M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Right turn signal malfunction
      02-15-2022, 09:42 PM   #23
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
Originally Posted by Fly M2 View Post
I was not so fortunate. I had the same issue with both taillights right after the warranty expired. $500 each
Sorry to hear that.
      02-23-2022, 09:02 AM   #24
zellatc
Drives: M2 LCI
But did you try cleaning both the cable and the plug?
Since I cleaned, still no issues...
If you just replaced the tail light, it's a matter of time it will happen again
      02-23-2022, 05:57 PM   #25
Zeese
a coffee drinker
Zeese's Avatar
Drives: 2017 BMW M2 6MT (LBB)
Does the new harness make a difference?
Repair cable tail lights
      02-25-2022, 10:14 AM   #26
pablom2c
pablom2c's Avatar
125
Drives: 2020 M2C
I had the same errors with my M2C 2020 and just disabled the bulb check for the rear tail lights with Carly app and the problem hasn't come back, the lights work fine.
CURRENT: 2020 M2 Competition (BSM)
Previous: 2008 135i
DanG10660.50
      02-25-2022, 10:48 PM   #27
qnet
qnet's Avatar
Drives: 18 Jeep Wrangler, 18 M2 LBB
I've had this happen off and on, but it doesn't last long. I had the dealer look at it last year during the routine oil change. They said it was because of my modifications. I only have a MPE and dash cam which are wired in the fuse box in the trunk. They must have did something because the problem went away for almost a year, then popped back up. It comes come up every once in awhile, then goes away for months.
My M2 isn't my daily driver and I'm not driving it as much when I first got it, so not sure how prevalent the issue is. My warranty is up so I'll probably just try what has been mentioned or I'll have to pay for it unfortunately.
DanG10660.50
      02-28-2022, 01:28 PM   #28
steve457
Drives: 2019 M2C
I don't think this is recommended, as I read in the other thread that while it no longer would show an error on your dashboard, the problem could occur and you just wouldn't notice it. In other words, you would think your turn signal is working fine, but in reality you could have the dim malfunction.
DanG10660.50
      03-01-2022, 07:35 AM   #29
DaveF82k
9
Drives: X5
Originally Posted by DanG View Post
I see that the administrators closed my old right turn signal malfunction thread.
So I guess I need to start a new one.
Two years after I thought my dealer had fix this problem, I just started to get the dreaded right turn signal malfunction message.
I go to the dealer in a little over a week. I guess we will see what they do this time. Good timing though. My warranty is up at the end of this month.
Yes
      03-15-2022, 09:54 AM   #30
zellatc
Drives: M2 LCI
For what I have read, maybe in the pre-LCI (non-LED) lights. At least, I didnīt see any burns or indications that the was any overcurrent in any pin.
From my side... still working flawlessly without any single fault since I cleaned them.
DanG10660.50
      08-14-2022, 04:13 AM   #31
zellatc
Drives: M2 LCI
Updates here: https://f87.bimmerpost.com/forums/sh...1#post29219631
(to centralize the discussion in one thread)
