M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Installed: APEX/RE-71RS 275/35-18 295/35-18
      02-15-2024, 07:54 PM   #1
GenXG87
GenXG87's Avatar
179
Drives: 2023 M2 & 2018 M2
2023 BMW M2  [8.50]
2018 BMW M2  [9.75]
Looks like a rally car now, lol
Stock suspension. Ohlins R&T and Vorschlag Camber Plates in its future.
I want to see how the car responds on the track. Hopefully, I don't destroy the outside edges.
F: 18x10ET25 w/ 275/35-18
R: 18x11ET40 w/ 295/35-18
Instagram Post
2023 G87 ///M2 6MT - Ohlins R&T, Vorshlag Camber Plates, Fall-Line Rear Toe Arms, APEX VS-5RS, Conti Extreme Contact Force, JB4, IRL single mid-pipe
2018 F87 ///M2 DCT - MPE, BM3 stg1, MAD Intake, xHP stg2, M4GTS Diff/Steering, Euro MDM, Ferodo 3.12, APEX VS-5RS, Potenza RE-71RS, Cobra Nogaro
IG: Follow ME: genXg87
VGSON210.00
6speed_M23633.50
      02-16-2024, 02:14 PM   #2
E90convert
Drives: F87 M2 DCT, F15 X5
Excellent - goodbye shoulders, lol. I started to shred my PS4S shoulders after just one weekend on the stock camber. The BMW Star PSS tire has a more heat-tolerant compound on the shoulder. You might be okay with the RE-71RS, though. Let us know!
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport
Sold in 2023 '12 F30 335i 8AT Sport Line
Sold in 2020 '08 E92 335xi 6MT
Sold in 2016 '08 E90 335i 6MT - FBO
GenXG87179.00
      02-16-2024, 11:38 PM   #3
Brokenbones
Drives: M2c and S2000
If you’re tracking hard especially in hot temps get your camber plates on asap. 4 track days at 110-115 degree days and I corded the shoulders. The tire guy was impressed, first 71rs he’d seen worn that far.
GenXG87179.00
      02-17-2024, 07:50 AM   #4
GenXG87
GenXG87's Avatar
179
2023 BMW M2  [8.50]
2018 BMW M2  [9.75]
No plans on waiting till the summer. Next weekend is looking to be high 50s low 60s. Splitting duty with my wife. She has a coach and isn’t pushing as hard yet.
I want to do the camber plates with the Ohlins. Probably next month though now I find myself spending money on 2 cars for the track. Ouch.
      02-17-2024, 10:55 AM   #5
ThreeStripes
Drives: X3M
Post pics of the tire wear after the first weekend
      02-18-2024, 05:03 PM   #6
ggggbmw
Drives: 2017 M2 Manual
Very interested in how this works for you. Having the same thoughts on wanting to delay the camber plates for a bit and seeing how the tires hold up on the stock suspension.
Also curious on how well the 10" wheels are working with a 275 in the front from a rubbing perspective. Even with stock suspension and ride height, I was thinking 10"/275 was pushing it. I was planning on 10"/265 to give myself just a bit more clearance. Also planning on using Kumho V730 as they are run a bit narrower (and are really cheap).
GenXG87179.00
      02-18-2024, 06:45 PM   #7
GenXG87
GenXG87's Avatar
179
2023 BMW M2  [8.50]
2018 BMW M2  [9.75]
I've driven it fairly hard around and tested in some bumpy conditions and no rubbing. Inside clearance at the liner is tight but good. Plenty of suspension clearance.
APEX has this combo listed but says -3 deg of camber. Once I do the suspension I'll probably run 3 to 3.5 deg of camber.
      02-20-2024, 02:07 AM   #8
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
It will rub slightly on the front liner towards the front. I run the exact same wheel specs but with Yokohama A052 265/35/18 with stock suspension but -2,7 degrees of camber.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87
      02-22-2024, 02:37 PM   #9
E90convert
Just ordered so VS-5RS ET40 18x10. What spacers did you go with?
‘18 F87 M2 DCT
GenXG87179.00
      02-22-2024, 03:31 PM   #10
RugbyBro
RugbyBro's Avatar
7602
Drives: M3
You should really get camber plates if you are above beginner pace - no joke I've seen multiple sets of *new* PS4S, Cup 2s, and 200tw tires have their outer edge significantly worn to outright shredded after one day on track by decent pace drivers on F8X (0,2, & 7)
Current: F80
Prior: F82, F32
GenXG87179.00
      02-22-2024, 04:24 PM   #11
GenXG87
GenXG87's Avatar
179
2023 BMW M2  [8.50]
2018 BMW M2  [9.75]
Yep I want to do the Ohlins at the same time.
Looks like car has -1.55 deg
On my G87 my PS4Ss got pretty beat up after 2 events.
      02-22-2024, 04:58 PM   #12
GenXG87
GenXG87's Avatar
179
2023 BMW M2  [8.50]
2018 BMW M2  [9.75]
No spacers in front I have the 18x10ET25
So you will need a bit or you will hit the strut.
In the back probably will need 12mm to make it flush.
      02-22-2024, 06:37 PM   #13
E90convert
Oh I see, you did the +25 for the front. I did 18x10 +40 square. So a 15mm spacer will get me to +25. Glad to see it fit!
‘18 F87 M2 DCT
      02-22-2024, 07:18 PM   #14
GenXG87
GenXG87's Avatar
179
2023 BMW M2  [8.50]
2018 BMW M2  [9.75]
Right now stock height w -1.5 degrees looks like it pokes too much to me. once lowered and with -3 I think it will be right.
I’m glad I went 275s vs 265s.
      02-22-2024, 07:20 PM   #15
GenXG87
GenXG87's Avatar
179
2023 BMW M2  [8.50]
2018 BMW M2  [9.75]
Good news is the RE71 RS are rotational not outside. So I can swap rubber after the weekend and get fresh edges 🤣
      02-23-2024, 10:57 AM   #16
RugbyBro
RugbyBro's Avatar
7602
Drives: M3
-1.5 is the stock amount, it's a shame camber wasn't adjustable for F chassis cars (and still isn't on G cars). Just my opinion - wouldn't wait for Ohlins if those aren't coming in the very near future. If they are, then great do it all at once.
Good news is the RE71 RS are rotational not outside. So I can swap rubber after the weekend and get fresh edges ��
Just a heads up, REs aren't recomended to be flipped - see 6:50 in the video below.
Current: F80
Prior: F82, F32
      02-24-2024, 06:31 PM   #17
GenXG87
GenXG87's Avatar
179
2023 BMW M2  [8.50]
2018 BMW M2  [9.75]
Total time on track about 100min at Road Atlanta. My wife and I were splitting time. Here 2nd track day and my first time in this track.
Btw not a direct comparison but I like these RE-71RS’s a lot more than my RT-660’s on my G87.
Works well cold and up to about 170deg. Predictable at limits. Seems pretty durable.
Here are pics after two session. Continued to lower pressure throughout the day to shoot for 34 front 33 rear.
I’ll post pics after our day at AMP as well.
Quick edit. Slight rubbing on left fender. Most noticeable in turn 12.
ggggbmw432.50
      03-01-2024, 07:27 PM   #18
MooMooM2
MooMooM2's Avatar
1819
Drives: M2 Comp
My 71rs looked worst after 1 track day and I have camber plates set to about 2.6 degrees. As you get more comfortable with the car and/or track the wear will start to be way more apparent quickly without a decent amount of camber
      03-02-2024, 08:59 AM   #19
medphysdave
medphysdave's Avatar
Drives: M2 CS | 85 of 592
Yeah, those look pretty good. You didn't wear through the shallow V on the outer edge. I got some where on the outside running -3.2.
I did have pretty even tire temps across the face. With infrared not probe. I'll need to up my tire temp measurement game at some point.
GenXG87179.00
      03-02-2024, 05:47 PM   #20
GenXG87
GenXG87's Avatar
179
2023 BMW M2  [8.50]
2018 BMW M2  [9.75]
Here are the pics after AMP. Definitely nocticeable wear. My wife is going to run it at Roebling Road next week but she isn’t too hard on it.
Then we will start doing suspension. Finishing up installing Ohlins R&T in the G87 this weekend. Nice quality and likely what we will do on the OG as well.
