M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > What engine oil to use for M2C?
      04-12-2023, 05:18 PM   #67
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
Originally Posted by Jasond13 View Post
I just switch to the platinum Euro 5w40 anybody notice on a cold start the engine really made some noise. They really say it’s not good to go from a 0w to a 5w. Anybody experience this any input?
In the UK / EU the BMW-LL04 oil BMW recommend is only readily available in 5W-30 and 5W-40.
0W or 5W shouldn't make any noise difference cold start for sure.
The winter weights are at -17degC.
F87source7251.50
chris7197334.00
      04-23-2023, 07:13 AM   #68
E90convert
Drives: F87 M2 DCT, F15 X5
“What oil do I use” seems to bring out a lot of opinions. This is what I would do, located in the US. Other countries may use different specs for a variety of reasons (emissions systems, fuel chemistry, environment, engine calibration, ect.) I run BMW Genuine 0w-30 SP in both my cars. Of course using FCP Euro lifetime warranty. X5 gets 5k oil change interval. First UOA looks great. I’m gonna track my M2, so I’ll keep the OCI to 3k and check the condition of the oil via UOA after that.
If you’re on street driving, BMW oil or LL-01FE rated is fine. Be sure to check the API spec for the latest formulations. If you’re modded AND track use, I’d step up to a Motul 300V 5w-30 and see how that fairs. Stronger antiwear additive package that may not be great for your emissions system (not important if you’re catless) and lacks stout antioxidants for long drain (replaced by antiwear additives lol). Motul is on Porsche forums a lot and have recommended 3k intervals with 300V regardless of usage. Something to remember, thicker oil will reduce efficiency and increase heat. Hotter oil breaks down additives faster, and the extra heat on the engine accelerates wear to seals and puts extra stress (thermal cycling) on the metals. For example I could run 15w-50 in my S2k and it would get to 280F within 4 laps. Where a 0w-40 would maintain oil pressure per Honda spec and keep temps around 260F.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport
Sold in 2023 '12 F30 335i 8AT Sport Line
Sold in 2020 '08 E92 335xi 6MT
Sold in 2016 '08 E90 335i 6MT - FBO
