07-27-2016, 08:27 AM | #24 | |
30
Rep 132
In the recent past, we data logged our own and other client E46 M3 with the Eventuri CF Intake at the track, street, and dyno. Time and time again, it proved that the whole comprehensive system lowered IAT's near ambient and sustained them far better than stock and other aftermarket versions. |
07-28-2016, 10:39 PM | #26 | |
Rep 3,006
Not that I'm a fan of Dinan but there's a reason it's called a cold air intake. Even the factory air box is a cold air and forced air design. |
07-29-2016, 12:57 PM | #27 | |
Rep 169
When can this be shipped? I ordered carbon front grill for M2 and a few days later Ryan said 6 weeks waiting... I'm sure this should be back-ordered also... Thx... |
07-30-2016, 09:54 PM | #29 | |
Rep 4,323
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
07-31-2016, 01:46 PM | #30 | |
Rep 1,153
08-11-2016, 07:42 PM | #33 | |
Queen of Motorsports
235
Rep 282
Drives: BMW 2016 M2
Instagram @winterrogue_F87
Tai Winter Targaryen |
08-12-2016, 12:52 PM | #35 |
5371
Rep 3,789
08-12-2016, 12:53 PM | #36 |
5371
Rep 3,789
I'll just leave this here too...
AndrewC198910931.00 |
08-21-2016, 01:13 PM | #37 |
Rep 169
Mike, guess ETA of carbon intake gonna take awhile...
Also saw you guys carry Fall Line Motorsports, heard they got parts for F87 M2, what suspension pieces do they have now? |
08-23-2016, 04:48 PM | #38 |
9587
Rep 10,878
Every Fall-Line suspension component that we carry for the F8X M3 / M4 is compatible with the F87 M2!
08-24-2016, 01:09 PM | #39 | |
Rep 169
Fall Line Motorsports F8X M2/M3/M4 Toe Link Kit - Race Fall Line Motorsports F8X M2/M3/M4 Rear Camber Shim Kit Fall Line Motorsports F8X M2/M3/M4 Front Mono Ball Conversion Kit Fall Line Motorsports F8X M2/M3/M4 Rear Upper Control Arm Bearing Kit Fall Line Motorsports F8X M2/M3/M4 Toe Link Kit - Standard Fall Line Motorsports F8X M2/M3/M4 Front Sway Bar End Link Kit Fall Line Motorsports F8X M2/M3/M4 Rear Sway Bar End Link Kit All fits And Fall Line Motorsports F8X M3 / M4 Air Charger Fall Line Motorsports F8X M3 / M4 Oil Cooler Guard Fall Line Motorsports F8X M3/M4 Bolt In Roll Bar Fall Line Motorsports F8X M3/M4 Tow Strap All does not fit, correct? |
08-24-2016, 01:20 PM | #40 | |
Rep 169
Fall Line Motorsports F8X M2/M3/M4 Toe Link Kit - Race Fall Line Motorsports F8X M2/M3/M4 Rear Camber Shim Kit Fall Line Motorsports F8X M2/M3/M4 Front Mono Ball Conversion Kit Fall Line Motorsports F8X M2/M3/M4 Rear Upper Control Arm Bearing Kit Fall Line Motorsports F8X M2/M3/M4 Toe Link Kit - Standard Fall Line Motorsports F8X M2/M3/M4 Front Sway Bar End Link Kit Fall Line Motorsports F8X M2/M3/M4 Rear Sway Bar End Link Kit All fits Rogue Engineering only have these? Rogue Engineering Monoball Front Tension Arm Bushing (which part is the same in Fall Line?) Rogue Engineering Adjustable Swaybar Links (Front found, have rears?)) and which brand do you think works better and which ones you recommend? |
08-25-2016, 11:10 AM | #41 | ||
9587
Rep 10,878
08-26-2016, 06:09 PM | #43 |
235
Rep 282
Drives: BMW 2016 M2
Got mine today!
