06-20-2017, 11:48 AM | #1 |
381
Rep 731
6 speed manual
Hello all, does anyone know what the final drive ratio is in the M2 manual vs the DCT. I have heard that the 6 speed could use another gear when driving long distance on highway, almost like it was revving higher than the DCT. Anyone have comparisons of both. I plan on doing some long trips and wondered if this is true.
06-20-2017, 12:02 PM | #2 | |
Rep 1,124
06-20-2017, 12:07 PM | #3 | |
381
Rep 731
06-20-2017, 12:34 PM | #4 |
Rep 6,635
06-20-2017, 11:18 PM | #6 |
Rep 6,635
06-21-2017, 02:53 AM | #7 |
Rep 6,635
chief1richard381.00 |
06-21-2017, 03:48 AM | #8 |
Rep 624
Type6-speed manual transmission
Manual gear ratios – I / II / III 4.11 / 2.32 / 1.54 Manual gear ratios – IV / V / VI 1.18 / 1.00 / 0.85 Type7-speed M Double Clutch Transmission with Drivelogic Automatic gear ratios – I / II / III 4.81 / 2.59 / 1.70 Automatic gear ratios – IV / V / VI 1.28 / 1.00 / 0.84 Automatic gear ratios – VII 0.67 |
chief1richard381.00 BAN_M2C4180.00 |
06-21-2017, 07:04 AM | #10 |
Rep 624
4.11 / 2.32 / 1.54 / 1.18 / 1.00 / 0.85
4.81 / 2.59 / 1.70 / 1.28 / 1.00 / 0.84 / 0.67 Easier to read |
06-21-2017, 12:33 PM | #11 | |
Rep 149
2016 M2 | LBB | Executive Pkg.| M Performance Exhaust | Dinan CAI | Fabspeed SportCat | standard-h.com | @standardh_
06-21-2017, 12:45 PM | #12 |
Rep 462
BMW could have given 6th gear slightly taller gearing for highway driving, but this is a very small issue and should in no way deter you from buying the 6MT. Buy the 6MT - you will not regret it.
06-22-2017, 07:55 AM | #14 | |
7906
Rep 11,785
I have found the ratios and posted them in the past. The DCT Has an extra cog, but the extra cog is at the TOP of the box and gives you a second Overdrive. |
06-22-2017, 07:55 AM | #15 |
7906
Rep 11,785
06-22-2017, 07:56 AM | #16 |
7906
Rep 11,785
06-22-2017, 10:38 AM | #17 |
Rep 1,644
The gearing is so damn short on this car, especially with the DCT. Definitely designed for track duty.
M3 Adjuster7905.50 |
06-22-2017, 11:14 AM | #18 | |
Rep 162
Chris H. - In the sunny PNW!
My handy Speed-in-Gears calculator |
STK215.50 |
06-22-2017, 02:41 PM | #20 |
Rep 190
So redlining in 3rd gear, the MT is at 93mph while the DCT is at 84. It's illegal to hit the rev limiter in 3rd with either transmission.
As for cruising, with the MT in 6th you go 72@3000rpm and 84@3500. With the DCT in 7th, you're at 76@2500 and 92@3000. So the MT is definitely running harder on the interstate. The final ratio for both is 3.73 Calculations made using the link from CLH. Still getting the '18 MT |
M3 Adjuster7905.50 chief1richard381.00 |
06-22-2017, 07:11 PM | #21 |
Rep 155
I agree with the comments for a longer 6th gear. 80mph is my highway cruising speed and 3100rpm with the MPE yields a fair amount of drone. However, 70 or 90 mph is no problem. Also, Ive never used 6th gear on my "local" higher speed tracks.
End of my unproductive venting
Living Life Turn After Turn!
[/url] F87 M2 Performance Edition - 2017-current F15 X5 35d - 2014-2017 E36 M3 - 2009-2016 |
06-23-2017, 09:35 PM | #22 | |
Rep 2,672
