05-08-2019, 08:52 PM | #265 |
Rep 1,124
Pocono IMSA Course
Best lap from event: 1:39.90 2017 BMW M2 Mods: Hankook RS4s 245/40-18 and 265/40-18; Pagid RS29 all around.
05-08-2019, 09:35 PM | #266 | |
Rep 684
I change oil after every 2-3 track weekends, depending on timing. I use Motul full synthetic 5w-40. |
05-09-2019, 12:50 PM | #267 |
Rep 1,823
With a good synthetic oil AND a good filter you can go 7500 or more miles between drain intervals even with a few tracks days.
Different car, but on the Mustang I would do oil changes once a year. 8500 miles and 3-4 track days. Every analysis I did with Blackstone labs said I could go even longer. I used Castrol Edge 5w-50 in that car. I plan on doing the same with this car. I’m wouldn’t worry about track us at all as long as the oil is full syn. Better yet send it for analysis and let professionals tell you how much longer you can go between drain intervals. I use 0w-40 now. BMW extended interval stuff. Last edited by 5.M0NSTER; 05-09-2019 at 01:02 PM.. |
05-09-2019, 03:21 PM | #269 |
Rep 1,823
2017 BMW M2 German Spec
GasBurnlife(landapanda)576.00 |
05-13-2019, 03:27 PM | #270 | |
Rep 6
This was my first track day with this car and it was solid considering it is stock (except brake fluid). This is not my primary track car so I am not planning on doing much to it (maybe pads), but it is really capable and fun at the track. I tried different settings and it is amazing to see how much the car changes. Sport is useless with a ton of TC intervention and Sport+ was not much better. DSC off is bliss, the car truly comes alive. My best lap was a 1:39 and I'm pretty happy with it given overall conditions were not great (track was damp) and I am not that confident (or skilled) with the car yet. The only weird thing that happened 3-4 times was a hard pedal when first applying the brakes and it would soften after about a second pressing the pedal. This didn't happen a lot but it was annoying and made for very inconsistent braking. Did any of you ever experienced this? Thanks |
05-14-2019, 01:23 AM | #271 | ||
Rep 753
Regarding the stiff pedal on first press, did you have emergency braking turned on? |
05-15-2019, 08:15 PM | #272 | |
Rep 650
As for TPMS, I disconnected mine a long time ago...it's an impossible PITA to try to start with normal pressure, bleed off, reset, etc. Even with it removed I still get a tire warning if one is going flat ( euro warning). |
05-15-2019, 10:13 PM | #273 | |
Rep 3,696
TPMS is better to have on track than not bc you can see your pressures and adjust by popping into the hot pits. Checking temps/pressures once you’re in the paddock is inaccurate bc brake temps will drive up tire temps & pressures by then. |
05-16-2019, 07:28 AM | #274 | |
Rep 650
05-22-2019, 01:13 PM | #275 |
Rep 212
I will try, new to tracking only 3 days under the belt.
M2C stock Tires: Hankook Ventus v12 evo2 Brakes: Stock Suspension: Camber plates stock suspension. Laguna Seca 3/6/19 first time ever on the track 1:53.16 Buttonwillow#1CCW 5/17/19 2nd time on this track, first time this config 2:23.74
2019 M2C Sunset Orange/Black (Ohlins/swift coilovers, Ground Control Camber Plates, Dinan Heat exchanger, BM3 ECU tune, CF mirror caps, diffuser and rear spoiler, Vorsteiner V-FF 101 Patina Bronze wheels)
06-17-2019, 09:54 AM | #278 | |
Rep 684
Braking consistency was much better with DSC off, but even then the brakes started to feel a bit mushy after 20 mins. Going to put on the Porsche brake ducts on this weekend and expect to see some improvement. I think you have done this also ZM2 ; did you do anything to the backing plate to allow for more airflow toward the hat? |
ZM22813.50 |
06-17-2019, 10:36 AM | #279 | |
Rep 3,696
You can also shave quite a bit of time by lining the car up to eat the 1st, 2nd, and 4th curbs in the bus stop, while touching the 3rd. Rattles the car, but really straightens things up. Yup, I have the Porsche deflectors front & rear. You cut away a section of the backing plate so the air flows to the disc & hat. Def helps. Did you record your sessions on BMW Laptimer? If so, I can send you my sessions so you can overlay yours & mine to see where you're faster & vice versa. isjoey beat my time by 0.2s (2:13.2), but I only have three days on WGI in my M2 and he's a hell of a driver. Last edited by ZM2; 06-17-2019 at 11:29 AM.. |
M2joey299.50 |
06-17-2019, 11:50 AM | #280 | ||
Rep 684
ZM22813.50 |
06-17-2019, 12:15 PM | #281 | |
Rep 3,696
And, I should further clarify throttle position for turn 2. I’m back to full throttle before corner entry and then blasting all the way up the hill. Turn 2 is one of those corners where if you half throttle commit your weight transfer is to the outside and you’ll just keep sliding across the track to the inside line for 3, not ideal. If you give her full gas, the weight shifts to the back of the car and then if you really come down on the apex, the car hugs the turn and is super planted. Much faster and you end up in the right spot for 3. But, there’s only so much you can ask of the 4S’s. Try that approach sometime on some 71R’s and you’ll have a huge grin when you nail it. One of my most favorite corners on any track. |
06-17-2019, 01:00 PM | #282 | ||
Rep 684
06-17-2019, 02:43 PM | #283 |
Rep 684
Timely video: this is how a GT2 Cup Car does it:
https://www.pca.org/news/2019-06-04/...g-watkins-glen |
ZM22813.50 |
06-17-2019, 03:13 PM | #284 | |
Rep 3,696
06-17-2019, 04:04 PM | #285 |
Rep 1,823
Good stuff landapanda, thanks for posting!
