M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Leaking / Faulty Differential?
      10-28-2022, 02:40 AM   #1
RKR
279
Drives: F80 ZCP
My gf's m2 comp has developed what looks like a leak from the output shaft on the diff. Can anyone confirm if that looks to be true going by this rubbish picture?
The car has recently developed heavy vibration under WOT however only really at speeds greater than 80mph. Putting 2 and 2 together here given the vibrations and looking at the residue on the midpipe but I could be completely wrong!
Thanks
      10-29-2022, 04:41 PM   #2
David.m
Drives: M2 LCI 6MT BSM
It's likely the driveshaft seal, it's not uncommon on F8X cars (not long ago had mine replaced at 100K km). The sub-frame has to be dropped to replace it so it's worth having all 3 seals done together.
Probably want to get under and confirm source of the leak though
RKR278.50
