05-01-2019, 10:30 PM | #155 |
Rep 1,084
I like to run 32psi hot, which means starting really low. Often I have to take an overdriving out-lap, pull into hot pits, reset TPMS and go back out.
05-05-2019, 12:31 PM | #157 |
Rep 53
Just getting into the B-Street game, and looking forward to the limited legal mods. Been reviewing options for a front sway bar. Any new news on good choices for a front bar? Seems H&R makes an adjustable bar, good reputation, sounds like a solid bar (heavy?), and will sell only the fronts if desired. Dinan seems to make the front bar to have, appears to be adjustable and hollow (nice weight savings), but only sold in sets (front & rear) so more $$. Don't really need a nice rear bar sitting in my garage, so right now leaning toward the H&R unit. Any other applications out there?
Looking forward to just doing a sway bar, wheels, tires, whatever alignment possible, and enjoy the pleasure of limited mods. (coming from Street Mod class). Thanks for any feedback / suggestions! |
Karazy49.50 |
05-05-2019, 12:57 PM | #158 | |
Rep 189
05-06-2019, 05:56 PM | #159 |
Rep 53
Nice to have the adjustability in bars, but I also value a tubular design to save weight. Looking also now at the Afe bar because it appears hollow design, fairly large diameter, but single hole so not adjustable. Gotta read up more on this.
OG: thanks for the reply! certainly relying on others that have already gone down this path! |
Karazy49.50 |
05-06-2019, 08:43 PM | #160 | |
Rep 50
I'm still working out setup, but my car continues to be a bit too pushy right now - on 6/7 full stiff. The Hotchkis bar may actually be a bit stiffer than the Dinan, or it's a driver issue I need to work through. Look to do tires when you do the bar or you may be very frustrated.
'18 M2 - Alpine White - 6M
05-07-2019, 02:15 AM | #161 |
Rep 53
Thanks Boony! The Hotchkis bar is worth looking into. Price for a set about same price as some single bars. Were you running both the front and rear bar when getting some understeer? Pictures look like 4 hole adjustable in front bars. Guessing the stiffer settings are pretty stiff, maybe too much so.
05-07-2019, 09:39 PM | #162 |
Rep 50
I'm running in B Street, so just the front bar. The specs on the front are supposedly the same as the Dinan. From memory - 32mm hollow? It may actually be stiffer or it's partially me. I did have three years in a C6 Grand Sport with a very soft front spring so driving around pushiness is not new. Definitely still have some fiddling to do with the M2.
Karazy49.50 |
05-08-2019, 06:02 PM | #163 | |
Rep 53
What are you running for wheels and tires? Eventually will look to change from stock, but will do some events totally stock for a baseline, then begin the mild mods |
05-09-2019, 09:49 PM | #164 |
Rep 50
Forgestar CF5's, OEM widths and offsets. Dropped an the front wheel diameter an inch. BStone RE71Rs - 275/35/18 and 305/30/19. FWIW, some very fast guys are running 285/30/18 up front. I'd try it if I had a tire guys willing to struggle with mounting them. Sam Stano was a huge help with my Corvettes so I've continued to use him for the M2 stuff. He can chase down just about anything.
CSBM52739.00 |
05-10-2019, 12:12 AM | #165 |
Rep 53
Thanks for the info. That 305 in the rear is tempting, but after running 275/335 on the Z06, I am leaning away from big stagger and thinking closer to square. Mostly for the understeer. Still learning about M2 stuff though!
05-24-2019, 05:16 PM | #166 |
Go Fast And Take Chances
50
Rep 261
Getting closer!
My Stingray is now sold as of yesterday, and my future M2C is on the boat!!
Wanting to say in a stock class, moving from AS to now BS, I have ordered a set of 763's from Sun, and gone up one size in tires, 255 / 275 sticking to my favorite AutoX tire, the RE71R. I really enjoy following you guys on this thread! I've not replaced a front sway bar yet, as I was racing the Stingray since 14, and was pretty perfect stock. But listening to you guys, it's sounds like a sway bar is a good move for the front. I look forward to learning more from everyone's experience here. ~Peter
2014 Corvette Z51 Stingray 3LT, 7 M/T
2015 KTM 1290 SA Retired- 11 BMW 335, 07 BMW R1200GSA, 04 BMW Z4, 01 BMW K1200RS, 00 BMW R1150GS |
05-24-2019, 05:40 PM | #167 | |
Rep 189
Karazy49.50 |
05-25-2019, 10:29 AM | #168 |
50
Rep 261
Thank you Geezer! Yes.. AS, same as my last ride. Danke!
So I plan on running the rest of the season stock with only the RE71's. I want to hold off and the front sway bar till I learn this car. Have you done the front bar? If so dramatic difference? Thank you, ~Peter
05-25-2019, 10:03 PM | #169 | |
Rep 189
One thing you’re going to want to do is experiment with the throttle, steering and traction control settings. You can do it either via the console switches or the iDrive screen. In particular, Sport+ on the throttle can be a bit twitchy, especially on low-grip surfaces. Try different settings and see what suits your driving style. |
CSBM52739.00 |
05-26-2019, 11:38 AM | #170 | |
50
Rep 261
Thank you, and noted. I have read elsewhere here that Sport+ is just as you have described. I have read the entire owners manual now online. Still kinda confused by just reading and not having the car to test setting out..
The only way I've every successfully competed (in other cars) is with all T/C off. Are you Autocrossing with it on in some form of MDM? And if going full T/C off, can we still adjust the steering / throttle / (I'm DCT) shift speed separately while full traction off? Thank you and happy Memorial Day weekend! ~Peter Quote:
05-26-2019, 12:39 PM | #171 |
Rep 684
Throttle, shifting and steering input are not configurable when in DCT, though I would love to see that option added. Of course, you can flash the car and program whatever set of configurations you'd like, but you have to consider that it will likely impact your warranty. Check our this article:
http://www.bimmerfile.com/2016/02/22...ng-the-bmw-m2/ |
05-26-2019, 01:24 PM | #172 | |
Rep 189
05-26-2019, 02:35 PM | #173 |
50
Rep 261
Can you even store full T/C off under the M1 or M2 buttons, or do they just save the steering / throttle / shift setting, and you still need to override T/C in addition to pressing the M button?
I owners manual was not too clear on this.
05-26-2019, 02:39 PM | #175 | |
50
Rep 261
What I meant by DCT was Dual clutch transmission. I think we may be talking about two different things. And I'm referring to the new M2 Competition.
05-26-2019, 02:40 PM | #176 |
50
Rep 261
Copy. Thank you!
Old Geezer205.00 |
