06-09-2017, 07:55 PM | #23 | |
Rep 1,153
From what I can tell, by the way, the stock DP on an N55 engine is 400 cell. See https://europeanautosource.com/evolu...npipe-n55.html Last edited by BruceM; 06-09-2017 at 08:04 PM.. |
c0riolis82.50 |
06-09-2017, 09:02 PM | #24 | |
Rep 2,577
My comparison picture in the OP doesn't look anything like a 400 vs 300. It must be a 600 stock or more, to say the least.
Lemania 2320
06-09-2017, 09:25 PM | #25 | |
Rep 3,006
Is the factory cat the entire length of the cylinder? If so we could apply the same points made in bullet 2 of the OP? The M2 is direct injection plus what 11+ years of other emissions improvements. |
06-10-2017, 12:43 PM | #26 |
Rep 3,006
I'm still siting on the fence to see if the freer flowing DPs are related to the "Drivetrain notifications" some are getting and if there is a true, even slight performance benefit. Especially, interested in those tracking or auto-crossing vs. enthusiastic drivers.
Since BMW said their are no gains from the freer flowing MPE. For me, I'm not sure if the "sound" is worth the trouble... There will be no power gains with an axle-back exhaust because the turbocharged engine will compensate to create the same amount of torque. It would be different with a naturally-aspirated engine, but not with the turbocharged engine. http://www.bmwblog.com/2015/11/05/in...ormance-parts/ Though BMW also said, which is consistent with posts I have seen... The result is faster engine response as well as noticeably improved acceleration across the entire engine speed range, enabling a 0-60 mph sprint 0.2 seconds quicker than stock. http://f87.bimmerpost.com/forums/sho...=m+performance |
06-10-2017, 12:54 PM | #27 | |
Rep 1,027
omasou2088.00 |
06-11-2017, 04:28 PM | #28 |
Rep 629
Just a note to the OPs original post- I believe the Milltek catted down pipe is basically this unit but branded; certainly it's a 300 cel HJS unit that looks the same, rather than the 200 cel HJS Fabspeed etc.
Just a heads up really especially for fellow UK owners as the Milltek is easier to get over here |
06-11-2017, 07:15 PM | #29 | |
Rep 2,577
If you see any of those brands is selling HJS Euro 6 300 cell downpipes, that is most likely the distributing of HJS in house products - to separate from HJS cat being used as core of the downpipes that is fabricated by companies under those brands.
Lemania 2320
06-13-2017, 06:37 PM | #30 | ||
Rep 3,951
06-13-2017, 08:02 PM | #31 | |
Rep 1,153
https://www.sema.org/sema-enews/2011...ermarket-parts And from the FTC itself: https://www.consumer.ftc.gov/article...ne-maintenance Further, from the second link: "Simply using an aftermarket or recycled part does not void your warranty. The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny coverage under the warranty simply because you used an aftermarket or recycled part." "The FTC says the manufacturer or dealer must show that the aftermarket or recycled part caused the need for repairs before denying warranty coverage." I do not know why this particular myth regarding aftermarket parts continues to have life. The language is quite clear--there is no automatic voiding of warranty simply as a result of using an aftermarket part. If you use an aftermarket part that itself goes bad, of course the warranty won't cover it. But if you use an aftermarket part that is in a chain of parts, and a part downstream goes bad, then the manufacturer has to show that your part caused the problem to deny coverage. So, if you install a catted DP and then crack a piston, the warrantor can't deny coverage on the engine simply because you installed the DP. And good luck to the warrantor in proving that the DP caused the piston to crack. As for a flash, that gets trickier, but only because causation gets trickier. If I install an aftermarket DP, and my air conditioner fails, good luck denying coverage. But if I flash a car, and the flash raises boost, and I blow a head gasket, then I'm probably out of luck. I've run into this debate myself on another car. I lowered my Jag XKR with springs. A couple of years later, I get some clunking up front. Spring perches are broken. Dealer denied coverage. I asked them for proof that the aftermarket springs broke the perches. They couldn't explain the mechanism by which this would have happened. We compromised, and I paid a grand for what would have been a $5500 repair. I got a bit lucky on that one, but they acknowledged their burden of proof. Some dealers flat out deny it, but it's the law. |
QM287.00 |
06-13-2017, 08:18 PM | #32 |
Rep 2,577
Hey guys, granted we're all aware of potentially losing warranty in using aftermarket downpipe. The reality is, it's a matter of your relationship with dealer, this can vary from region to region - where I live, we see from time to time blown engine with all powertrain mods bolted on gets covered. Remember it's ultimately BMW, the manufacturer that's bearing the cost of a valid warranty claim, so dealer isn't necessarily working against you, who they may or may not value. Plus, you always have the option of putting back stock downpipe prior to going to dealer for warranty. Anyway, warranty concern isn't really the point of this thread, let's drop it for a little bit please.
Lemania 2320
06-14-2017, 04:26 PM | #33 | |
Rep 715
Drives: It like I stole It.
Garage List 23 Gladiator Rubico ... [0.00]
08 uuuge wrangler r ... [0.00] 718 gt4 Wife's 2nd car [0.00] 2007 Audi RS4 [0.00] 2017 BM2 M2 [0.00] |
P car or AND M2>
06-16-2017, 12:47 PM | #34 | |
Rep 5,369
If you add an aftermarket DP that does meet OEM specifications, BMW could void your warranty because the DP does not meet OEM specifications, changes the operation of the DME, and more importantly, is against the law to modify emissions controls devices like catalytic converters, ECU (thru flashes and piggybacks), emissions sensors (i.e., relocating O2 sensors), etc. Since things like DPs and ECU flashes and piggybacks manipulate and change the operation of the DME, which is outside of BMW's designed parameters, BMW can easily say that the DP you installed caused "X" part to fail inside the motor thus you're responsible and warranty coverage denied. It would be on YOU to prove the failure was not caused by the aftermarket part. You might be able to arbitrate it, but that would take a lot of time and chances are nil that you win. Same goes for pursuing legal action. BMW has a lot of lawyers and they can tie things up for quite some time. The chances of winning are low as well. The burden of proof is on you and the first thing that they would argue is that the MMA is not applicable in the case, which would be true. I strongly suggest that you reread the act and better understand it's intent. You are correct that BMW cannot deny warranty coverage on unrelated failures such as an A/C failing and the car has a DP. With that said, they could get pretty crafty and claim that a leaking half-shaft boot was the result of the added power from a piggyback. We both know it's BS, but BMW could simply claim that the elevated power levels are outside the design limits of the drivetrain thus go pound sand. In the end, if you choose to modify your car with performance enhancing parts that increase power, expect BMW to deny warranty coverage on the powertrain in the event something fails and consider it a win and sheer luck if they don't or goodwill the repair. |
06-16-2017, 01:14 PM | #35 |
Rep 3,951
Correct on how it works. I have been through the courts with this with a modified car especially non oem spec and non carb approved mods.
06-16-2017, 01:50 PM | #36 | |
Rep 1,153
You can speculate, or simply declare, how easy it would be for BMW or other manufacturer to defeat a warranty claim with a non-OEM part in the chain, but that's just what it is--speculation. It all depends on causation. In some cases, it could be tough to win. In others, quite easy. "BMW's lawyers" don't intimidate me in the slightest. |
06-16-2017, 03:48 PM | #37 | |
Rep 5,369
You modify a car at your own risk. Pay to play. |
Poochie9104.50 |
06-17-2017, 07:40 PM | #38 | |
Rep 1,153
And what has pissed me off more than most things over my career is defendants who try to use lawyers to make the cost of justice too high to pay. Sometimes, they run into people with whom that doesn't work. |
06-05-2018, 12:59 PM | #41 |
24178
Rep 190,775
subliminalaudio313.50 |
