07-23-2017, 11:50 AM | #1 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
Fun and Fuel Efficient Car Suggestions
I'm going to be having a 35-40 minute commute in the next month or 2, so I'm currently looking for some suggestions for a fuel efficient car that is still fun to drive. From what I can find, the BMW 230i has the most HP/TQ with mid 30s mpg, but the new civic si coupe/sedan makes decent hp, subpar tq for a turbo motor IMO, but makes upper 30s in mpg. However, I know that HP and TQ numbers are a bad starting point for "fun to drive" criteria, but it's the easiest starting point when just looking on the internet.
What I'm hoping for from this thread is the collective knowledge of everyone on the forums and your personal experience of different models that also get 35+ mpg but are still fun to drive. Budget is $15k-25k so new and used are on the table. 2 or 3 pedals. gas/diesel/electric/hybrid. If going Hybrid, I know that I'm trading the fun to drive for 40+ mpg which is fine since I'll have the 240 for my fun drives. Some considerations: mx5 - new/used 228i mini hardtop 2 door (3cyl) civic (regular or si) - new/used |
07-23-2017, 12:08 PM | #3 | |
Rep 1,303
07-23-2017, 12:20 PM | #4 |
Rep 754
Mk7 GTI is the best option imo
Joe2402923.50 FriskyDingo380.00 |
07-23-2017, 02:55 PM | #7 |
Primo Generalissimo
4672
Rep 4,022
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
Golf R/S3
228/230i Corvette C7 Camaro RS GS400h |
Joe2402923.50 |
07-23-2017, 03:16 PM | #9 |
Rep 1,303
I've heard a lot of people enjoy the mk7s. Might test drive one when I get back. Thanks
Think you're missing the point of fuel efficient. I mean mid 30s mpg, not fuel efficient for a v10 This get less than 30mpg on the highway. At that point I'd just drive my 240 Golf r, s3, camaro rs, gs400h and corvette all get similar or worse mpg than the 240. 228/230 is nice, but trying not to have 2 2ers. Would like to have a different model. 240 already has CAI, OCC, Remus catback, catless DP, jb4. Would like the pure turbo upgrade, but I think I'm going to stay away from that until warranty is up. Easy enough to uninstall the catless DP, intake, OCC, and tune and leave the exhaust should I need any warranty work, turbo wouldn't be as easy. |
07-23-2017, 04:05 PM | #10 |
Rep 2,665
My vote would also be for the GTI but if your main goal is to save gas money you may want to run the numbers to see if getting rid of your new car will really help enough to bother. Assume there will be a big hit on the recently purchased car.
Estimated savings between your car and the GTI (20k miles a year, 70% highway) is $700 a year - https://www.fueleconomy.gov/feg/Find...id=37972&#tab1
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
Joe2402923.50 |
07-23-2017, 05:07 PM | #11 | |
Primo Generalissimo
4672
Rep 4,022
Drives: All of them
I forgot to mention Fiat Abarth, just buy it used because it depreciates fast. I got 36 mpg consistently and I had a piggyback on it. It was fun to drive despite its quirks. |
Joe2402923.50 |
07-23-2017, 05:40 PM | #13 |
Rep 8,339
Spend less but get less mpg so cost is the same. Maybe an ecoboost mustang with 30 mpg for example? Or a wrx or evo? 5 mpg less vs 10k for gas goes a long way. That's 4800 gallons which for a 20k, 30 mpg car means you'd have to drive 850,000 miles to have the same cost. As a 30k car with 35 mpg. Till you hit 850k miles, the 20k car is cheaper.
Joe2402923.50 |
07-23-2017, 11:59 PM | #14 | |
Rep 1,303
07-24-2017, 12:00 AM | #15 |
Rep 1,303
07-24-2017, 12:02 AM | #16 | |
Rep 1,303
07-24-2017, 12:03 AM | #17 |
Rep 1,303
Guy I work with has an Abarth 500. Sounds good and is pretty quick. Just heard reliability on them sucks. What quirks did yours have?
07-24-2017, 04:18 AM | #18 |
Rep 1,514
07-24-2017, 05:29 AM | #19 | |
Primo Generalissimo
4672
Rep 4,022
Drives: All of them
07-24-2017, 05:43 AM | #20 | |
Primo Generalissimo
4672
Rep 4,022
Drives: All of them
The car is cheap, for $12k used don’t expect the fit and finish of anything close to a BMW. It’s like taking a step back into the 80-90s. The seating position is odd. It’s a 5 speed instead of a six speed unless you get automatic. The shifts are long and rubbery. The stock radio sounds like an old Motorola. Beyond that, the car is pretty awesome. There’s a good sized trunk and if you put the rear seat down it swallows most everything. My recommendation would be to get the base manual with fabric seats (clean up easy). They typically have lower miles and sell for less. I think sticker said 34mpg but I only got that if I sat in traffic. I was usually around 36-37mpg. I got a madness 500 piggyback as my only mod. I would still have it as a fun little back up car but ended up trading it for a cargo van I needed. With the piggyback, it made glorious little popping sounds on the overrun. There is no muffler and the exhaust is designed by Akropovic. In stock form, the car has 160hp/170tq. With the piggyback it’s 200-210hp/240tq. You won’t pass an M2 but you will surprise people. I drove it like 34,000 miles over 18 months, never skipped a beat. It’s a pretty simple design. If it has reliability issues, it’s the owner not taking care of it which is usually the case. |
07-24-2017, 07:07 AM | #21 |
Rep 2,665
If you end up buying another car figure out the cost to insure, maintain, repair and then the depreciation on it and it is unlikely to make sense to get another car to save money either. Then as you said you spend most of the time in would rather not be in.
07-24-2017, 09:50 AM | #22 |
Rather Ambivalent
380
Rep 755
Wouldn't even be considering anything other than a GTI or A3.
Maybe a Civic Si if I could get past the looks. Everything else is either going to be older/high mileage for the money, less fun to drive, or less practical/driveable on a day-to-day basis. |
