06-12-2017, 10:45 AM | #1 |
Rep 4
My M2 with Apex EC7 Anthracite 18" fitted
Wheels arrived in the UK from APEX last week so sealed them with Gtechniq C5 and coated with Gtechniq EXO V2 before fitting the tyres over the weekend. Spec are: 18x9.5 ET35 front and rear Tyres: Goodyear PS4 275/35/18 front and rear Fronts have a 12mm spacer fitted which gives loads of clearance to the suspension (8-10mm) and sits perfectly inside the wing/fender Rears have no spacer fitted as the 12mm were a bit too much, an 8mm would be perfect I think. Will be fitting suspension later this week, will post more photos then. |
06-12-2017, 02:11 PM | #3 | |
Member
35
Rep 60
Thanks! |
06-13-2017, 04:52 AM | #4 |
Rep 4
06-13-2017, 07:09 AM | #5 |
Rep 1,017
Speedwell-Industries434.00 |
06-14-2017, 05:00 PM | #6 | |
Rep 246
cheers MJ |
07-26-2017, 11:59 PM | #10 |
1423
Rep 2,657
Very nice OP. I am loving Anthracite against that paint code
OEM hardware works with all of our wheels, no problem. - Ryan
08-03-2018, 09:49 AM | #11 |
M2 Pilot
138
Rep 165
Were you able to fit the front 275s with just the spacer, or do you have neg camber as well? Looking at a very similar setup for the track.
Thanks!!
America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt
'17 BMW M2 |
08-31-2019, 07:33 PM | #14 |
Rep 385
This is beyond looks. Stock wheels cant support the tires needed for max performance. 9.5F 10.5R are needed and weight as low as possible. Apex is the way to go in my opinion for price vs performance. Their forged offerings are 3 and 4 pounds less than stock wheels. That is significant for rotational mass. You can get another 3 sounds savings per wheel using BBS FI-R or HRE 101 LW and that will cost you close to 10,000$ versus Apex (less than $3,000).
08-31-2019, 07:36 PM | #15 | |
Rep 385
