06-07-2017, 07:55 PM | #1 |
Rep 362
Unstable Engine RPM, Need Your Advice!
Hey guys, hope you can give me some advice if it's a normal situation. I just installed Dinan Sport Tuner and start seeing a bit unstable engine RPM while downshifting into "1" then stop, the engine RPM will go up a bit into 900rpm then back to ready position 650rpm around. I wasn't aware this situation before this mod but just want to get your thought about this.
Is that OK situation? |
06-10-2017, 07:00 PM | #2 |
Rep 120
I don't see that exact problem but I do notice when cruising at a consistent speed rpm's/ boost seems to very ever so slightly. Which setting are you using? I seemed to settled with sport or 2psi IIRC. I also have a fabspeed cat and at higher altitude in Denver, as a disclaimer.
06-10-2017, 07:13 PM | #3 |
enthusiasm > practicality
4021
Rep 2,247
Drives: 987 CS | G35x
What fuel and mode are you using?
06-11-2017, 10:02 AM | #4 | |
Rep 362
06-11-2017, 02:38 PM | #6 |
4021
Rep 2,247
Hmmm. Disconnect the unit and see if the problem persists. If if doesn't, reconnect it and see if the same issue occurs. If you're still getting the unstable rpm, it's probably related to the Sport tuner. Dinan_Engineering can give words of wisdom I'm sure.
06-12-2017, 08:07 AM | #8 |
Rep 306
Drives: MY17 LBB M2
Sounds like the auto-blip, rev match...? You downshift into first gear before you stop?
06-12-2017, 07:33 PM | #11 |
Rep 362
06-12-2017, 10:16 PM | #12 | |
Rep 120
06-12-2017, 11:56 PM | #13 | |
Rep 3,888
1 Remove Sport Tuner 2 Remove or replace air filter 3 Clean (maybe replace) MAF sensor, if 1 and/or 2 aren't the cause I've read where an air filter alone, such as the BMS intake, can sometimes cause a rough idle similar to what you are seeing. |
06-12-2017, 11:56 PM | #14 | ||
Rep 362
06-13-2017, 12:04 AM | #15 | ||
Rep 362
06-13-2017, 08:54 AM | #16 |
Rep 362
Sorry I checked last night, the rpm up then down after I stop. I'm thinking about MAF sensor since I'm using AFE oiled air filter. Possible?
06-13-2017, 10:58 AM | #17 |
Rep 120
I only ran Sport+ a few times and for me it just didn't seem as natural of a feeling. Too boosty, if that makes sense but don't recall your exact issue. I can just change mine back and test it again. I also punched it at 70 one time on the highway and the traction control light lit up for a few seconds in S+ and thought, I really don't need this much power, traction is more of an issue. Just another reason I've been leaving it in Sport. Between the Dinan and the Fabspeed Cat I have no complaints!
06-13-2017, 01:55 PM | #18 | |
Rep 362
06-13-2017, 11:41 PM | #20 | ||
Rep 362
Any idea? |
06-14-2017, 07:49 PM | #21 | |
Rep 3,888
06-14-2017, 07:52 PM | #22 | ||
Rep 362
