06-10-2017, 01:17 AM | #1 |
Rep 791
Hi all
Anyone attempted to purchase 34402222539 - a f22 m perf part with a carbon fibre handle. I'm planning to swap the oem parking handle with the cf piece and would like to know if it's a straightforward fix. Thanks
YMB F80 M3 DCT (Gone but never forgotten)
AW F87 M2 6MT (Current whip) |
06-10-2017, 06:56 AM | #3 |
Rep 549
Drives: The Bus
As said. It should be a very easy job. I did mine in 5-10 minutes and most of that time was making sure the boot was on straight and the stitching lined up as I like.
06-10-2017, 04:46 PM | #5 |
Rep 521
Very straight forward, just start with the clips on the boot and then pull hard on the handle. A couple min job if you can find a good position to pull.
06-12-2017, 03:08 AM | #7 |
Rep 791
I'd like to know if anyone managed to swap the handles and reuse the oem alcantara polar blue boot.
The std oem handle is plain black plastic/rubber finish. The m perf part is cf but the alcantara finish has criss cross grey stitch.
06-12-2017, 03:29 AM | #8 |
Rep 1,514
I bought the Performance Carbon Interior kit and used this DIY, it has the hand brake removal instructions:
http://f87.bimmerpost.com/forums/sho....php?t=1274653 Yes mate, i bought the kit in the DIY i posted above, it only comes with the handle so you re-use the OEM boot. |
M2wolf182.50 |
06-15-2017, 11:50 AM | #9 |
Rep 4,550
Drives: 2015 328d xDrive
here's a pre built one. i just bought that, swapped with the stock one and sold the old one on the regular 2series forum. easy peezy.
https://ind-distribution.com/product?sku=IND-F87-EBRAKE |
M2wolf182.50 |
07-03-2017, 05:16 PM | #10 |
Rep 1,718
Just watch your teeth when you pull it off!! I swapped out the ebrake and the shift knob in my F30 (basically the same process) and nearly knocked my tooth out when pulling it off lol. Felt like a dumb ass, but in the end successful and these guys are correct, takes only a few minutes.
