04-21-2021, 09:05 AM | #23 |
Rep 95
GC claims you can have some minor caster adjustment and that was the only thing that stood out to me that would allow it. Without one in my hand I can't tell for sure.
Current: 2020 X3M, 2022 911 GT3
Past: 2020 M2 Competition,2018 X3 M40i,2017 X3,2016 VW ,Golf R,2015 BMW M3,2010 VW GTI,2008 911 GT3,2005 VW GTI,2002 VW GTI 337 |
04-21-2021, 11:13 AM | #24 |
Rep 3,540
The only way I see that on their plate is if it's directly tied to the camber adjustment (so not independent). That could be done by having the slot the shock mount slides in at an angle instead of straight in/out from the edge of the car towards the center of the car.
05-19-2021, 12:30 PM | #25 | ||
Rep 168
Current: 2019 M2 Comp, Coilovers, Camber Plates, Rogue SSK, AA Single MP, BM3 Stg 1
Sold: 2015 M235i RWD, MHD Stage 2, FBO, MPE, XHP, HPD5Evo | IG @sea_m235i |
05-20-2021, 02:29 AM | #26 | |
Rep 4,525
Has some nice design touches...see YT vlog below from ~ 6:30 in.
Current '22 X3M LCI.. |
FaRKle!4023.50 |
05-21-2021, 12:07 PM | #27 | |
Rep 3,540
I couldn't help but notice the knocking noises (starting around 12:45) picked up by the video during the test drive. Ouch.
06-17-2021, 03:57 AM | #28 | |
Rep 303
06-17-2021, 03:57 PM | #29 | |
Rep 95
JJ
06-17-2021, 05:12 PM | #30 |
Rep 1,337
If you want caster adjustment as well check out the nitrons as I think they support camber and caster
https://www.nitron.co.uk/buy-online/...ront-top-plate
06-18-2021, 01:20 AM | #31 |
Rep 554
I posted earlier in this thread regarding my Millway Street plates & how the aluminium strut brace interfered with accessing an adjustment screw for camber beyond -2.4. I have an OG LCI with F80 bracing.
I've decided 2.4 is not enough for track so now trying separate street (-2.0) & track (-3.0) settings plus I've marked 2 settings on the tie-rods to keep zero toe-in. Attached picture shows the minor mod required to the aluminium brace so I can get a 5mm hex key in to torque the adjustment screw at -3.0 camber. I've just bought some replacement screws from Millway (alignment shop damaged a couple of the hex screws) and they are now torx so would required a slightly bigger cut-out in the brace. Still no noise from the Millway Street plates after 20K km which includes 7 track days and about 4K km spirited driving on average to poor remote country roads. |
Carrera2RS204.00 |
06-19-2021, 01:16 AM | #32 |
Rep 303
I have e-mailed Suspension secrets and Millway but heard nothing yet.
My two questions : Millway - when will your street Millway for a non comp M2 be available (out of stock ordered 3 weeks ago) Suspension Secrets - I'd like to know what adjustment are recommended for caster and how accurate are the standard non adjustable cars. Plus how suitable for mostly road are the bearing top plates (noisy-harshness NVH etc) |
06-19-2021, 09:45 AM | #33 | ||
Rep 4,525
I might weigh in
Carrera2RS204.00 |
06-19-2021, 09:49 AM | #34 | |
Rep 4,525
06-19-2021, 10:04 AM | #35 |
Rep 303
Well as I’m happy with my 991 GT3 I’m up for a set as well. I have my car booked in at Litchfield. I hope SS will get back to me to discuss castor settings
06-19-2021, 06:14 PM | #36 |
Rep 463
Have you guys seen these? https://k-mac-camber-kits.com/produc...ace-192616-2n/
The design looks very interesting and I like how they include bump stops |
06-20-2021, 01:10 PM | #37 | |
Rep 3,540
06-21-2021, 01:48 AM | #38 |
Rep 303
I am not 100% sure why a lot list M2 or M2C, are they retrofittable, I thought it was only the competition strut being the difference ? is this worth retrofitting by the way ?
I am thinking of the Suspension Secrets set up with Litchfield AST Suspension |
06-21-2021, 02:14 AM | #39 | |
Rep 4,525
Did it on mine and ran just the alloy brace part for circa 6 months before adding CFRP U brace to finish as more window dressing !!!
06-21-2021, 02:28 PM | #41 |
Rep 139
RE: Camber Plates.
FWIW, I’m running KW V3’s with Suspension Secrets’ Camber Plates and Millway monoballs in the front thrust arms. No appreciable NVH over stock in an M2C. I’d read long and wide that camber plates increase NVH, but even as stock, the M2 isn’t exactly a comfortable and quiet car. Bad roads will easily highlight how stiff and unyielding the chassis is, which can be positive/negative based on your perspective. The M2 is definitely not built to be a GT. The combination of monoballs and solid bushings move the balance towards a track-biased car, but even then, the reduction in daily comfort is perhaps 10% or less in my experience. The camber plates are high-quality and use a high quality bearing. There is naturally some ‘noise’ transmitted via the top-mounts, but this is just due to the reduced sound-deadening from the stock mounts; however it really is negligible, and not the magnified knocking we’re led to believe. I suspect (but I can’t be certain), that on some coilover combinations, e.g, Ohlins, or any setup using a narrow racing spring that the noise increase may be more as you won’t be reusing the stock rubber swivel mounts from the existing top-mounts, but more metal to metal contact through a metal spring plate adapter. However, this is just a theory and for the more expensive motorsport setups, NVH takes a secondary importance to overall performance. In my case, any sound only presents itself when you’re negotiating steep inclines at an angle(like a driveway or entry ramp), where one of the wheels is unloaded, even then it’s minimal and brief. I don’t tend to take these ramps at speed anyways but that’s just me. |
06-21-2021, 06:14 PM | #42 |
382
Rep 731
I have Ohlins with the narrower front spring, Vorshlage Camber Plates, after 5,000 miles and many Track Days, I can say There is zero noise or vibration coming from them. I have been pleasantly surprised, as I had expected just the opposite.
At a Point above 7,000 RPM.
06-22-2021, 12:22 AM | #43 |
Rep 303
Well alas the Suspension secrets will not fit on the non competition cars, so I after watching the useful video on this thread I will hopefully hear back from Millway regarding the timing of the supply for the street camber plates or look at a UK supplier of Vorshlage
06-22-2021, 02:27 AM | #44 | |
Rep 4,525
https://www.ebay.co.uk/p/11020948080 - says f3x but its actually from a F8x car - £75 Have a read of this thread so as you know what's involved/parts required... https://f87.bimmerpost.com/forums/sh...ighlight=brace
