11-02-2020, 10:04 PM | #89 |
756
Rep 2,149
11-02-2020, 10:31 PM | #90 | |
Rep 3,701
The stock turbo guys will hit the the numbers you’ve stated but with more upper RPM under the curve than the Stg 2 maps, as AmuroRay said. Even if a particular stock turbo car only makes 20-25whp over their Stg 2 93 numbers, it’s a lot faster in the real world than just the 20-25whp peak delta bc in upper RPM’s they’re gaining 30-45whp. Just ask any of the guys running the map how those upper rev’s feel and how their 100-200 & 1/4mi times are improving. Add something like a decat and stock turbo whp numbers will be just as good as my car. And, the Race Gas 2+ map is looking even quicker than the 2+ E30 map. So yeah, there will be plenty of stock turbo cars making 500 engine hp. |
AmuroRay2305.50 |
11-03-2020, 01:16 PM | #91 | |
@_sunbish
284
Rep 611
An interesting note that I didn't think about, is how some people are claiming that power holds on better into the 6000-7000 RPM range. I believe there is some truth to that. I was accustomed to shifting at 6000-6300 (depending on the gear) on the regular E30 map, the two times I held it out to about 6500 on the stage 2+ my trap speeds were higher than when I shifted at 6000-6300. Honestly when comparing this tune to say a custom tune, there isn't much to be gained on a custom tune. These new tunes and features that are soon to be released, is a blessing. The N55 could've been left behind and forgotten about. I am happy Halim is continuing to support our engine platform. Last edited by 5w20; 11-03-2020 at 01:24 PM.. |
11-03-2020, 01:25 PM | #92 | |
Rep 3,701
I'm not familiar with the OTS EWG N55 Stg 2 93 map power output, but if Stg 2+ E30 is putting down 60whp more, that's a hell of a jump for you guys! It would be very interesting to see the difference in dyno curves and gains for the EWG N55 & M2 Stg 2 & 2+ maps. I'm pretty sure the N55 EWG & M2 Stg 2+ maps are the same, but the Stg 2 maps were different and the M2 was able to make a little more power on 93. Last edited by ZM2; 11-03-2020 at 01:50 PM.. |
11-03-2020, 01:40 PM | #93 | |
@_sunbish
284
Rep 611
ZM22825.00 |
11-03-2020, 01:49 PM | #94 | |
Rep 3,701
The 2+ OTS is definitely closing the gap b/n the EWG N55 & M2 2+ maps. If they actually are different, it's not by much. |
11-03-2020, 02:41 PM | #95 | |
Rep 4,168
The standard E30 tune doesn't really seem to do too much more, maybe 10 to 15whp more at peak, but the powerband doesn't really hold significantly better. Does anyone have the actual post/statement or picture showing the M2's manifold vs the rest?
Mods: Yes.
11-03-2020, 02:52 PM | #96 | |
Rep 4,168
16PSI on a PS2 is over 400whp 20PSI on a PS2 is almost 500whp https://www.1addicts.com/forums/show....php?t=1405434 I get what you're saying, but it only works if your comparing cars with the same major mods - like a turbo. With that said, I'm really interested in what the dyno shows. I can speculate all day, but I want something to sink my teeth into.
Mods: Yes.
11-03-2020, 02:57 PM | #97 | |
Rep 3,701
11-03-2020, 03:00 PM | #98 | |
Rep 3,701
The HPFP is close to max’ed out on Stg 2 93 v5.8, and if you have a weaker than average stock HPFP, Stg 2 E30 isn’t going to do better. |
11-03-2020, 03:13 PM | #99 | |
Rep 4,168
I just ran across this while searching - https://www.2addicts.com/forums/show....php?t=1490691 10whp difference from 93 to E30.
Mods: Yes.
ZM22825.00 |
11-03-2020, 03:22 PM | #100 | |
Rep 3,701
First it was find the fueling limit, now it's find the turbo limit, and then it's add some flow mods or a larger turbo for even more juice with the OTS! |
11-03-2020, 03:30 PM | #101 | |
756
Rep 2,149
ZM2 is also flip flopping his statements depending on who he is trying to convince. One minute he says his Dinan turbo doesn't make a difference compared to stock turbo, maybe 5-10hp. Another minute he says his Dinan turbo make 60hp more than stock so he can't show me his dyno graphs because his turbo is too different to be comparable. He says he had dyno graphs of his car, on the tune those logs go to, making over 500hp. So I think he should show them. That would resolve the discrepancy I had when I called out his logs for not making the power he claims his car is making. Without that, all his words are meaningless, because it's impossible for anyone to compute the value proposition in upgrading. |
11-03-2020, 03:42 PM | #102 |
Rep 3,701
"Another minute he says his Dinan turbo make 60hp more than stock so he can't show me his dyno graphs because his turbo is too different to be comparable." When did I ever say this?
At this point, holding out on updating my curves from beta to OTS for you is getting fun. Btw, all the Dynojet's around here are booked out for a few weeks. |
11-03-2020, 03:54 PM | #103 | |
756
Rep 2,149
This is in response to me questioning your claim that your car makes more than 500whp. |
11-03-2020, 04:13 PM | #104 | |
Rep 3,701
As I have said many times my curves are on beta maps, and they’re higher than your incredible log reading/dyno math abilities are stating. I have not updated my curves with the OTS map yet, but the OTS does feel a little quicker. Once the Dynojet’s close by have availability, my OTS curves will get posted. But, it sounds like 6speed_M2 may get there first. Last edited by ZM2; 11-03-2020 at 05:12 PM.. |
11-03-2020, 04:32 PM | #105 | |
Rep 4,168
So while this tune may allow a stock turbo make 420whp, and maintain 390whp up to 6500rpm, his turbo may allow for 435whp (15 peak) and maintain 420+whp over that same area. |
ZM22825.00 |
11-03-2020, 04:42 PM | #106 | |
Rep 3,701
Your peak number looks right, but still don’t think I’ll see 420whp at 6500 on the OTS. That’ll take something a little bigger than the Dinan like a TTE460. |
11-03-2020, 05:29 PM | #107 | |
Rep 4,168
https://f30.bimmerpost.com/forums/sh...1622618&page=3 CJ Tune - 440Whp at peak - 355whp@6500RPM. FBO M235i - note SAE correction 350whp@6500RPM (Note, this is Stage 1 apparently)
Mods: Yes.
ZM22825.00 |
11-03-2020, 05:35 PM | #108 |
Rep 4,168
https://www.e90post.com/forums/showt...ighlight=m235i
Found more - Stage II 2016 M235i auto M performance exhaust and AFE cold air intake (stock downpipe) 355whp@6500RPM "No downpipe, just muffler and intake. Downpipe doesn't really net much to anything on these cars at that power level. I've posted a 2015 335i (makes less than the m235i b/c it has a more aggressive tune from the factory) With just our stage 2 tune and downpipe. EDIT: I posted the timestamp to show we did this all in the sameday." https://www.e90post.com/forums/showt...8#post24041118
Mods: Yes.
ZM22825.00 |
11-03-2020, 05:42 PM | #109 |
Rep 4,168
aFe Intake
ER FMIC ER Chargepipe ER Downpipe M-Performance exhaust JB4 +FF + EWG Wires + E35 fuel mix + Map 6 (16 psi) Got to eat my words - 385whp@6500RPM! (STD - 2.2% = SAE) https://www.2addicts.com/forums/show....php?t=1031832 "Current mods: aFe Intake, ER Chargepipe, ER Downpipe, M-Performance exhaust and JB4. I used ~95 octane fuel by mixing my current 91 octane with 5 gallons of Sunoco 100 octane at a local 76 gas station." 361whp@6500ROM (STD - 2.2% = SAE) https://www.2addicts.com/forums/showthread.php?t=983353
Mods: Yes.
ZM22825.00 |
