01-31-2024, 07:15 PM | #419 | |
Rep 583
01-31-2024, 07:51 PM | #420 | ||
4736
Rep 2,554
The last part are you wanting to know what track it is that they do this testing on? If so I know exactly what it is. |
01-31-2024, 09:13 PM | #422 | |
4736
Rep 2,554
I would be curious how much the weight makes a difference between the F87 and their test miata on long term pace on these tires. Certainly lower tread will help but wonder if the increased abuse from a heavier car would counter it. |
Sungillest101.50 |
02-01-2024, 09:01 AM | #423 | |
Rep 3,703
Sounds like it’s a tire that definitely needs heat cycling to balance out its grip performance thru its life. |
02-01-2024, 10:32 AM | #424 | |
Rep 344
I know quite a few WRL teams run this tire so I'd be curious to hear experiences on them. Alternatively, last time I was in the WRL pits at COTA, a lot of teams were running A052s which seems very odd to me given that tires' supposed heat tolerance weakness. |
02-01-2024, 11:05 AM | #425 | |
4736
Rep 2,554
jefe2000776.50 |
02-04-2024, 12:42 PM | #426 |
Rep 81
I had an opportunity to speak with a Bridgestone engineer that worked on the RE71RS and asked him this very question. He said it is more of a hero lap tire and falls off fairly quickly, but he said some of the endurance guys have had luck running it at higher pressures and getting fairly consistent performance out of it. He said it definitely does not get faster as the tread wears.
02-05-2024, 11:03 AM | #427 | |
Rep 344
ZM22827.50 |
02-05-2024, 08:40 PM | #428 | |
Rep 81
02-20-2024, 07:32 PM | #429 |
Rep 426
Drives: F87 M2 DCT, F15 X5
I'm about to pull the trigger on either VS5-RS 18x10 +40 and 12mm spacers or TA16 +33 and 5mm spacers. Spacers and wheel bolts from Apex. These will be track wheels only. The tires will be Kumho V730 275/35-18
Before I click buy... is there anything else I need to consider? I am stock suspension OG M2 with -3 degrees front camber and -2 degrees rear camber.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO Last edited by E90convert; 02-21-2024 at 07:38 AM.. |
02-21-2024, 02:05 PM | #430 | |
Rep 584
For comparison, I have an OG M2 and run: - Apex SM-10 18x10 33ET square (12mm spacer up front) - Nitto NT01 275/35/18 square
2017 BMW M2 5Spd, 2007 VW Touareg, 2023 Yamaha MT09 SP
https://www.instagram.com/dvas99/ https://www.youtube.com/channel/UC2j..._as=subscriber |
02-21-2024, 04:14 PM | #431 | |
Rep 3,703
02-21-2024, 04:23 PM | #432 |
Rep 426
Thanks. I’d effectively be at a +28 or +21 with the stock suspension depending on the spacer. With the +25 front, do you have more than 3mm clearance?
Other thought is I could run an 18x9.5 +35, and use a 12mm spacer to get +23. This seems more friendly for both front and rear, but I am giving up 1/2 inch, smaller than the car comes with stock in the rear! Last edited by E90convert; 02-21-2024 at 04:40 PM.. |
02-21-2024, 05:23 PM | #433 | |
Rep 3,703
9.5 is too narrow for a 275. |
02-21-2024, 05:29 PM | #434 |
Rep 426
What suspension are you running?
I did just find this https://f87.bimmerpost.com/forums/sh...1346915&page=2 18x10 513M with a 12mm spacer (effectively +28) just barely clears the stock suspenion. It would seem like +28 is ok for stock, but would need to switch to +21 to clear coilovers. What do you think? Going with the 5mm spacer is appealing because I can just leave it on for my stock winter wheels and 19x9.5 ET28 front rain/street wheels |
02-21-2024, 05:44 PM | #435 |
Rep 426
Reading through Apex’s fitment guide it seems like they try to push you into a +20 to +25 offset for a 10” and 275 front setup. Even if 5mm does fit, Seems like I should just get the 12 mil spacers so I don’t have to rebuy them when I put coilovers on
02-22-2024, 06:00 AM | #436 |
Rep 3,360
9.5 is the standard width used in the TRA measuring guide for a 275/35 and is used by lots of manufacturers as OE sizing (i.e. rear of E39 M5 for example). The rim width range in the TRA guide is 9-11".
That said, I'm always in the camp for "the wider the wheel the better" for decades, and it was nice to see the extensive Tire Rack testing recently showed that with such detail. On my M3 I'm running 275/35-19 in the rear on a 10.5" wheel, and it is the perfect size for the tire imo.
Current Stable:
E90convert163.50 |
02-22-2024, 09:48 AM | #437 | |
Rep 3,703
That said, I’m running a 295 on a 10.5 wheel in the back. Would rather it be an 11” but didn’t want to risk clearance issues and wheel width isn’t as critical in the rear. At least it’s saving me a whole 0.5lb per wheel, and an extra inch of clearance when my track wheelset is in my backseat…hah! Last edited by ZM2; 02-22-2024 at 10:16 AM.. |
02-22-2024, 02:56 PM | #438 |
Rep 426
I went with the VS-5RS ET40 18x10 square with a 15mm front spacer. It had an ideal fit in the rear compared to Bimmerworld, and with the 15mm spacer, it had a better fit in the front, effectively making it a +25. Plus I could go to an 18x11 in the rear if I wanted to go back to staggered.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
02-22-2024, 06:29 PM | #439 |
Rep 3,540
x10 ET28 works fine on stock type dampers (I ran ET33 with 5mm spacer). x10 ET25 pokes a bit in the back doesn't it?
