt-ons - including a downpipe, intake, inlet, HPFP and a custom tune. Oh, you'll want an inlet with your turbo - do not use the stock one.
Mods: Yes.
02-02-2024, 09:12 AM | #212 |
Rep 581
If you get a good sport cat, you don’t need to replace it every two years and there is no CEL or smell. My active autowerke GESI cat has been great. Adds some good sound too. No drone, not too anti-social just a little more throaty.
02-02-2024, 11:08 AM | #213 | |
Rep 6
I’m not sure I would see real number differences in driving around town regarding FMIC upgrade. I won’t be doing back to back pulls. Just looking for a bit for DD power. 350-400whp makes for a fun and quick DD. Very nice drivability. I would only spend the money on 200-300 cell cat should my stock one fail. Power gains aren’t worth the money imo, for me. Noted regarding the turbo inlet. I think ER makes one for my chassis that is reasonably priced. |
02-02-2024, 11:50 AM | #214 | |
Rep 176
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
AmuroRay2316.50 |
02-02-2024, 12:12 PM | #215 | |
Rep 4,174
Mods: Yes.
02-02-2024, 12:18 PM | #216 |
Rep 6
I’ll have to see how intake temps look once I have it installed. I know the stock e70 FMIC is quite a bit larger than other n55 chassis so you can push more out of it with decent temps (again I know this isn’t the e70 forum) but you can’t argue the fact that an upgraded FMIC would be better. I just think for my application I may be OK staying with stock and monitoring. Upgrade as necessary.
02-02-2024, 12:20 PM | #217 | |
Rep 4,174
Mods: Yes.
02-02-2024, 12:30 PM | #218 |
Rep 6
Thanks! The jb4 alone is a nice upgrade from stock. Map1 is nice. Map5 goes up to 16 or so psi and pulls much harder than map1.
I don’t have any logs right now but can grab some in a couple weeks once I’m back in town |
02-03-2024, 02:31 AM | #219 |
Rep 720
Asking because I haven't seen anyone (aside from tuning shops) say it..
Does anyone have the 750 sorted out and enjoy it? Don't really care about dyno numbers as much as just a solid review on driving characteristics, perceived performance, issues with install, etc. Leaning towards PS2 at the moment since it seems more proven. |
02-03-2024, 07:27 AM | #220 |
Rep 587
You'll find more here near the end: https://f87.bimmerpost.com/forums/sh....php?t=2010464
